Is asymmetric time dilation in twin paradox possible in SR?
In summary, the conversation discusses the question of whether or not special relativity can explain the observed time dilation in experiments like the GPS satellite or Bailey et. al. The conversation presents the scenario of twins in space, with one twin traveling at high velocity and then returning to the original location. The conversation also mentions the explanations based on the traveling twin not being in an inertial frame at all times, but finds them inconclusive. The conversation then raises the question of how special relativity can predict whose clock will record a longer passage of time in this experiment. Finally, the conversation discusses the idea that the traveling twin sees a change in the tick rate of the stationary twin's clock immediately, but this is cancelled out by the time dilation effect.
arindamsinha
181
I am trying to understand if SR can explain a real, measurable velocity time dilation as seen in experiments/observations like GPS satellite or Bailey et. al.
Let us say we have twins sitting in their identical, individual spaceships in space, close to each other, and far away from any large masses. One of them fires his engine and goes some distance at high velocity, reverses, and comes back to the original location. Would he really have aged less than the stationary twin, and if so why?
I have seen the explanations based on the traveling twin not being in an inertial frame at all times, but do not find them conclusive. I mean, from SR perspective, when the traveling twin is accelerating, he may consider from his point of view that the stationary twin is in a non-inertial frame, while he is in an inertial one. Since there is no third party observer involved, each twin should be entitled to expect that the other has aged less by a specific amount (as per SR formula).
I am thinking that the traveling twin feeling acceleration should not differentiate between the twins from an SR perspective, since we cannot consider the acceleration asymmetrically (i.e. both twins are identically accelerating or in uniform motion w.r.t. each other at all times, from SR perspective).
So, how would SR predict correctly whose clock will turn out to have recorded a longer passage of time if this is a real experiment?
ghwellsjr said:
Let me guess: you haven't bothered to read any other threads on this subject, such as this recent one:
Wrong guess, but good point. I am unable to convince myself with the reasonings given.
What I am trying to state here is that when we are talking about 'traveling', 'reversing', or 'returning', it is happening symmetrically to each twin in the other's frame of reference, and there is no third party frame of reference which can arbitrate to break this symmetry. There is no absolute 'velocity' or 'acceleration' in SR, only relative.
If you look at the original postulates of SR, there is nothing that states that a so-called unilateral acceleration breaks this symmetry, as an acceleration cannot be unilateral in SR without breaking the basic tenets of the theory itself. If an acceleration provides a certain instantaneous velocity at every point in the path of one twin, it provides the same symmetrically to that of the other twin - since we have no reason to see things 'preferentially' from the point of view of either of them.
You said in your first post that the traveling twin feels the acceleration. The one that fires his rockets is the one that accelerates.
But beyond that, if you look at my posts in the linked thread, you will see that the Doppler analysis answers your question without regard to any frames at all. While they are departing, they each symmetrically see the other ones clock ticking more slowly than their own by the same amount. This continues for as long as they both remain at a constant speed and without regard to which one originally fired his rockets. But as soon as one of them fires his rockets after they are separated by some distance, he is the only one that immediately sees a change in the tick rate of the other twin's clock. The other twin will not see that change until some time later. Is that so hard to grasp?
'Feeling' acceleration is not a differentiator based on SR postulates. It matters only in GR.
As for the second part, there are two issues:
- The first firing of the rocket doesn't make a difference, but the second one does? Apparently this is because there is some spatial distance between them in the second case. I do not see anything in SR that says that such a spatial distance matters from a symmetry perspective
- This is important - the traveling twin sees the other's tick rate change immediately while the stationary one sees such a change later by Doppler effect and speed of light delay - granted. But note that since time is slowed down for the traveling twin, he also sees the other's clock tick 'faster' for a 'shorter' period of time by his clock - effectively cancelling out any difference! (Before you ask, I have not seen this in any reference, just my own logic, so certainly open to criticism, but think about it)
Why do you think that? What ever time it took according to his own clock for the traveling to get to his turn around point is exactly the same amount of time that it takes for him to get back, assuming that he is traveling at the same speed in both directions.
You've just granted that the situation is not symmetrical for both twins--something that you did not recognize until now. Why do we need to consider this any more?
Think about it this way
- stationary twin: faster clock, so more elapsed time by his clock, before the traveling twin come back
- traveling twin: slower clock, so less time elapsed by his clock, before he gets back
This is as per SR only. We cannot say that the clock of one slows down (the traveling twin's), and then interpret the results based on one preferred clock (the stationary twin's). I feel the two effects cancel out, so when they meet again, their clocks will be in synch.
Interested to hear your views on this.
See the logic after that statement. It is not a simple asymmetry, but reciprocal.
Ok, what's the problem? They both agree the traveling twin's clock accumulated less time.
If you want to analyze this according to SR, then you can pick any Inertial Reference Frame (IRF) because, as you pointed out, none is preferred. In the first quote, you were using the IRF of the stationary twin. There's nothing wrong with that and you got the right answer. I don't know why you then "feel the two effects cancel out". Once you analyze the situation from one IRF, there is no need to use any other IRF, they will all produce the same result.
These are not my views, they are Einstein's.
How? As I see it: (faster clock)/(longer time by fast clock) = (slower clock)/(shorter time by slow clock) = same clock tick-rate. No? Perhaps I am explaining this badly :-(
Oops! I meant on my logic, not on SR! :-)
Let's say the speed of the traveling twin is 0.6c. That means the time dilation factor is 0.8. And let's say the traveling twin is gone for ten years according to the stationary twin. That means the traveling twin's clock will advance by eight years. Is this how you see it:
faster clock = 1
longer time by fast clock = 10
slower clock = 0.8
slower time by slow clock = 8
So 1/10 = 0.8/8 = 0.1
What's the problem?
This is false, and is the key error that leads to your further incorrect conclusions.
The common definition of an inertial frame is a frame where accelerometers at rest everywhere read 0. Clearly by this definition the accelerating twins frame is non inertial, since accelerometers at rest in the cockpit read non-0 values.
A closely related definition is that an inertial frame is one where objects not subject to external forces travel in straight lines at constant speed. The accelerating twins frame is non inertial by this definition since if he drops something in his cockpit it accelerates to the floor.
An approximate definition of an inertial frame is one where the distant fixed stars are not accelerating (note, I don't like this definition since it is only an approximation). The accelerating twins frame is non inertial by this approximate definition since the distant fixed stars are accelerating on average in his frame.
AFAIK, there is no definition of an inertial frame which would entitle the accelerating twin to consider his frame to be inertial. If you disagree then please explicitly post the definition and clearly show how it applies. Otherwise, stop repeating this demonstrably false assertion.
Even post #104
https://www.physicsforums.com/showthread.php?t=642784&page=7
and post #159 ??
https://www.physicsforums.com/showthread.php?t=642784&page=10
:eek:
Did you read any of the references?
What I am trying to state here is that when we are talking about 'traveling', 'reversing', or 'returning', it is happening symmetrically to each twin in the other's frame of reference [..]
As you are talking about SR, that is wrong as I explained in those posts; you mix up SR with GR.
In that thread I explained in posts #188 and #190 (my explanation) as well as #264 (Einstein's explanation) what frames SR uses for the physics.
Oh and one more, essential thing:
I guess that your "feeling" is not based on calculation... did you actually try? If you didn't, then we can talk endlessly without getting anywhere.
But in case you did try, please show us your calculation and we can show you where you made a mistake. :smile:
arindamsinha said:
...There is no absolute 'velocity' or 'acceleration' in SR, only relative.
Acceleration is not relative. It is possible to distinguish a state of accelerated motion from a state of uniform motion. This means that if one twin accelerates it is possible to distinguish them.
But it is not acceleration per se that causes the differential ageing - it is the different proper lengths of the paths.
I don't understand why you think that. It's just wrong. In SR, there is a privileged collection of trajectories, the inertial trajectories. If a twin is not following an inertial trajectory, then he is accelerated. There is no ambiguity about whether a trajectory is accelerated or not.
Thanks for all the responses, guys. They are definitely helpful in furthering the thoughts.
As I mentioned earlier, I may not have been able to explain very well the points I am trying to make. My responses below are an attempt to explain my thoughts better. It is not meant to oppose any of the opinions provided, and does not mean I am ignoring the opinions in the threads I am not specifically responding to.
Request you to please read this post completely to understand my reasoning, before responding to any specific points.
Sorry, my original thoughts had got derailed just around here.
What I meant was this - on the outward trip, there is no difference between the observations of the two twins based on Doppler effect. This is fine. Only when the traveling twin reverses course does he see the other twins clock rate suddently getting faster based on Doppler effect. However, this is an effect that will be seen even without considering relativity, as long as we consider only one twin to be traveling.
My objection to this is:
  • In the postulates of SR, relative velocity is common to both observers. Acceleration in no more than a set of different values of instantaneous relative velocities between them. Why should we then attribute the acceleration to one and not the other? I do not see anything in the postulates of SR or derivation of the equations that allows a 'physical feeling of acceleration' or looking at it from 'one preferentially "at rest" observers point of view' to justify this. From what I have gathered, these explanations were added later on to resolve paradoxes within SR framework, and justify asymmetrical time dilation observed in experiments, but do not follow from the postulates and derivation of SR theory.
  • The additional fact is that the traveling twin's clock will jump back by a certain amount at the point of reversal, i.e. he will travel into the past instantaneously. This is another part I am finding hard to digest.
Nowhere in the derivation of SR is the above 'common defintion' of inertial frames, or even the concept of acceleration used. The only definition of inertial frames used in the derivation is 'two systems of coordinates in uniform translatory motion'.
Other definitions of inertial frames (like the above) were introduced much later to resolve SR paradoxes and explain asymmetrical time dilation observed in experiments.
Going by the postulates of SR, each twin will be entitled to equally consider the other twin to be in a non-inertial frame, or in other words, to have different but reciprocal/symmetric instantaneous relative velocities over time.
This is what I really am trying to get at in this topic. Acceleration is not relative, but velocity is? Again going back to the postulates of SR, the only way we can consider acceleration is different instantaneous 'relative velocities' over a period of time, and that applies symmetrically to both observers. If we can assign acceleration to one but not the other observers in question, we can extend the same logic down to velocity, and say that velocity is also not relative. I strongly believe these are not part of original SR theory, but 'borrowed and retrofitted' into it from GR and experimental observations, to keep SR consistent and to explain paradoxes.
In fact, when GR is applied to situations like GPS satellite time dilation, note that velocity is not taken as the 'relative velocity' between Earth surface and satellites, but from the CG of the system (or ECIF actually), which is absolutely in agreement with observations and experiments.
Why do we need to force such absurd logic into SR to somehow or the other explain 'within the framework' some solution for paradoxes and experimental observations, when clearly GR has encompassed all of SR and given a clearer picture of how physics works in the Universe?
In summary, let me quote Einstein' thoughts that inspired me to start this thread in the first place:
"... according to the general theory of relativity, the law of the constancy of the velocity of light ... cannot claim any unlimited validity. A curvature of rays of light can only take place when the velocity of propagation of light varies with position ... the special theory of relativity cannot claim an unlimlited domain of validity... No fairer destiny could be allotted to any physical theory, than that it should of itself point out the way to the introduction of a more comprehensive theory, in which it lives on as a limiting case."
So, are we trying too hard to resolve within SR inconsistencies and paradoxes that are outside the domain of validity of the theory itself, instead of looking at the more general theory for the proper explanations?
I will rephrase my original question as:
"Is asymmetric time dilation in twin paradox possible in SR, or should we really look to GR for such an explanation?" (Asymmetrical time dilation = actual experimental clock time dilation)
Yes, even with sound when the traveler reverses direction, he observes an increase in the pitch of the sound coming from a remote stationary source. However, the Doppler factors for going and coming are not reciprocals like they are for light and that is what makes the difference. You really should read up on your subject matter before you present these false notions.
The Twin Paradox was introduced by Einstein in his first paper on Special Relativity in 1905 at the end of section 4. It involved a continuously accelerating clock traveling in a circle and reuniting with a stationary clock and running slower than the stationary clock. Einstein didn't call this a paradox (because it isn't) but he did show the asymmetrical time dilation right from the very beginning of his theory. It wasn't something added later.
You should find that hard to digest because it isn't true. Where'd you get such a strange notion from?
The rest of your thread shows a complete lack of regard for all the help you have been given by so many people on this thread. All your questions have been previously answered. Go back and read what has already been offered to you instead of just repeating your unsubstantiated claims.
This was answered previously in my reference to Einstein's paper. Yes, of course we can understand the twin paradox with SR (that's where it was introduced) but you can also get an explanation from GR if you want.
Physicist Max Born, a colleague and good friend of Albert Einstein, wrote that “the clock paradox is due to a false application of the special theory of relativity.” Wolfgang Pauli says of the paradox in his brilliant (according to Albert E.) 1921 treatise on relativity, “Of course, a complete explanation of the problem can only be given within the framework of the general theory of relativity.”
The issue is discussed in detail here http://mathpages.com/rr/s4-07/4-07.htm
But if you read to the end of the relevant paragraph, you will see:
In opposition to this view, some have argued that only inhomogeneous metrical fields, i.e., fields with non-vanishing curvature, should be regarded as exhibiting “gravity”, and that there is no need to invoke general relativity in the absence of curvature.
As I said, you can use GR to explain the twin paradox but if we assume the absence of gravity, you can do it just with SR as Einstein did in his 1905 paper.
arindamsinha said:
Thanks for all the responses, guys. They are definitely helpful in furthering the thoughts.[..]
Good - but it should (or at least could!) have been sufficient to bring this to an end. Everything that followed in your post was already answered several times by several people including myself, and with references again in this thread.
ghwellsjr said:
[...] The rest of your thread shows a complete lack of regard for all the help you have been given by so many people on this thread. All your questions have been previously answered. Go back and read what has already been offered to you instead of just repeating your unsubstantiated claims. [..]
Yes indeed! I now unsubscribe from both these twin paradox spin-off threads.
Oh, let me acknowledge that the responses have been very helpful, guys. It has clarified a number of things on how the SR theory is interpreted and applied. Perhaps at the cost of repetition and disagreements, I have been able to get some very good insights.
Good, now do you see that the answer to your question is "yes" and no more questions need to be asked on this thread?
Yes, I think all the responses were very helpful.
This is not correct. Those words are simply an English translation of some of Einstein's early writings. They do not limit the modern definition of the two postulates. In physics the early pioneers are respected, but not worshipped, and their words are not considered some sort of final gospel, never to be modified in any way.
The modern definition of SR, the two postulates, is very much focused on the concept of an inertial frame, despite the fact that it was not explicitly mentioned by Einstein. See any college lecture notes or textbook on SR, e.g. http://www.phys.ufl.edu/~acosta/phy2061/lectures/Relativity2.pdf
OK. This seems to destroy your own argument since you appear to realize that, now that the modern definitions of inertial frames have been introduced, they have resolved any SR paradoxes and explained the observations.
No. This is not correct. Please update your definitions, they are 107 years old now.
Also, it helps to read complete paragraphs, rather than snippets out of context. While not using the same terminology as modern writers, there is no doubt of Einstein's intent when the context is given. For example, the following is the more complete text around use of "uniform translatory mortion":
In order to attain the greatest possible clearness, let us return to our example of the railway carriage supposed to be traveling uniformly. We call its motion a uniform translation ("uniform" because it is of constant velocity and direction, " translation " because although the carriage changes its position relative to the embankment yet it does not rotate in so doing). Let us imagine a raven flying through the air in such a manner that its motion, as observed from the embankment, is uniform and in a straight line. If we were to observe the flying raven from the moving railway carriage. we should find that the motion of the raven would be one of different velocity and direction, but that it would still be uniform and in a straight line. Expressed in an abstract manner we may say : If a mass m is moving uniformly in a straight line with respect to a co-ordinate system K, then it will also be moving uniformly and in a straight line relative to a second co-ordinate system K1 provided that the latter is executing a uniform translatory motion with respect to K. In accordance with the discussion contained in the preceding section, it follows that:
If K is a Galileian co-ordinate system. then every other co-ordinate system K' is a Galileian one, when, in relation to K, it is in a condition of uniform motion of translation. Relative to K1 the mechanical laws of Galilei-Newton hold good exactly as they do with respect to K.
Note especially that last part. This shows, with absolute clarity, that Einstein was referring to inertial frames.
"In opposition to this view, some have argued that only inhomogeneous metrical fields, i.e., fields with non-vanishing curvature, should be regarded as exhibiting “gravity”, and that there is no need to invoke general relativity in the absence of curvature."
The author, Kevin S. Brown, is recognizing contrary arguments with which he does not agree.
He also admits there is 'spirited debate on this', and does not claim his view is universally accepted or even the majority view. While he has some eminent scientists sharing his view (Einstein in some writing - but not in 1905; Max Born; Pauli in 1921, but not later), he does not present more recent scientific views. The 'only SR is need to explain the twin paradox' view is pretty clearly the majority view of modern scientists. However, a lot boils down to what it means to 'explain'. SR and Galilean relativity take as an axiom there is some family of inertial frames which can be experimentally identified. An explanation of this fact is outside their purview, because it is an axiom (supported by thousands of years of observation).
Mach took as an axiom that there had to be some explanation of inertia. GR only partially, at best, explains inertia. The upshot, in my view, is that GR adds very little to the understanding because it fails to really explain inertia. It also completely fails to explain the origin of the absolute character of rotation.
[Edit: Let me explain how GR completely fails to explain inertia in any fundamental way. A spacetime that is asymptotically flat with a single rocket that can control its thrust is a solution of the EFE. This solution will be nothing but SR to any observable precision. The rocket, despite no other matter in the universe, will find that if it fires its thrust, an accelerometer inside the cabin measures acceleration; if thrust is turned off, it does not. This is exactly the state of affairs in SR and in Newtonian physics. GR has, in this trivial universe, added exactly nothing to the understanding of inertia. One thing this example does show, is that outside of mathematical abstractions, there is a clear physical distinction to non-inertial frames. You have to do something like fire a rocket, or have an electric field and be charged, etc. to undergo non-inertial motion. Ultimately, IMO, inertia remains as much a mystery now as in Newton's time. GR unified gravity and inertia, but despite Einstein's hopes, did not make any real progress explaining inertia.]
To All - the additional comments and responses are very helpful. Thanks.
PAllen said:
... GR has, in this trivial universe, added exactly nothing to the understanding of inertia. One thing this example does show, is that outside of mathematical abstractions, there is a clear physical distinction to non-inertial frames. You have to do something like fire a rocket, or have an electric field and be charged, etc. to undergo non-inertial motion. Ultimately, IMO, inertia remains as much a mystery now as in Newton's time. GR unified gravity and inertia, but despite Einstein's hopes, did not make any real progress explaining inertia.]
This is actually most interesting, and I have thought about it quite a lot. It seems an area where relativity theory seems to still have a gap - it may be consistent and predictive, but does not explain the physical principle behind one of the basic concepts it uses - the 'inertia' behind the inertial frame.
Is anyone aware of any really good and credible alternative theories about the origin of inertia?
I agree here. I think that GR uses inertia to explain gravitation, but does not explain inertia.
  • #31
What you are asking for is impossible. Inertia is part of the postulates of relativity. It is not possible for any theory to explain it's own postulates. All it can do is use its postulates to explain other phenomena. All we can ask of any theory is for it to be "consistent and predictive".
  • #32
All I asked was whether there was some other credible theory that does explain inertia. I don't think that is asking for the impossible.
Is it so wrong to even be inquisitive about the reason behind a 'postulate' of a great theory?
  • #33
I wasn't objecting to that part of your post. It is perfectly fine to look for more fundamental theories in which the postulates of less fundamental theories can be explained. However, the more fundamental theory will also have postulates that are not explained, even if it is a complete theory of everything. So having unexplained postulates does not constitute a gap in a theory and the only standard to judge theories is their being consistent and predictive. That is why I was objecting to the quoted part of your post.
Related to Is asymmetric time dilation in twin paradox possible in SR?
1. What is the twin paradox and how does it relate to time dilation in special relativity?
The twin paradox is a thought experiment that explores the concept of time dilation in special relativity. It involves two twins, one who stays on Earth and one who goes on a high-speed space journey. When the traveling twin returns, they will have aged less than the twin who stayed on Earth due to time dilation effects.
2. Is it possible for the twin paradox to result in asymmetric time dilation?
Yes, it is possible for the twin paradox to result in asymmetric time dilation. This means that the traveling twin may experience a different amount of time dilation compared to the twin who stays on Earth. This can occur if the traveling twin changes direction or accelerates during their journey.
3. How does special relativity explain the concept of asymmetric time dilation in the twin paradox?
Special relativity explains asymmetric time dilation in the twin paradox through the principles of time dilation and the relativity of simultaneity. Time dilation occurs because the traveling twin is moving at a high velocity, causing time to pass slower for them. The relativity of simultaneity means that the traveling twin may experience events at different times compared to the stationary twin due to their relative motion.
4. Are there any real-life examples of asymmetric time dilation in the twin paradox?
Yes, there are real-life examples of asymmetric time dilation in the twin paradox. One example is the Hafele-Keating experiment, where atomic clocks were flown on commercial airplanes in opposite directions around the world. The clocks that traveled eastward experienced a slightly slower rate of time compared to the stationary clocks on Earth due to their high velocities.
5. Can the twin paradox and asymmetric time dilation be observed in everyday life?
No, the effects of the twin paradox and asymmetric time dilation are only significant at very high speeds close to the speed of light. In everyday life, the differences in time dilation are too small to be observed. However, these effects have been confirmed through experiments and are important in understanding the principles of special relativity.
