Spacetime diagrams: ct axis and time contraction and length dilation
In summary, according to the two postulates of special relativity, moving clocks run slower in an inertial frame of reference than clocks that are at rest.
RadiantL
32
Hi, this isn't really a homework problem... but I'm just wondering
I see the time axis as c*t, now people say that its to scale the time axis so that the world line of light is 45 degrees. But if you were to multiply time by the speed of light, wouldn't you just get the units metres or.. light years, a measurement of length not time? How can you still say that the axis represents time?
Also another question, is it possible to show both time dilation and length contraction on one spacetime diagram?
On grid paper (squares grid) the t axis would look similar to what you are used to. Let's say you mark 1 second per 2 squares up. 2 seconds would be at the 4th square up and so on...
The x-axis, you would use light-seconds. Each two squares would be 1 light-second. 4 squares 2 light-seconds and so on...
Light travels at about 300000km/s. This means that one light-second is 300000km. So instead of using 1 light-second, you could write 300000km, 600000km and so on... but using light-second i guess is more elegant.
If you scale your diagram as stated above, light-beams inside that diagram will necessarily have a gradient of 45° or otherwise said, for each square you move left/right on your grid paper, you move 1 square up/down.
You would have to take this drawing
and extend the two diagrams towards the bottom (negative t). Then get the light-beams going from E0/E0' to cross the blue lines(you also extend towards the bottom).
Call the events E3/E3' and E4/E4'.
What you want to get is a formula which let's you see by which factor MOVING clocks would run slower, seen from an observer in an inertial frame of reference, compared to clocks being at rest inside the observer's frame.
All clocks following the blue line in system A, are moving at vrel = 0.5c in system A. In system B, they are at rest.
getting the Δt/Δt' between E1/E3 and E1'/E3'
Do the same for system B. This time we need a clock which moves at vrel=0,5c relative to an observer being at rest in system B. This would be the green line. After extending the diagram to the bottom along with the green line, cross some light-beams that go through E0' with the green lines.
E5/E5' and E6/E6' where the beams cross the green lines.
get the formulas for the Δt2/Δt2' and you should be able to solve similar to how i solved for the length contraction.(you only need either E3/E3'/E5/E5' OR alternatively E4/E4'/E6/E6' to arrive at the formulas)
Just remember that because of one of the two postulates of SR:
"The laws of physics are the same in all inertial frames of reference." implying that,
by whatever factor (γ) Δt is modified to arrive at Δt' using Δt * γ = Δt'
the same is true the other way around Δt2' * γ = Δt2I hope this is good enough to get you started. The description is sloppy but that is because it's harder to imagine than measuring distances with rulers. The clocks here are used just like rulers, to measure time-frames. But before i fry my brain, trying to explain this further, i am out of here.Warning: I call the two postulates, Axioms. Postulates is the better term here i believe. Also, the factor γ i use is inverse to the γ you will find on Wikipedia. This is because of the way i derived the formula, where using γ that way made perfect sense.
If you substitute γ in my formulas with sqrt(1-(v^2/x^2)), you arrive at the same formulas as Wikipedia does, so there is not really anything wrong here other than maybe not going by the standard or being a carbon copy of Wikipedia.
Also noteworthy. The numbering of the two Axioms/Postulates of SR as i used it, is flipped compared to how Wikipedia has it. You might want to change that in your derivation to be more in accord with the standard. Again, it seemed more reasonable to me to flip this, and goes along to how i derived it as i used, light always traveling at C in a vacuum absent of gravity seen from any arbitrary inertial reference frame, for the first part of my derivation.
I can provide some insight into the questions you have raised about spacetime diagrams and the representation of time dilation and length contraction.
Firstly, the ct axis on a spacetime diagram does indeed represent time. The reason for multiplying time by the speed of light is to account for the fact that in the theory of relativity, the speed of light is constant and is the same for all observers. This means that in a spacetime diagram, the world line of light will always be at a 45 degree angle, regardless of the observer's reference frame. By scaling the time axis in this way, we are able to accurately show the relationship between time and space in the theory of relativity.
Regarding your question about showing both time dilation and length contraction on one spacetime diagram, the answer is yes, it is possible. In fact, spacetime diagrams are often used to illustrate the effects of time dilation and length contraction in special relativity. The key is to use different reference frames for each phenomenon. For example, you could have one reference frame representing an observer at rest, and another representing an observer moving at a high velocity relative to the first. By comparing the two frames, you can see the effects of time dilation and length contraction on the same diagram.
In conclusion, spacetime diagrams are a powerful tool for understanding the relationship between time and space in the theory of relativity. By scaling the time axis with the speed of light, we can accurately represent the effects of time dilation and length contraction. And yes, it is possible to show both of these effects on one diagram by using different reference frames. I hope this helps to clarify any confusion you may have had about spacetime diagrams.
FAQ: Spacetime diagrams: ct axis and time contraction and length dilation
What is a spacetime diagram?
A spacetime diagram is a graphical representation of the relationship between space and time, typically used in physics and astronomy. It is often used to visualize the effects of special relativity, such as time dilation and length contraction.
What is the "ct" axis on a spacetime diagram?
The "ct" axis on a spacetime diagram represents the time coordinate, where "c" is the speed of light and "t" is the time elapsed. The ct axis is typically plotted vertically on a spacetime diagram, with time increasing as you move upwards.
What is time dilation on a spacetime diagram?
Time dilation is a phenomenon in which time appears to pass slower for an object or observer moving at high speeds relative to another object. This effect is represented on a spacetime diagram by the ct axis becoming longer, indicating that more time has passed for the moving object compared to the stationary one.
How is length dilation shown on a spacetime diagram?
Length dilation, also known as length contraction, is a concept in special relativity where an object appears to be shorter when viewed from a reference frame in which it is moving at high speeds. On a spacetime diagram, this is represented by the space axis (often labeled as "x" or "d") becoming shorter in the direction of motion.
Can spacetime diagrams be used to explain time travel?
Spacetime diagrams can be used to illustrate the theoretical possibility of time travel, as they show how time and space are interconnected and can be distorted by high speeds and gravity. However, they do not necessarily prove the existence or possibility of actual time travel.
