How do balloon-launched satellites even reach outer space?
In summary: Even a very small amount of thrust can overcome it.In summary, Elon Musk commented on how if Earth's gravity were just a little stronger, then it would have been impossible to generate enough thrust to get into space. However, I know of a few independent projects involving sending satellites to space via balloons. Peter Forsythe, a British 13-year-old, managed to do it. There's a handful of Kickstarter projects trying to get funding to do the same thing, SkyCube is one example. Something isn't adding up. If thrust is a fundamental requirement for reaching space, then how exactly are these balloon-based satellites pulling it off? They surely don't have enough thrust.
Mr. Barracuda
I recently saw an Elon Musk talk on YouTube where he commented on how if Earth's gravity were just a little stronger, then it would have been impossible to generate enough thrust to get into space. He cited that as the reason why only a handful of national governments have successfully reached space.
It seems like something isn't adding up. If thrust is a fundamental requirement for reaching space, then how exactly are these balloon-based satellites pulling it off? They surely don't have enough thrust.
If anyone could clear this up for me it'd be really helpful. Thanks!
Skycube and most of the others launch via rocket (skycube was intended to descend with a balloon -- not ascend). PongSats (Peter's cool experiment) have not gone into 'space' when launched by balloon. The record for any of them is just over 100k feet.
You cannot get to space by balloon. The maximum altitude you can reach is very 'space like' for a person but still has way too much atmosphere for anything to freely orbit there. Low Earth orbit altitude starts around roughly 530k feet.
And even if you had a rocket launched from a balloon at high altitude, it might make it high enough to call it "in space", but it will fall right back down to Earth, since it would not have anything close to orbital velocity in the radial direction.
Even the two communications satellites that were literally balloons were launched by a rocket.
Echo project
There's also different definitions for where 'outer space' begins, since the atmosphere actually just gradually tapers off in density.
About 60 miles is one definition. By that time, the atmosphere is so thin that the speed an airplane would need to generate lift and so on would be greater than the speed necessary to obtain orbit. But, that wouldn't be a functional orbit because, as thin as the atmosphere is, it's still thick enough that atmospheric drag would pull a spacecraft back down to Earth before you'd get any use out of it unless you continuously fired the rocket to maintain an orbital speed.
Alot of a rocket's thrust is wasted in accelerating its own fuel, in fighting gravity, and in combatting air drag. These factors compound and feed upon themselves in a circular feedback loop (more needed fuel means even more fuel to accelerate that fuel, etc.) resulting in insanely large rockets.
By starting out higher (such as with a aballon), you reduce all these factors and therefore you need a smaller rocket to reach space.
Smaller rocket, sure. Much smaller? Not so much.
Air drag in the first minutes of launch is almost insignificant next to the 7.75 km/sec orbital velocity.
FAQ: How do balloon-launched satellites even reach outer space?
How do balloon-launched satellites reach outer space?
Balloon-launched satellites are able to reach outer space through a process called balloon-assisted launch. This involves attaching a satellite to a high-altitude balloon, which carries it up to the edge of Earth's atmosphere. Once the balloon reaches a certain altitude, the satellite is released and then propelled into orbit using its own rocket engines.
What types of balloons are used for launching satellites?
The most commonly used type of balloon for satellite launches is a zero-pressure balloon, which is designed to maintain a constant volume and shape as it ascends to high altitudes. These balloons are typically made of durable materials such as polyethylene or polyester and can reach altitudes of up to 30 kilometers.
How do scientists control the trajectory of a balloon-launched satellite?
Scientists use a combination of weather forecasting, atmospheric modeling, and real-time tracking to control the trajectory of a balloon-launched satellite. They also have the ability to remotely release the satellite at a specific altitude and direction, using onboard guidance systems.
What are the advantages of using balloon-assisted launch for satellites?
One major advantage of using balloon-assisted launch for satellites is cost-effectiveness. Balloon-launched satellites require less fuel and take advantage of the Earth's natural rotation and atmospheric currents, making it a more energy-efficient method compared to traditional rocket launches. Additionally, balloon launches can be conducted from remote locations, allowing for greater flexibility and access to different orbital paths.
Are there any limitations to balloon-launched satellites?
While balloon-assisted launch offers many advantages, it also has some limitations. The main limitation is the payload capacity, as balloons can only carry a certain weight to high altitudes. This means that balloon-launched satellites are typically smaller and have more limited capabilities compared to traditional rocket-launched satellites. Additionally, the weather can also impact the success of a balloon launch, so careful planning and monitoring are necessary.
10K
