What Are the Degrees of Freedom for a Massive Spin 1 Particle?
In summary: Now, in order to avoid any kind of confusion, the number of degrees of freedom of a p-form field is given by the number of components minus the number of equations of motion. For the photon, there are four components, but the equation of motion removes one, hence three are left.I hope this answers your question.marlonIn summary, the conversation revolves around the topic of the coupling of the graviton to mass in the context of quantum field theory. The number of degrees of freedom for a field is discussed, with the stress-energy tensor having 10 degrees of freedom and the gravitational field having 2 degrees of freedom. It is mentioned that a mass is represented by the stress-energy tensor and a field with 5 degrees
joshuaw
24
I was wondering if anyone has any insights or can guide me to some decent literature of the coupling of the graviton to mass. I became intrigued about this when thinking about presenting the gravitational interaction in a Feynman diagram. If anyone has any ideas or knows I would greatly appreciate it.
Josh
Josh
This an idea coming from QFT. In QFT you have a quantum field that you must imagine as being a mattress built out of a gazillion springs (harmonic oscillators). Now suppose we but two objects on that mattress, it will start to vibrate. This vibration of the quantumfield (the mattress) corresponds to a particle called the gauge boson or force carrier which really brings over the interaction between the two particles.
Now, a mass is represented by the stress energy tensor from general relativity, which is a symmetric lorentz tensor. Such a tensor has 5 components. In order to put a mass on the mattress is QFT, we have to multiply this tensor with the field (which is the actual mattress, remember ?)
The specific symmetry of this tensor leads to the fact that our field must have 5 degrees of freedom, otherwise this multiplication is not 'valid' (not Lorentz covariant). A field with 5 degrees of freedom expresses a particle of spin 2 because spin 2 really means 2*2+1 = 5 degrees of freedom (think over the degenerate energylevels in QM)
regards
marlon
ps : read A. Zee's QFT in a Nutshell
or check out my journal : the info on the web entry
Thanks for the help. I had never really asked why the graviton had to have spin 2. I will look some more into QFT. It will probably be a couple of years before I am able to take a class in it.
Josh
regards
marlon
1.The stress-energy tensor of matter fields [itex] \Theta_{\mu\nu} [/itex] which appears in the RHS of Einstein equation is a second rank SYMMETRIC 4TENSOR which has 10 (sic) independent components (outta 16 altogether).
2.The gravitational field has 2 (sic) degrees of freedom.You can show this very elegantly in the weak field limit,where one not only can prove this fact,but can also quantize it (the gravity field).
The graviton is the quanta of the gravitational field.A spin 2 particle with 2 degrees of freedom/polarizations/eigenvalues of the helicity operator:+2 & -2...
Daniel.
Josh
It's David Hilbert's fault.He was the first to come up with the Lagrangian or the gravitational field
[tex] S_{L}^{H}[g_{\mu\nu}]=\int \left(d^{4}x\sqrt{-g}\right) \ R [/tex]
from which it can be shown that this classical field has 2 degrees of freedom & at quantum level describes massless particles of spin 2.
Daniel.
dextercioby, you are again wrong...here we go again...pitty cause i really liked the mutual ignorance.
A massive spin 2 field has 5 degrees of freedom, caracterized by the five polarization tensors which are each symmetric in their indices. You will also have one tracelessness condition when you multiply the g-tensor with these polarization tensors.
The stress energy tensor has ten degrees of freedom, i never argued that. You misinterpreted (again) my words. In order for a field, to couple to this tensor, this field will have to be symmetric in its two indices. This field will have ten degrees of freedom.
But minus 5 degrees of frredom coming from the polarization tensors (well, their product with the k-four vector that is) and minus 1 coming from the traceleness relation. 5 degrees of freedom remain.
To the OP : disregard dextercioby's post, since it is partially incorrect and it contains incorrect corrections,...hmmm
marlon
The photon has spin 1 because the field (A-field) describing it will couple to the four vector J.
At first you might think that there is one degree of freedom to much, but this 4th variable is eliminated by the equation [tex]\partial_{\mu}A^{\mu} = 0[/tex]
Thus, three degrees of freedom remain : this is a spin one particle...
regards
marlon
Marlon,what is a degree of liberty...?From your post,you have no idea.
Daniel.
Daniel.
First of all it's a 'degree of freedom'
Basically in this case this concept denotes the number of components in a tensor. They can be reduced whenever some kind of equation, expressing some linear connection between those components, is given.
BTW this is a nice tactic dexter, asking something you don't know yourself but making it look like other people's incompetence...you should have become a sollicitor :smile:
marlon
The components don't always have to be independent. Just look at the influence of gauges in field theory...In the general case of the stress energy tensor, the components are independent, but not all tensors respect that property.
regards
marlon
I wasn't mentioning gauge wrt to matter fields,because in QFT (SM),there are no I-st class constrained systems acting as matter fields.
As for degrees of freedom,you just proved you have no idea whatsoever.
Daniel.
Well, the graviton picture arises from the principles of QFT. You just take as the perturbation of the field (normally denoted by the J-tensor in the path integral formalism) the stress energy tensor.
Don't sell this blablabla...
Daniel.
:smile:
How is that ?
Please, prove me wrong on the matter as to why the graviton has spin two and thus five degrees of freedom (and the other way around).
Before you start your charade, i suggest you read QFT in a Nutshell (page 32 in the chapter called 'bypassing einstein'), you will find the exact same definitions and explanaitions there. Or are you going to deny the content of this book :smile: ?
Should be interesting, though in respect of our 'mutual ingorance'-promise (which you broke) i won't respond any more to your posts...
regards from your best friend
marlon
Josh
If you really must, Feynman has some notes about Gravity approached from a QFT perspective. "Freyman's lectures on Gravitation".
But if you don't already know QFT I wouldn't recommend it.
These are published as a collection of lecture notes and not as a complete theory. The actual theory runs into some difficulties down the road (IIRC it won't renormalize). So it's not a complete theory, just a collection of lecture notes for an approach to gravity that Feynman himself eventually wound up abandoning.
It's noted in the book (which I actually looked at, for some reason which I find unfathomable our local library actually has a copy of it!) that for tutorial purposes, there are much better sources.
I believe one of them is even online
http://xxx.lanl.gov/abs/astro-ph/0006423
From the abstract
A pedagogical description of a simple ungeometrical approach to General Relativity is given, which follows the pattern of well understood field theories, such as electrodynamics. This leads quickly to most of the important weak field predictions, as well as to the radiation damping of binary pulsars. Moreover, certain consistency arguments imply that the theory has to be generally invariant, and therefore one is bound to end up with Einstein's field equations. Although this field theoretic approach, which has been advocated repeatedly by a number of authors, starts with a spin-2 theory on Minkowski spacetime, it turns out in the end that the flat metric is actually unobservable, and that the physical metric is curved and dynamical.
Short sections are devoted to tensor-scalar generalizations, the mystery of the vacuum energy density, and quintessence.
I can't say I really follow the paper - I think the classical approach to gravity is a lot easier. If someone is in the position of already knowing QFT really well, while also not knowing differential geoemtry, the approach in this paper might be of special interest. Otherwise, it's probably a lot easier to learn some differential geometry than it is to learn QFT at the required level.
I think a lot of people on this thread are talking apples and oranges. Take the electromagnetic field - does it have two degrees of freedom, because a photon has a spin of +1 or -1, or does it have six degrees of freedom, because there are 3 components of the electric field, and three of the magnetic which are all independent?
I seem to recall that gravity has 5 degrees of freedom in empty space, and 10 in general.
http://www.physlink.com/Education/AskExperts/ae98.cfm
has a lot more detail, but I have to reread it.
The biggest problem with QFT AND gravity is the cosmological constant (let's call it M). In the absence of gravity, the Lagrangian L is invariant under L ---> L-M, where M is a constant. In classical physics this is true because only the variation of the L is important in the Euler-Lagr equantions. In QFT, the M yields a multiplicative factor in the Feynman path integral, but that is no problem since we can omit that.
However if gravity is 'turned on' (i mean, included in the theory, which is NOT the case in the SM) the invariant under L-M is broken. This means that gravity 'knows' about M...The associated shift in the Hamiltonian H--> H + int(d³xM) is not invariant under coordinate transformations x-->x'(x)...so that is a big problem.
This M represents a constant energy or mass per unit volume permeating the universe.What is this mass and how big is it ? A possible candidate is the vacuum fluctuations...check out my journal for some references to peer reviewed articles.
In particle physics this M is supposed to be 0 but that cannot be the case because of cosmological measurements
regards
marlon
The EM-field has THREE degrees of freedom because of 2j+1 and j=1 for this field (and thus for photons)...Otherwise there cannot be a coupling with this field and the vectorcurrent J (the charged particles)
In classical physics there are indeed two degrees of freedom. The spin 0 state is not possible because we can never bring the massless photon to a restframe and then look at how the rotationgroup works on the photon-spin states. One of the polarization vectors (the longitudinal mode) will decouple from the EM-interactions...Thus two degrees of freedom remain...
The three values for s initially arise from the fact that the field theory is applied for a massive spin 1 particle.
However virtual photons DO have three spin values...
marlon
Pervect,
The degrees of freedom are just the number of linear independent variables that you need in order to describe some physical quantity in a certain representation. They can be denoted by the quantumnumbers...For example you will need three polarization tensors in order to represent a massive spin one particle in the SO(3) representation. If you take away mass, SO(3) will become SO(2)...The polarization tensors can be seen as a fundamental representation, just like the three colours in the case of the SU(3) color symmetry of QCD.
A massive spin 1 particle is just described in terms of these three (in the SO(3)-case) polarizations or in terms of the two polarizations in the photon case (SO(2))
marlon
Related to What Are the Degrees of Freedom for a Massive Spin 1 Particle?
1. What is the graviton?
The graviton is a theoretical particle that is thought to be the carrier of the gravitational force in the framework of quantum mechanics. It is believed to be massless and have a spin of 2.
2. How is the graviton related to the theory of general relativity?
The graviton is related to the theory of general relativity because it is the predicted particle that is responsible for transmitting the force of gravity, which is a fundamental aspect of general relativity's description of the gravitational force.
3. What is meant by the "coupling" of the graviton?
The coupling of the graviton refers to the strength at which the graviton interacts with other particles. In other words, it describes how strongly the graviton mediates the gravitational force between two particles.
4. How is the coupling of the graviton calculated?
The coupling of the graviton is calculated using a mathematical formula that takes into account the properties of the graviton, such as its spin and mass, as well as the properties of the particles it is interacting with.
5. Why is the coupling of the graviton important in understanding the theory of quantum gravity?
The coupling of the graviton is important in understanding the theory of quantum gravity because it is a crucial factor in determining how gravity behaves at the quantum level. By studying the coupling of the graviton, scientists can gain a better understanding of how gravity works and how it can be unified with other forces in the universe.
  • Beyond the Standard Models
  • Science and Math Textbooks
