Manned Mission to Mars: Ideal Locations for Exploration
  • Thread starter baconman71
  • Tags
    mars
In summary: PR disaster.In summary, I think a manned mission to Mars is not feasible in the near future, and the funds would be better spent on robotic missions instead.
baconman71
25
What locations on Mars would be good for a first manned mission? This is remembering that we want to 1. survive out there and 2. be able to look for possible signs of life and do other science (study geology and the atmosphere).
I'm not sure. Other than the terrain being favorable for landing and exploring, I don't know what other criteria there might be. Anyone else have any ideas?
If finding evidence of life is the primary objective, then I would think one of the lava tubes/cave formations would have to be at the top of the list. If life is to be found on Mars, it will most likely be underground away from the radiation, and where moisture/water might be present. A cave/lava tube would offer both opportunities. Check out the cave that some 7th graders discovered for NASA:
http://www.space.com/8638-7th-graders-discover-mysterious-cave-mars.html
A complete understanding of the geothermal gradient on Mars will aid in the quest as well. Wouldn't have to go to deep to get into the 'liquid water phase'. Here is a good link:
www.lpi.usra.edu/meetings/geomars2001/pdf/7044.pdf
I would be more surprised to find a planet/moon ‘sterile’ in ‘habitable areas' where liquid moisture/water exists. Sterility might not be the norm, but rather the exception? Time will tell.
Forgot to mention that the cave would also provide protection to the Astronauts from the radiation as well. Communication equipment could be left outside the cave. Not sure I would want to be the first to step into an unexplored cave on another planet? These will be brave men/women who venture there for the 1st time to say the least.
I am strongly of the opinion that the best location for a manned Mars mission is nowhere, at least anytime in the next decade or three. It's a suicide mission plain and simple with anything like today's technology.
I would have to partly agree. All about the amount of resources and time we would want to put invest into it. We pulled off Apollo missions that we were damn lucky to have succeeded with the technology at hand back then. Not without tragedy and loss of life however.
I think the resources could certainly be better served with separate robotic missions with no loss of life vs. the manned mission, but somewhere along the line a Politician will make it his/her agenda to make him/her self remembered for something.
Certainly there are Pro's to a manned mission. Not easy to explore a cave with a rover, and rovers cannot entirely 'fix themselves' out on the mission, as the Astronauts could adjust and overcome some obstacles they will encounter. There most certainly will be obstacles on the way, some of which may be deadly.
I would expect that survival and signs of life would both warrant a landing near one of the polar ice caps. Mostly CO2 but lots of H2O in there too.
From my armchair the best option would seem to be Phobos. Dig in for shelter against radiation and teleoperate equipment on the surface. Far easier to get back from as well.
I'm solidly in favor of probes to research such things. Sending people is prohibitvely expensive. Finding life on Mars [past or present] would be a wonderful discovery, but, the expense of a manned mission is unjustified.
Agreed. The extra money it would take for a manned mission could probably go further if it was invested in robotics.
But it's more than just a research project. It is the next most likely place where humans are eventually going to live (in a century or so).
Better to set up a permanent colony on the moon than a temporary visit to mars, IMO. Or even a self sufficient base in Earth orbit. The only reason to send humans to space is to learn how to live there.
I disagree with those 2 premises. Private sector space flight is here already, but hasn't reached Mars yet. What makes you think a national science mission project will be first to land? If Mars Corp gets there first, maybe they will pick sites with tourist or commerical interest?
If (when? ;)) a manned mission to Mars costs ~10 billions at some point in the future (corrected for inflation), chances are good that a scientific mission is started. It would probably involve several months of research on Mars, due to orbital mechanics, require a lot of training of the astronauts, have a high risk of failure and probably some significant radiation exposition, even with shielding.
While I cannot exclude it, I doubt that a touristic mission can get that amount of money under those conditions.
The cost of space missions is going to drop sharply once there is orbital infrastructure. So much power and thrust is needed to escape Earth vs starting from a space station in orbit.
This whole question seems to be a solution in search of a problem.
Since cost was mentioned, we really need to take a serious look at it. Spirit and Opportunity cost about $500,000/kg to make it to the Martian surface. The lunar module ascent stage weighed about 2000 kg without propellent. So that's a billion dollars right off the bat.
The LM had about 4.5 habitable cubic meters for two people. You can't put people in a space that small for 450 days, so let's say that the astronauts share a space the size of a Supermax Prison cell. That increases the volume by 4.2, and assuming the mass goes as area, the cost by 2.6. So we're at 2.6 billion.
The reliability of Mars missions is about 2/3, and manned missions is >95%. A good rule of thumb is that reducing the failure rate by x requires an increase in cost by x. If you're willing to go with a 90% success rate, that gets you to $8.7B. So that's a guess what it costs to drop two guys in a tin can on the surface of Mars.
The problem is that you can't just drop two guys in a tin can on the surface. You need to send a rocket so they can get back. A Delta II weighs about 200,000 kilograms, so you're talking hundreds of billions.
And don't forget radiation protection for the round trip, as well as on orbit, as well as on surface. How long will the trip be? 90 days each of two ways - or 200 or 300 or . . . .
Don't forget also, that we haven't yet launched anything from the surface of Mars.
The big challenge would be to get the launch vehicle and it's propellant onto Mars - intact. That's not trivial - considering how the Rovers (and they are small) were landed.
Aerobraking is not much of an option in the Martian atmosphere.
One would probably want some sort of station (e.g., Skylab or ISS) on orbit around Mars to serve as an intermediate point to and from the surface. An Earth-to-Mars transfer vehicle would rendezvous with the station. The return Mars-to-Earth would be parked there waiting for the return trip.
Radiation protection from solar wind (high energy protons, deutrons and alpha particles) as well as GCR must be addressed. One issue is the spallation reactions in the structural materials of the spacecraft - and the secondary radiation this prodcues. Low Z elements like H and Li in the form of LiH (or H in ice or frozen ammonia) provide good shield against neutrons and protons. Higher Z materials provide effective shielding against gamma radiation and X-rays.
These issues have been on the table for the last several decades or so.
Barely. There has been exactly one commercial spaceflight (not counting Virgin). They have a long way to go to catch up.
While there has been only one private venture that docked with the International Space Station, there have been dozens and dozens of commercial space flights. The communications satellite industry is a private industry in the US and in other countries. Those private communications satellites are put into orbit by private launch companies.
Moon escape velocity is 2,4km/s, Mars escape velocity is 5,0km/s. An orbit is 1/sqrt(2) of this value. This has to be delivered by chemical rockets, sure. From orbit, 1-1/sqrt(2) (~1.4km/s) deltav is required to reach escape velocity, and 0.9km/s more to reach a Hohmann transfer orbit.
An ion drive with 1N thrust can accelerate 10 tons of mass to +2.3km/s within 9 months. Actually the ion drives would require a bit more delta-v, as they cannot be used like conventional rockets (short burn to change orbits). Obviously too much, but we are just off by a factor of ~10. As ion drives have exhaust velocities of several 10 km/s, the fraction reaction mass / total mass is small (<10%) and this system (together with everything else not needed on the surface) can stay in Mars orbit all the time.
Agreed. We cannot always predict how fast our technology or what new invention could alter or speed up technology in one area vs. another.
It will at first more than likely be a combination reusable system; i.e., rail gun (electromagnetic rail system) or some other system (lighter than air balloon, scramjet, etc) with a smaller cheaper rocket for the secondary stage. NASA proposal to the President:
http://www.popsci.com/technology/ar...rail-gun-and-scramjet-fire- spacecraft -orbit
A fixed infrastructure, with low cost delivery to orbit, will exponentially accelerate the space program.
The Martian polar ice caps may be ideal depending on the mission duration as they could provide a source of water for the crew and the water could possibly be used as radiation shielding. It may also be a good spot to search for life on Mars.
I've always thought the bottom of the Valles Marineris would be a good spot for a permanent colony. This would be the area on Mars where the atmosphere is most dense, which would facilitate in-situ resource utilization. Settlers could dig into the side of the canyon for radiation shielding. The only problem is there may not be any water there, but could be imported by pipeline from a base at the north pole or synthesized with imported hydrogen and oxygen from the atmosphere.
Hercuflea said:
I've always thought the bottom of the Valles Marineris would be a good spot for a permanent colony. [...] but could be imported by pipeline from a base at the north pole or synthesized with imported hydrogen and oxygen from the atmosphere.
That's a long way to build a pipeline, for that level of resource expenditure you can use the piping material more efficiently.
As far as digging in for shielding, you can do that anywhere. Just dig down or pile up loose debris. Also importing hydrogen would be another issue...(why go to Mars if you have to import your hydrogen, just build in the asteroid belt.)
I don't think you're wrong about Valles Marineris, just about the solutions. I think trucking in ice might be more practical until exploration uncovered nearer sources. One could design a robotic truck with a crusher conveyer to dig into the ice and then compact to refreeze the results into unit blocks. Stack 'em and haul 'em out. This could be done remotely prior to manned landings so there's a guaranteed startup supply. Once on site any hiccups in supply could be resolved without it being a desperate situation.
I think one of the most pressing questions is, how will settlers on Mars grow food? It can't be sustainable to have to constantly ship in foodstuffs for more than a few settlers.
Better yet...Europa. It's the most earthlike place in the solar system.
You mean 2nd most Right? ; )
I'd suggest a supply chain of ramscoop robots visiting the gas giants to mine for materials that
could be used at the base.
Obviously it would take a while to get the first supply but it would be interesting to see what you get
and could do with it. (I have a lot of faith in chemists and engineers)
I suspect this might be a good way to avoid the gravity well issue at least to some degree?
Related to Manned Mission to Mars: Ideal Locations for Exploration
1. What is the ideal location on Mars for a manned mission?
The ideal location for a manned mission on Mars would depend on the specific goals and objectives of the mission. However, some potential locations that have been suggested by scientists include the Valles Marineris region, which is a massive canyon system that could provide valuable geological and mineralogical information, and the Elysium Planitia, which is a large, flat plain that may have once been a lake bed and could hold clues about past water and life on Mars.
2. What are the main challenges of sending humans to Mars?
The main challenges of a manned mission to Mars include the long distance and travel time, which could take anywhere from 6 to 9 months, exposure to high levels of radiation, and the need for self-sustainability and self-sufficiency on the planet due to the lack of resources and support from Earth. Additionally, the psychological and physical effects of living in a confined and isolated environment for an extended period of time must also be considered.
3. How do scientists determine the safety of a potential landing site on Mars?
Scientists use a variety of methods to assess the safety of a potential landing site on Mars. These include analyzing data from orbiters and rovers to gather information about the terrain and environmental conditions, conducting simulations and tests on Earth to replicate the conditions on Mars, and studying the history and geology of the area to understand any potential hazards.
4. What are the potential benefits of a manned mission to Mars?
A manned mission to Mars could bring numerous benefits, including expanding our understanding of the Red Planet and its potential for past or present life, testing and advancing new technologies and systems for space travel and exploration, and serving as a stepping stone for future missions to other planets. It could also inspire and engage the public in the exploration of space and potentially lead to new discoveries and advancements in science and technology.
5. How can we ensure the safety of the astronauts during a mission to Mars?
Ensuring the safety of astronauts during a mission to Mars requires careful planning and preparation. This includes thorough risk assessments and contingency plans, providing proper training and support for the crew, developing advanced technologies for radiation protection and life support systems, and maintaining constant communication and support from Earth. Additionally, having a well-planned and well-equipped mission control team is crucial for monitoring and addressing any potential issues that may arise during the mission.
