Saitama
- 4,243
- 93
(There are four questions based on the paragraph below. I was able to solve two of them but clueless about the other two.)
Given two curves ##y=f(x)## passing through the points (0,1) and the curve ##y=g(x)=\int_{-∞}^{x} f(t)dt## passing through the points (0,1/2). The tangents drawn to both the curves at the points with equal abscissas intersect on the x-axis. Then
Q.1) The value of f'(0) is:
(A)0
(B)1/2
(C)2
(D)1
Attempt:
Let the points on the curve at which the tangents are drawn be ##(x_1,y_1)## for ##y=f(x)## and ##(x_1,y_2)## for ##y=g(x)##.
The equation of tangent at ##(x_1,y_1)## is ##y-y_1=f'(x_1)(x-x_1)##. It intersects the x-axis at ##x=\frac{-y_1}{f'(x_1)}+x_1##.
The equation of tangent at ##(x_1,y_2)## is ##y-y_2=g'(x_1)(x-x_1)## and this intersects the x-axis at ##x=\frac{-y_2}{g'(x_1)}+x_1##.
According to the above paragraph, the tangents intersect at x-axis, the x intercept is equal. Hence ##\frac{y_1}{f'(x_1)}=\frac{y_2}{g'(x_1)}## which is equal to ##f(x_1) \cdot g'(x_1)=g(x_1) \cdot f'(x_1)## using ##y_1=f(x_1)## and ##y_2=g(x_1)##.
We have ##g'(x)=f(x)##. And for ##x_1=0##, i get ##f(0) \cdot f(0)=g(0) \cdot f'(0)##.
##f(0)=1## and ##g(0)=\frac{1}{2}##. Therefore, ##f'(0)=2##.
Q.2)##\lim_{x→0}\frac{f^2(x)-1}{x}## equals
(A)1
(B)2
(C)3
(D)4
Attempt:
Using L'Hôpital's rule,
[tex]\lim_{x→0}\frac{f^2(x)-1}{x}=\lim_{x→0} 2f(x) \cdot f'(x)[/tex]
Solving, I get the answer 4.
Q.3)The value of ##g'(\frac{1}{2})## is
(A)e
(B)e/2
(C)2e
(D)1
Attempt:
I can't obtain the value of g'(1/2) using any of the equations I have derived. I am stuck here.
Q.4)The area bounded by the x-axis, the tangent and normal to the curve y=f(x) at the point where it cuts the y-axis, is:
(A)3/4
(B)1
(C)5/4
(D)3/2
Attempt:
Haven't yet tried this. I would like to first discuss Q.3 and then move on to this one.
Thanks for taking your time to read this.
Any help is appreciated. Thanks!
