Does New Research Disprove Heisenberg's Uncertainty Principle?
  • Thread starter d3mm
  • Tags
    Hup News
In summary, the article claims that the original formulation of the uncertainty principle (which is incorrect) is not violated by weak measurements.
d3mm
140
BBC NEws Story "refuting" HUP
http://www.bbc.co.uk/news/science-environment-19489385
Pioneering experiments have cast doubt on a founding idea of the branch of physics called quantum mechanics. The Heisenberg uncertainty principle is in part an embodiment of the idea that in the quantum world, the mere act of observing an event changes it. But the idea had never been put to the test, and a team writing in Physical Review Letters says "weak measurements" prove the rule was never quite right.
I did a double take when I read this, can someone please explain what it's all about?
I took the important sentences from the full article:
The modern version of the uncertainty principle proved in our textbooks today, however, deals not with the precision of a measurement and the disturbance it introduces, but with the intrinsic uncertainty any quantum state must possess, regardless of what measurement (if any) is performed. These two readings of the uncertainty principle are typically taught side-by-side, although only the modern one is given rigorous proof. It has been shown that the original formulation is not only less general than the modern oneit is in fact mathematically incorrect...
Our work conclusively shows that, although correct for uncertainties in states, the form of Heisenberg's precision limit is incorrect if naively applied to measurement. Our work highlights an important fundamental difference between uncertainties in states and the limitations of measurement in quantum mechanics.
So, while the uncertainty coming from the disturbing influence of the measurement is smaller than Heisenberg's original formulation , the uncertainty principle itself remains valid (e.g. there is an intrinsic uncertainty any quantum system must possess).
hereafter "Uncertainity Relation"
It's about WEAK measurement, not ordinary measurement. Weak measurement determines only an AVERAGE value, not the actual value. For example, by weak measurement you can measure exactly average momentum at a given position, but not exact momentum at a given position. Therefore, HUP is not violated.
See also
https://www.physicsforums.com/blog.php?b=1225
https://www.physicsforums.com/blog.php?b=1226
https://www.physicsforums.com/blog.php?b=3077
We already have threads on this, here and here.
Related to Does New Research Disprove Heisenberg's Uncertainty Principle?
1. What is the BBC News story about refuting HUP?
The BBC News story is about a recent study that claims to have found evidence contradicting the Heisenberg Uncertainty Principle (HUP), a fundamental principle in quantum mechanics.
2. What is the Heisenberg Uncertainty Principle (HUP)?
The HUP is a principle in quantum mechanics that states that it is impossible to know both the position and momentum of a particle with absolute certainty. This is due to the inherent uncertainty and randomness of quantum particles.
3. How does the study refute the HUP?
The study argues that by using a new measurement technique, they were able to measure the position and momentum of a particle simultaneously, which goes against the HUP. However, many experts in the field have questioned the validity of the study's results and methodology.
4. What is the scientific community's response to the study?
The scientific community has largely rejected the study's findings and continues to uphold the HUP as a fundamental principle in quantum mechanics. Many experts have pointed out flaws in the study's methodology and argue that the results are not reproducible.
5. What does this mean for our understanding of quantum mechanics?
While the study may have sparked some debate, it does not significantly challenge our understanding of quantum mechanics. The HUP has been extensively tested and confirmed by numerous experiments, and the scientific community continues to use it as a fundamental principle in their research.
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
