Eigenfunctions/bases/fourier series
  • Thread starter maple
  • Tags
    Series
In summary, the conversation discusses the wave function and eigenfunctions of a free particle in an infinite potential well in quantum mechanics. The question is raised about whether all eigenfunctions form a basis and if an even function can be represented by eigenfunctions that are odd. The concept of a "gentle" Hermitian operator and the need for real eigenvalues is also mentioned. It is clarified that both sine and cosine are needed to form the basis and solve the TISE, and a recommendation is made to consult introductory texts for further understanding. The importance of understanding the value of a in the problem is emphasized.
maple
I posted this in the general maths section but i think it'll fit better over here.
Anyways...
In quantum mechanics, a free particle in an infinite potential well has the wave function (ie. overlap <x/phi>). Its eigenfunctions take the form:
(2/a)^1/2 * sin(n*pi*x/a), n is ofcourse an integer.
My question is that do all eigenfunctions form a basis? And if so how can you represent an even function with eigenfunctions which are clearly odd- my understanding of the Fourier Series is that its equals a function by representing it as an infinite sum of both sin and cos terms, and if the function is even, the coefficients of the sin terms are zero.
Eg. why can I represent:
cos (pi*x/a) = Infinite Sum (A(subscript)n * sin(n*pi*x/a)).
Any assistance would be much appreciated
Anyways...
You also have K*cos(n*pi*x/a) depending on the parity of n. (I suppose that You have a symmetric potential well (-a/2 to +a/2).
For all practical purposes yes for an obseervable. It is in fact included on the definition of an observable: it is a "gentle" hermitian operator where its eigen vectors form a basis of the Hilbert space. Howerver, the class of these operators with such a mathematical property is difficult to define/verify. Try googling spectral theory for more information.
Seratend.
Thanks Seratend,
although, the well goes from (0 to a): i don't think there are any cos terms that make up the enegy-eigenfns.
Seratend.
so if they form a basis, you can represent any function as linear combinations of these eigenfunctions. Fourier series seems to suggest that you cannot express even functions as linear combinations of odd ones. So cos(n*pi*x/a) is clearly even, so how can you represent it in terms of eigenfns which are sin terms.
also what do you mean by "gentle" Hermitian operator... an observable has to be hermitian because eigenvalues must be real... complex ones are unphysical?
Yes,eigenvalues (more general,spectral values) need to be real (ergo the linear operators need to be self-adjoint,or hermitean at least),because these are numbers which can be experimentally obtained.You can't measure energy (par éxample) and get a complex (i.e.imaginary) value...
Daniel.
Anyways...
No
You are absolutely correct there.
No, you cannot do that.
Both the sine AND the cosine form the basis. You cannot express the cos as a linear combination of the sine, as you can not express the unit vector [tex] {\vec i} [/tex] as a linear combination of the basis vectors [tex] {\vec j}[/tex] and [tex] {\vec k} [/tex].
So in general, you need both the sine and the cosine. In the case of an infinite square well from 0 to a, any physical wavefunction will vanish at x=0 and at x=a and therefore it does not contain any cosine "piece".
I hope that answers your question..keep asking if it's not what you wanted to know.
Regards,
Pat
nrqed said:
No
Regards,
Pat
Thanks Pat, that really cleared somethings up.
I solved the TISE again, and I still get that the eigenfunctions are simply K*sin(n*pi*x/a) where K is a normalised constant as before, applying the boundary condition that you mention alongside the condition that the gradient of the wavefunction must be continuos.
So the problem lies therein. Perhaps I'm solving it incorrectly?
You can always check with a book.Almost all introductory texts on QM deal with the infinite potential (square) well.Hopefully I'm not telling you something new.
Messiah,Cohen-Tannnoudji,Griffiths,exercises in Flügge,Constantinescu & Magyari,etc.
Daniel.
And if you shift your x-axis by a/2 (you just change the origin of your problem), you obtain:
K*sin(n*pi*x-a/2/a)=K*sin(n*pi*x/a - n*pi/2)
= K*sin(n*pi*x/a ) if n is even
= K*cos(n*pi*x/a) if n is odd
What do you conclude now?
You need to understand what is a Fourier series on a given interval (a,b) that is not symmetric respectively to 0 (mathematic problem). The quantum well is a good example to understand that.
In addition you must understand what is the hilbert space associated to the quantum well: the space of functions square integrable with given values on boundaries (in this case 0). Therefore it is normal that the eigenvectors that *form* a basis of this peculiar hilbert space follow these conditions and all the possible functions also. The functions on the square well are a subset of all the square integrable functions (addition of the boundary condition) on (a,b), they are not symmetric respectively to the origin (no signification) and they may be written as a sum of sin(n*pi*x/a).
If you develop a little you may see that you can construct odd or even functions respectively to a/2.
Seratend.
Seratend.
Aha! It all makes sense now; quite interesting stuff. Thanks!
A basis of the solution space... not of all possible wavefunctions.
To follow up on what Hurkyl said, that's only within the solution space. If you can represent any function with them, then it means they're complete. It's not true that all eigenfunctions for all potentials are complete, but it's usually the case.
FAQ: Eigenfunctions/bases/fourier series
What is an eigenfunction?
An eigenfunction is a function that, when multiplied by a constant, results in the same function multiplied by a scalar. In other words, it is a function that remains unchanged except for a scaling factor.
What is a basis?
A basis is a set of linearly independent vectors or functions that can be used to represent any other vector or function in a given vector space or function space. It is often used to simplify calculations and represent complex functions in a more manageable form.
How are eigenfunctions and bases related?
Eigenfunctions are often used as the basis for function spaces because they have special properties that make them easy to work with. For example, they are often orthogonal, meaning they are perpendicular to each other, making it easier to manipulate and solve equations.
What is a Fourier series?
A Fourier series is a way of representing a function as a sum of sines and cosines. It is often used in signal processing and other applications to decompose a complex function into simpler components.
How is a Fourier series calculated?
A Fourier series is calculated by finding the coefficients of the sines and cosines that best fit the given function. This can be done using integration or other methods, and the resulting series can be used to approximate the original function.
