Work Done ON or BY the System [Conceptual Question]
In summary, during the combustion experiment, heat has been transferred from the system to the surroundings, and work has been done ON the water bath BY the system. The sign of ΔU for the system is negative, meaning that the internal energy has decreased. As for part d), the heat of combustion (energy released per gram) of the fuel can be calculated by dividing the observed increase in temperature of the water bath by the mass of the fuel used.
CallMeShady
45
A student performs a combustion experiment by burning a mixture of fuel and oxygen in a constant-volume metal can surrounded by a water bath. During the experiment, the temperature of the water is observed to rise. Regard the mixture of fuel and oxygen as the system.
a) Has heat been transferred to/from the system? How can you tell?
b) Has work been done by/on the system? How can you tell?
c) What is the sign of ΔU of the system? How can you tell?
d) 1g of fuel is placed in the can for combustion. During combustion, the 200mL water bath is observed to increase in temperature by 35.5°C. What is the heat of combustion (energy released per gram) of the fuel?
ΔU = Q - W
where ΔU = change of internal energy in system, Q = heat gained by system, W = work done on the surrounding BY the system.
Now I know that for part a), heat has been transferred from the system, as the temperature of the water bath rises (meaning, heat has been transferred from the system to the surroundings). However, I am a little confused about part b). I am not sure if the work is done by the system or not. I am guessing, since the metal can is at constant-volume, no work has been done, but I may be wrong. Please correct me if I am wrong.
I am stuck at this point. I can't attempt the other parts of the problem unless I understand part b).
Thank you.
Your understanding of b) is correct.
and
The unit of work is the Joule. Work is done whenever energy is exchanged. Heat is measured in Joules. The chemical energy of the contents of the can is reduced. The heat energy of the water jacket increases. Work has been performed by the system on the water.
Imagine pushing a box.
Work is done ON the box, but BY who? Ya, BY you.
You are exerting kinetic energy towards the box to make it move :)
Imagine putting food into oven.
Work is going to be done ON the food (To cook it) BY the oven.
Note: There is only heat energy, no "cold" energy.
So when it comes to a fridge, heat energy is being transferred from the food to the fridge. Work done by the food :D
I would like to clarify that the concept of work being "done by" or "on" the system can be confusing, and it is important to understand the difference between the two. In thermodynamics, work is defined as the energy transferred to or from a system due to a force acting on it. Therefore, work done "by" the system refers to the system doing work on its surroundings, while work done "on" the system refers to the surroundings doing work on the system.
In this particular experiment, the system is the mixture of fuel and oxygen, and the surroundings are the metal can and water bath. Since the metal can is at constant volume, no work is being done on or by the system. The only type of work in this scenario is pressure-volume work, which involves changes in volume, and since the volume is constant, there is no work being done.
Regarding part c), the sign of ΔU for the system would be negative, as heat is being transferred out of the system to the surroundings, resulting in a decrease in internal energy.
Finally, to solve part d), we can use the equation Q = mCΔT, where Q is the heat gained by the water, m is the mass of the water (200g), C is the specific heat capacity of water (4.186 J/g°C), and ΔT is the change in temperature (35.5°C). This will give us the total heat released by the fuel during combustion. To find the heat of combustion per gram of fuel, we can divide this value by the mass of fuel (1g) to get our final answer.
FAQ: Work Done ON or BY the System [Conceptual Question]
1. What is meant by "work done on or by the system"?
Work done on or by the system refers to the transfer of energy into or out of a physical system. It can be caused by forces acting on the system or by changes in the system itself.
2. How is work calculated in this context?
In this context, work is calculated as the product of the force applied on the system and the displacement of the system in the direction of the force. It is typically measured in joules (J).
3. What is the difference between work done on the system and work done by the system?
Work done on the system refers to energy being transferred into the system, while work done by the system refers to energy being transferred out of the system. This can be seen as the system gaining or losing energy, respectively.
4. How does the concept of work done on or by the system relate to the laws of thermodynamics?
The concept of work done on or by the system is closely related to the first law of thermodynamics, which states that energy cannot be created or destroyed, only transferred or converted from one form to another. In this case, work is a way of transferring energy into or out of the system.
5. Can you give an example of work done on or by the system?
One example of work done on or by the system is a car accelerating on a flat road. In this scenario, the car's engine is applying a force on the car, causing it to move forward and do work on the car. At the same time, the car is also doing work on the road by applying a force on it in the opposite direction.
