Is the derivative equal to one over the derivative of the inverse?
In summary, it is true that (dy/dx) = 1/(dx/dy) for inverse functions, as long as they are both defined. This may not make sense for partial derivatives, but for implicit functions, it can be proven using the chain rule. However, for partial derivatives, it depends on the specific variables involved in the function.
Crosson
1,259
Is it true that (dy/dx) = 1/(dx/dy) ? Is it still true if these are partial derivatives of a function of multiple variables? (All this, assuming that the inverse function exists)
Can anybody prove it in terms of the definition of a derivative? or any sort elementary proof at all? (I can almost convince my self it is true with Linear Algebra).
I haven't seen it proven in any books, but it is true for all of the functions I know of. Can I get a definitive answer?
yes, dy/dx= 1/(dx/dy), when both are defined.
It doesn't make sense to ask about it for partial derivatives in the manner you do.
Suppose that y=f(x) implicitly defines y as a function of x. differentiate both sides wrt y
1 = df(x)/dy
apply the chain rule
1= (dx/dy) (df/dx)
or
1= (dx/dy)(dy/dx)
For partials you'd need to be more specific, are x and y both variables of this functions, or is, y=f(x,z,w...) the thing you're after? You can apply what I did above in the partial case for the second type.
The statement that the derivative of a function is equal to one over the derivative of its inverse is not always true. This only holds for functions that are invertible and have a well-defined inverse function.
For a one-variable function, the statement can be written as: (dy/dx) = 1/(dx/dy). This is only true for functions that are one-to-one, meaning that each input value corresponds to a unique output value. In this case, the inverse function exists and the statement holds true.
However, for functions that are not one-to-one, the inverse function may not exist or may not be well-defined. In this case, the statement is not true.
This also applies to partial derivatives of functions with multiple variables. The statement (dy/dx) = 1/(dx/dy) is only true if the function is invertible and has a well-defined inverse function. Otherwise, it does not hold.
To prove this statement, we can use the definition of a derivative. The derivative of a function f(x) at a point x=a is defined as the limit of the difference quotient as h approaches 0:
f'(a) = lim(h->0) (f(a+h) - f(a))/h
Similarly, the derivative of the inverse function g(x) at a point x=b is defined as:
g'(b) = lim(h->0) (g(b+h) - g(b))/h
Now, if we let h = 1/f'(a), we can rewrite the first equation as:
f'(a) = lim(h->0) (f(a+1/f'(a)) - f(a))/1/f'(a)
Using the definition of the inverse function, we can replace f(a+1/f'(a)) with g(f(a)):
f'(a) = lim(h->0) (g(f(a)) - f(a))/1/f'(a)
Now, we can substitute this into the second equation:
g'(b) = lim(h->0) (g(b+h) - g(b))/h = lim(h->0) (f(a+1/f'(a)) - f(a))/1/f'(a) = f'(a)
Therefore, we can conclude that g'(b) = f'(a) = 1/(f'(a)), which proves the statement for invertible functions.
In conclusion, the statement (dy/dx) = 1/(dx/d
Related to Is the derivative equal to one over the derivative of the inverse?
Is the Derivative Equal to One over the Derivative of the Inverse?
The relationship between a function and its inverse, as well as their derivatives, is a topic in calculus that can be explored. Understanding whether the derivative of a function is equal to one over the derivative of its inverse is a common question. Here are some frequently asked questions related to this concept:
Q1: What Is the Inverse of a Function?
The inverse of a function is another function that undoes the action of the original function. If \(f(x)\) is a function, its inverse is denoted as \(f^{-1}(x)\), and it satisfies the property that \(f(f^{-1}(x)) = x\) for all valid values of \(x\). In other words, applying \(f^{-1}\) to the output of \(f\) returns the original input.
Q2: What Is the Derivative of a Function?
The derivative of a function measures its rate of change at a specific point. It provides information about how the function's output (dependent variable) changes concerning its input (independent variable). The derivative of a function \(f(x)\) is denoted as \(f'(x)\) or \(\frac{df}{dx}\).
Q3: Is the Derivative of a Function Inversely Related to the Derivative of Its Inverse?
No, in general, the derivative of a function is not equal to one over the derivative of its inverse. This is a common misconception. The derivatives of a function and its inverse are related, but they are not simply reciprocals of each other.
Q4: What Is the Relationship Between the Derivatives of a Function and Its Inverse?
The relationship between the derivatives of a function and its inverse is given by the following formula: \[f'(x) = \frac{1}{f^{-1}'(f(x))}\] Here: - \(f'(x)\) is the derivative of the original function \(f(x)\). - \(f^{-1}'(f(x))\) is the derivative of the inverse function \(f^{-1}(x)\) evaluated at the point \(f(x)\). This formula shows that the derivative of the original function is related to the derivative of its inverse through the composition of functions. It is important to note that this relationship holds at specific points where the functions are differentiable.
Q5: When Does the Relationship Between Derivatives Apply?
The relationship between the derivatives of a function and its inverse applies when both the function \(f(x)\) and its inverse \(f^{-1}(x)\) are differentiable at the point of interest. In other words, the functions must have well-defined derivatives at that specific point for the relationship to hold.
In summary, the derivative of a function is not equal to one over the derivative of its inverse in general. However, there is a specific relationship between these derivatives given by a formula that involves the composition of functions. This relationship applies when both functions are differentiable at the point of interest.
