Is there a connection between topological M theory and full M theory?
  • Thread starter marcus
In summary: I'm trying to avoid using the word degree of freedom) has come up in previous discussions, and I think I even got into it a bit, but didn't really understand what was being talked about. That's probably because I wasn't paying close enough attention to Smolin. I'll try and do better this time.This is what I think I recall from the previous discussions. In every Calabi-Yau manifold there are two things associated to it. One is a symplectic structure and the other is a complex structure. If the manifold is to be used to compactify some physical theory, the symplectic structure is what you use to define the theory on the manifold,
marcus
Dearly Missed
24,775
792
http://arxiv.org/abs/hep-th/0503140
A quantization of topological M theory
Lee Smolin
20 pages
"A conjecture is made as to how to quantize topological M theory. We study a Hamiltonian decomposition of Hitchin's 7-dimensional action and propose a formulation for it in terms of 13 first class constraints. The theory has 2 degrees of freedom per point, and hence is diffeomorphism invariant, but not strictly speaking topological. The result is argued to be equivalent to Hitchin's formulation. The theory is quantized using loop quantum gravity methods. An orthonormal basis for the diffeomorphism invariant states is given by diffeomorphism classes of networks of two dimensional surfaces in the six dimensional manifold. The hamiltonian constraint is polynomial and can be regulated by methods similar to those used in LQG.
To connect topological M theory to full M theory, a reduction from 11 dimensional supergravity to Hitchin's 7 dimensional theory is proposed. One important conclusion is that the complex and symplectic structures represent non-commuting degrees of freedom. This may have implications for attempts to construct phenomenologies on Calabi-Yau compactifications."
When Smolin talks, I listen. On the surface, it looks like a challenge to M-theory, but having read it, that does not appear to be the case. Good link.
I think you are right. the paper seems more like part of a conversation that he is having with string theorists Cumrun Vafa, Robbert Dijkgraaf, et al
(the authors of http://arxiv.org/hep-th/0411073 )
and with differential geometer Nigel Hitchin.
In the acknowledgments there are thanks to Dijkgraaf, Gukow, Hitchin, Neitzke, Vafa. Smolin's paper was apparently written in haste and still has lots of typos to correct. Some sections, like section 3 maybe, could be expanded. I think the paper could be seen as a response to
hep-th/0411073.
If that is the way to look at it, then one would have to go back and see what stands out in the earlier paper
just to have it handy, since it seems to go with Smolin's paper or viceversa, here is the Dijkgraaf et al abstract:
Topological M-theory as Unification of Form Theories of Gravity
Robbert Dijkgraaf, Sergei Gukov, Andrew Neitzke, Cumrun Vafa
65 pages, 2 figures
"We introduce a notion of topological M-theory and argue that it provides a unification of form theories of gravity in various dimensions. Its classical solutions involve G_2 holonomy metrics on 7-manifolds, obtained from a topological action for a 3-form gauge field introduced by Hitchin. We show that by reductions of this 7-dimensional theory one can classically obtain 6-dimensional topological A and B models, the topological sector of loop quantum gravity in 4 dimensions, and Chern-Simons gravity in 3 dimensions. We also find that the 7-dimensional M-theory perspective sheds some light on the fact that the topological string partition function is a wavefunction, as well as on S-duality between the A and B models. The degrees of freedom of the A and B models appear as conjugate variables in the 7-dimensional theory. Finally, from the topological M-theory perspective we find hints of an intriguing holographic link between non-supersymmetric Yang-Mills in 4 dimensions and A model topological strings on twistor space."
here is something about Nigel Hitchin
http://www.ma.utexas.edu/~hausel/hitchin/
his field is differential geometry
he is in the math department at Oxford
here's Robbert Dijkgraaf's attractive homepage
http://staff.science.uva.nl/~rhd/
Just reading a bit in these papers, an important point that Smolin makes is that the DGNV Topological M-theory isn't really topological, since he shows it has local degrees of freedom. Two of them in fact, and they don't commute with each other.
He further shows that both of these degrees of freedom are needed to specify a paticular Calabi-Yau manifold to compact your string physics on, but if they don't commute, when you come to quantize the theory, you can't specify them both at the same time because of uncertainty. Bummer! It seems amazing to me that nobody noticed this little problem before!
can you explain what difference it makes? I noticed him saying that too: that there were a couple of local degrees of freedom. But I couldn't interpret it. Why should that be inconvenient, for what DGNV are up to? sorry if this is a naive question.
maybe it is merely disconcerting, that DGNV didnt notice something and had to wait for Smolin to point it out? but maybe it is not a serious impediment to what they want to do? (feeling very tentative about trying to interpret, these is unfamiliar terrain for me)
Don't know if this is helpful:
Generalized Calabi-Yau manifolds
Nigel Hitchin
http://www.arxiv.org/abs/math.dg/0209099
It wasn't referenced by Smolin. It ends up talking about gerbes. Note that Hitchin is a very important mathematician in the history of cohomological field theory and the maths of String theory in general. The above paper is expanded upon in the 2003 thesis of Hitchin's student
Generalized complex geometry
Marco Gualtieri
http://arxiv.org/abs/math.DG/0401221
Regards
Kea :smile:
It sure isn't naive, I am just on the outer erdges of the math myself. I'm going to research it, including the Hitchins paper Kea linked to (Thanks Kea!) and I'll post something hopefully tomorrow.
The idea of Calabi-Yau manifolds having two structures, a metric and a symplectic, was new to me; in fact I never knew of any connection between C-Y and symplectic manifolds at all.
selfAdjoint said:
I'm going to research it, including the Hitchins paper Kea linked to...
Thanks selfAdjoint. I've been busy with work, mountain accidents (which I have a tendency to get mixed up in) and other adventures.
DGNV don't reference the latter Hitchin stuff either, which makes me think (perhaps erroneously) that this is why Smolin didn't look at it. It would be good if we could get some comments from an M-theory person, such as Sati, but I'm not sure if any of them read this site.
Cheers
Kea :smile:
Hi Kea, sorry to hear about the mountain accidents. Trust it is not you but someone you know, hope they are all right.
Just to clarify about the Hitchin papers (not for you or sA so much as in case anyone else is listening). The two recent papers by Hitchin that DGNV cited (besides the earlier "twistor" one from 1981) were
http://arxiv.org/math_DG/0010054
http://arxiv.org/math_DG/0107101
and these are exactly the two that Smolin referenced in his paper, which seems appropriate because his paper is in response to theirs and initiates a Loop treatment of what DGMV presented as topological M-theory.
Right, Marcus. The Hitchen "super-Calabi-Yau" paper is not in issue here. I'm still trying to get the DGNV paper into my thick head.
At long last. Here is the relevant theorem from Hitchens October 2000 paper.
Theorem 19 Let M be a closed 7-manifold with a metric with holonomy G2, with defining 3-form [tex]\Omega[/tex]. Then [tex]\Omega[/tex]
is a critical point of the functional [tex]\Phi[/tex] restricted to the
cohomology class [tex][\Omega] \in H^3(M,R)[/tex].
Conversely, if [tex]\Omega[/tex] is a critical point on a cohomology class of a closed oriented 7-
manifold M such that [tex]\Omega[/tex] is everywhere positive, then [tex]\Omega[/tex] defines on M a metric with holonomy G2.
So basically just giving a 3-form with holonomy serves to define the geometry of any 7-dimensional manifold. He goes on to show that the 3-form defines the moduli space of the manifold too. Note that this is all pure math; Hitchin cross classifies it on the arxiv as Algebraic Geometry and Differentiqal Geometry.
Now on to Dijkgraaf, Gukov, Neitzke, and Vafa (DGNV) in hep-th/0411073. They are concerned with a topological theory they call the B-model:
There has been a longstanding prediction of the existence of a 7-dimensional topological theory from a very different perspective, namely the wavefunction property of the topological string partition function, which we now briefly recall in the context of the B model. The B model is a theory of variations [tex]\delta\Omega[/tex] of a holomorphic 3-form on a Calabi-Yau 3-fold X. Its partition function is written ZB(x;0). Here x refers to the zero mode of [tex]\delta\Omega[/tex] , x ∈ H3,0(X,C) ⊕ H2,1(X,C), which is not integrated over in the B model. The other variable 0 labels a point on the moduli space of complex structures on X; it specifies the background complex structure about which one perturbs. Studying the dependence of ZB on 0 one finds a “holomorphic anomaly equation” [7,14], which is equivalent to the statement that ZB is a wavefunction [8], defined on the phase space H3(X, IR). Namely,
different 0 just correspond to different polarizations of this phase space, so ZB(x;0) is related to ZB(x;′0) by a Fourier-type transform. This wavefunction behavior is mysterious from the point of view of the 6-dimensional theory on X. On the other hand, it would be natural in a 7-dimensional theory: namely, if X is realized as the boundary of a 7-manifold Y , then path integration over Y gives a wavefunction of the boundary conditions one fixes on X.
They then define a wavefunction [tex]\Phi[/tex] as the tensor product of ZB and its complex conjugate. This wave function then has a well defined quantum thing called a Wigner Function, which measures its density in phase space. They show an identification of this Wigner function with the partition function of Hitchin's form theory, stongly suggesting that the two theories are identical.
More to come--
Related to Is there a connection between topological M theory and full M theory?
1. What is Smolin's LQG-style M-theory?
Smolin's LQG-style M-theory is a proposed theory that combines elements of loop quantum gravity (LQG) and M-theory, two different approaches to understanding the fundamental laws of physics. It aims to address the limitations and inconsistencies of both theories by incorporating aspects of both, while also providing a more complete and unified understanding of the universe.
2. How does Smolin's LQG-style M-theory differ from traditional M-theory?
Traditional M-theory is a framework that attempts to unify all known forces and particles in the universe into a single theory. However, it has several limitations, such as the inability to explain the observed value of the cosmological constant. Smolin's LQG-style M-theory incorporates elements of loop quantum gravity, which provides a quantum description of spacetime, in order to address these limitations and provide a more complete theory.
3. What are the implications of Smolin's LQG-style M-theory for our understanding of the universe?
Smolin's LQG-style M-theory has the potential to provide a more complete and unified understanding of the universe by incorporating elements of both loop quantum gravity and M-theory. It also has the potential to address some of the limitations and inconsistencies of traditional M-theory, such as the cosmological constant problem. However, the theory is still in its early stages and further research is needed to fully understand its implications.
4. How does Smolin's LQG-style M-theory relate to other theories of quantum gravity?
Smolin's LQG-style M-theory is one of several proposed theories of quantum gravity, which seek to reconcile the principles of quantum mechanics with those of general relativity. It differs from other theories, such as string theory, in that it incorporates elements of both loop quantum gravity and M-theory. However, like other theories of quantum gravity, it is still a work in progress and has yet to be fully developed and tested.
5. What are the current challenges and criticisms of Smolin's LQG-style M-theory?
One of the main challenges facing Smolin's LQG-style M-theory is the lack of experimental evidence to support its predictions. The theory is still in its early stages and has yet to be fully developed and tested. Additionally, some critics argue that the theory is too complex and may not be falsifiable, making it difficult to verify or refute its claims. Further research and development are needed to address these challenges and criticisms.
  • Beyond the Standard Models
