ianhoolihan
- 145
Hi all,
I'm a part III student and taking the QFT course. The following seems "trivial" but when I went and asked the lecturer, the comment was that they too hate such nitty gritty details!
The problem is page 12 of Tong's notes: http://www.damtp.cam.ac.uk/user/tong/qft/one.pdf
All we're doing is waking an active transformation of a scalar field ##x\to x'=\Lambda x## such that ##\phi(x)\to\phi'(x) = \phi(\Lambda^{-1}x)##. Correct me if I'm wrong, but an active rotation in this sense means we keep the axis fixed, and rotate the field. (Q1: if we're not changing the axis, what then does ##x\to x' = \Lambda x## even mean?) I can accept why the ##\Lambda^{-1}## appears, but I think this is a more accurate formulation:
$$\phi(x) \rightarrow \phi'(x') = \phi (\Lambda^{-1} x') = \phi (x) $$
So the previeus statement should really be ##\phi(x)\to\phi'(x') = \phi(\Lambda^{-1}x')##. (I.e. I've taken ##\phi' = \phi \circ \Lambda^{-1}## in some sense.) It's equivalent to the former, except one has now taken ##x## to mean ##x'##, which I think confuses the (following) situation.
Onto derivatives. The statement given is simply that
$$(\partial_\mu \phi)(x) = (\Lambda^{-1})^\nu{}_\mu (\partial_\nu \phi) (y).$$
My first problem is that things are undefined --- is ##\partial_v## on the right ##\partial /\partial x^\nu## or ##\partial / \partial (x')^\nu## or ##\partial / \partial y^\nu##?
I have two different approaches to this:
A:
$$\partial_\mu \phi (x) \rightarrow \partial_{\mu'} \phi'(x') = \frac{\partial x^\nu}{\partial x^{\mu'}}\partial_\nu \phi(\Lambda^{-1}x') =(\Lambda^{-1})^\nu{}_{\mu'} \partial_\nu \phi(\Lambda^{-1}x')$$
where all I've done is change coordinates of the partial derivative. I was going to say that my problem would then that if I evaluated the derivative, I'd get another ##\Lambda^{-1}## from tho chain rule, but that would only have been if I hadn't used the more correct notation of ##x'## instead of ##x## in ##\phi(\Lambda^{-1}x')##. This is, of course,##\phi(x)##, so evaluating the derivative involves no chain rule. Hence, by this method,
$$\partial_\mu \phi (x) \rightarrow \partial_{\mu'} \phi'(x') = (\Lambda^{-1})^\nu{}_{\mu'} \partial_\nu \phi(x)$$
This is similar to Tong's notes (##\partial_\nu \phi(x) = (\partial_\nu \phi)(x)## as no chain rule) except that I have an ##x## instead of a ##y## in the final term.
B.
The next approach is to use the chain rule, and assuming that ##\partial_\mu \to \partial_\mu## i.e. the coordinate basis of differentiation does not change, and ignore my prior statements about ##x## versus ##x'## (which may have been incorrect). Then, letting ##y= \Lambda^{-1} x##,
$$\partial_\mu \phi (x) \rightarrow \partial_\mu \phi(y) = \partial_\mu y (\partial_\mu \phi) (y) = (\Lambda^{-1})^\nu{}_\mu (\partial_\nu \phi) (y)$$
where I mean ##(\partial_\nu \phi) (y)## in the sense of ##d f (g(x)) = d (g(x)) f' (g(x))##. This seems OK, except that it goes against some of my statements previously, and I'm also not sure if Tong means what I do by ##(\partial_\nu \phi) (y)##.
I'd much appreciate a few quick comments on which scheme is correct, or, indeed, if both are wrong! I'm on the A-team...
Cheers.
A:
B.
Cheers.
