Can someone me understand pH levels (Meaning mainly for certain molecule)
In summary, the conversation discusses the comparison of D2O, HDO, and H2O in terms of their pH levels and vibrational frequencies. It is mentioned that the pH of pure water does not make much sense and is not constant, but changes with temperature. The concept of pK and its relationship to pH is also brought up, as well as the difficulties in calculating and measuring these values. The idea of using deuterium to change vibrational frequencies is mentioned, but it is clarified that molecules have quantized and consistent vibrational frequencies.
nukeman
655
Hey,
I am trying to figure out some research for a department at school, and need some chemistry info.
Basically, I am comparing D2O (Heavy water) HDO (Semiheavy water) and H2O (Light water)
NOW... each of them have different pH levels.
What does that mean that they each have different pH levels?
I know the pH is the activity of the hydrogen ion. But can someone explain that a little more clear for me? :)
Does it mean they vibrate at different rates? Or what?
Thanks Chem guys and galls!
Chemistry news on Phys.org
Speaking of pH here makes little sense. However they differ in the pK_W values.
This is mainly due to there being more vibrational levels in case of the DO bond as compared to the HO bond which makes it entropically less favourable to break the DO bond.
As DrDu wrote, speaking of pH of a pure water doesn't make much sense. Even for normal (not heavy) water, it is not constant, but changes with the temperature (see the table at the water ion product page).
sorry if this is a dumb question, but if I have d2o, and by changing the temperature, do I change the frequency in which it vibrates?
It is very unlikely that in any biological experiment the pH of water matters, since the pH would be determined by whatever else is there. There are some difficulties in both calculating and measuring. Deuteroacids are less acidic than the corresponding ordinary ones (as DrDu is saying), say H3CCOOD less acid than H3CCOOH, because the dissociation rate is slower but the association rates are about the same.
If you calculate you'd have to know the pK. But if you measure you'd have to know you have to make an adjustment. http://garfield.library.upenn.edu/classics1979/A1979HZ34800001.pdf http://pubs.acs.org/doi/abs/10.1021/ac60260a013 and others.
It would tax me to be sure what pD-pH comparison really means and as frankly it is sounding to me like uninterpetrable experiments I'd tend to avoid that tax. At most I hope a fairly small pH difference somewhere is not something that greatly affects whatever you trying to compare.
Basically my goal is to have deuterium, and some permutations of it, and find a way that each sample will have a different vibrational frequency.
example, if I want to see if this imaginary door only let in deuterium that vibrated a certain way :)
I have a feeling you are talking about vibrations not knowing what you are talking about. Molecules don't vibrate with some random frequencies, frequencies that they can take are quantized and always the same for a given molecule (and often even for a given kind of bond, regardless of surrounding atoms - for example carbonyl group always vibrates at almost perfectly the same frequency, which makes its detection in IR spectrum extremely easy).
http://en.wikipedia.org/wiki/Quantum_harmonic_oscillator
http://en.wikipedia.org/wiki/Molecular_vibration
Related to Can someone me understand pH levels (Meaning mainly for certain molecule)
1. What is pH level?
pH level is a measure of how acidic or basic a solution is. It is determined by the concentration of hydrogen ions in a solution, with lower pH values indicating higher acidity and higher pH values indicating higher basicity.
2. How is pH level measured?
pH level is typically measured using a pH scale, which ranges from 0 to 14. A pH meter or pH test strips can also be used to measure the pH level of a solution.
3. What is the significance of pH level in chemistry?
pH level is an important factor in many chemical reactions and processes. It can affect the properties and behaviors of molecules and can also be an indicator of the health or quality of a substance.
4. Can pH level be changed?
Yes, pH level can be changed by adding or removing acidic or basic substances from a solution. This process is known as neutralization and can be used to adjust the pH level to a desired value.
5. What are some common substances with different pH levels?
Some common substances with different pH levels include lemon juice (pH 2), vinegar (pH 3), milk (pH 6), water (pH 7), baking soda (pH 9), and bleach (pH 12). It is important to note that the pH level of a substance can vary depending on its concentration.
  • Chemistry
