Boundedness of Continuous Function
In summary, the function f is continuous on (0, 1), but not bounded. It is bounded on the interval (0, r), where r is the smallest value such that d(x,s)<r for all {s}\in{E}.
gajohnson
73
Let [itex]f[/itex] be a real, uniformly continuous function on the bounded set [itex]E[/itex] in [itex]R^1[/itex]. Prove that [itex]f[/itex] is bounded on [itex]E[/itex]. Show that the conclusion is false if boundedness of [itex]E[/itex] is omitted from the hypothesis.
NA
Ok, so the second part is easy. We simply let [itex]E=R^1[/itex] and [itex]f(x)=x[/itex].
For the first part, I feel like there is a proof-by-contradiction to be had, but I can't quite find it. Any help in the right direction (including telling me that I'm barking up the wrong tree), would be helpful.
Here's what I have so far (pretty much just the definitions, currently searching for where to create the contradiction):
Assume [itex]f[/itex] is unbounded on [itex]E[/itex]. Then, for all [itex]M>0[/itex], there exists some [itex]{x}\in{E}[/itex] s.t. [itex]\left|f(x)\right|>M[/itex].
Now, because [itex]E[/itex] is bounded, there exists [itex]{x}\in{R^1}[/itex] and [itex]r>0[/itex] s.t. [itex]d(x,s)<r[/itex] for all [itex]{s}\in{E}[/itex]
Thanks!
If ##E## is bounded, then it is contained in some compact set ##K##. Compact sets allow you to reduce any open cover to a finite subcover. What would be a good open cover to use here?
NA
Thanks!
You haven't used uniform continuity! E contained in the interval [s-r,s+r]. State the definition of uniform continuity and split the interval into a lot of parts.
And you do need to use uniform continuity. The function f(x)= 1/x is continuous on (0, 1) but not bounded.
(I point this out because my first thought was that continuity was sufficient. I was trying to remember "a function continuous on a closed and bounded set is bounded on that set" and momentarily forgot that E is not necessarily closed.)
Ah, got it! Of course. It's pretty simple from there. Thanks everyone!
FAQ: Boundedness of Continuous Function
What does it mean for a function to be bounded?
When a function is bounded, it means that its values are limited or restricted in some way. In other words, the function does not have values that become infinitely large or small.
How do you determine if a continuous function is bounded?
To determine if a continuous function is bounded, you must analyze the behavior of the function over its entire domain. If the function has a finite range, or if it approaches a specific value as x approaches positive or negative infinity, then it is considered bounded.
Can a continuous function be unbounded?
Yes, a continuous function can be unbounded. This means that the function has values that become infinitely large or small over its domain. An example of an unbounded function is f(x) = 1/x, which approaches infinity as x approaches 0.
How does boundedness relate to continuity?
Boundedness is one of the properties that is necessary for a function to be continuous. A continuous function must have a finite range and be bounded in order to be considered continuous. However, not all bounded functions are necessarily continuous.
What are some real-life examples of bounded continuous functions?
Examples of bounded continuous functions in real life include temperature over time, stock market prices, and population growth. These functions have a finite range and do not have values that become infinitely large or small, making them bounded.
