Aki
- 83
Are black holes black afterall? I remember reading in Hawking's book that black holes aren't black.
Aki said:Are black holes black afterall? I remember reading in Hawking's book that black holes aren't black.
Unless and until they get very small in which case the Hawking radiation (HR) would "climb" up the EM spectrum into visible light and all the way to gamma ray frequencies. There is also the "escape" of pairs of real particles taking their energy from the magnetic field. Similar to HR but a different process.Phobos said:They are extremely black (since light cannot escape them) but they are not absolutely black due to Hawking radiation (which unaided human eyes wouldn't be able to detect anyway).
Aki said:so Hawking radiation is basically composed of the particles that fell into the black hole?
If you have time and inclination, please take a look at the arguments I have been making in the thread "First Stars - how big- Black Holes now." Your text above is a perfect example of what I call "empty words" or "feel good" words that do not really explain the mechanistic process anymore than "Morphine makes you sleepy because it contains a narcoleptic agent" does.selfAdjoint said:No. Hawking radiation is created outside the black hole (outside its "event horizon", the sphere from which nothing can escape that surrounds the singularity). Basically it is composed of quantum virtual particles which have acquired enough energy from the stressed spacetime near the black hole to become real. Since the release of the stress by this production reduces the black hole's gravity, it has in effect reduced the black hole's mass.
Different thread so I'm not breaking my promise to not post again on the other one. There is no sense in you visiting PF since you refute any explanations that include what you call "feel good words". But, how is any sane PF member to ever post a reply without knowing what you will or will not call "feel good words"? Anything we could post you could deny just by saying that we used "feel good" words, so any post would, by definition, be self-conflicting.Billy T said:I only want some "feel good" words that are explanitory and certainly not circular words that are just renaming of the same effect.
Now THAT "feels good"!This led me in a few hours to come up with my very own crackpot theory for the first time.
I am not refuting any widely accepted physics. I would appreciate your indication of which of the two different "explanations" of why black holes do evaporate is more satisfying to you. (gamma rays or VP particles escaping as cause.)Labguy said:...There is no sense in you visiting PF since you refute any explanations that include what you call "feel good words". ...
Chronos said:Yes, but it takes a very long time.
s3nn0c said:No. Time of evaporation depends on BH mass.
Despite what I have said against "feel good" words, I tend to agree with you PROVIDED that when "explanations," that are not actually true are offered, it is made clear that it is just a convenient way to think about a more complex subject. I, for example, have no objection to Faraday's suggestion that magnetic field lines are a convenient aid to thought, if one also states that they do not actually exist. etc. Their cutting thru conductors is an aid in predicting when a current will be induced in a closed circuit (or a voltage difference will exist between the ends of an open circuit conductor) in both transformers and generators. The image of field lines concentration near the poles also helps understand why the Earth's magnetic field is stronger and nearly vertical at the N an S magnetic poles, or why electrons are trapped in the ionosphere, or why lighting strikes on the other side of the Earth can make static in your radio etc.Phobos said:...there's nothing wrong with offering a simple explanation to a simple questions. When someone is first learning about topic, you don't necessarily start them off at the most complicated level. "Feel good words" may be short hand for a lot of complicated mathematics.
Is there an evaporation limit? It is my understanding that black holes of any mass can lose mass through Hawking radiation as long as they are not accreting more mass than they are losing through the evaporative process.SpaceTiger said:It does, but I think he was referring to the observed black holes. They're well above the evaporation limit.
turbo-1 said:Is there an evaporation limit? It is my understanding that black holes of any mass can lose mass through Hawking radiation as long as they are not accreting more mass than they are losing through the evaporative process.
Ah, a time-based limit. Ok.SpaceTiger said:By "evaporation limit", I'm referring to the mass at which it would take a Hubble Time for the black hole to evaporate away. We usually assume that black holes less massive than that will be long gone. It's not a limit on which black holes radiate, nor is it a strict limit on which can exist. A black hole created yesterday could be well below that limit.
turbo-1 said:I can accept the concept that very small BHs created in a Big Bang might have evaporated by present time, but whenever I think about primordial BHs, I imagine them existing in a very dense environment where they can gleefully accrete at rates that would be impossible for us to imagine in present physics, and this makes me wonder if true evaporation is possible, even for very tiny black holes.
And:The Hawking temperature of a 30 solar mass black hole is a tiny 2×10-9 Kelvin, and its Hawking luminosity a miserable 10^-31 Watts. Bigger black holes are colder and dimmer: the Hawking temperature is inversely proportional to the mass, while the Hawking luminosity is inversely proportional to the square of the mass.
Black holes get the energy to radiate Hawking radiation from their rest mass energy. So if a black hole is not accreting mass from outside, it will lose mass by Hawking radiation, and will eventually evaporate. For astronomical black holes, the evaporation time is prodigiously long - about 10^61 times the age of the Universe for a 30 solar mass black hole. However, the evaporation time is shorter for smaller black holes (evaporation time t is proportional to M3), and black holes with masses less than about 10^11 kg (the mass of a small mountain) can evaporate in less than the age of the Universe. The Hawking temperature of such mini black holes is high: a 10^11 kg black hole has a temperature of about 10^12 Kelvin, equivalent to the rest mass energy of a proton. The gravitational pull of such a mini black hole would be about 1 g at a distance of 1 meter.
It is not well established what an evaporating mini black hole would actually look like in realistic detail. The Hawking radiation itself would consist of fiercely energetic particles, antiparticles, and gamma rays. Such radiation is invisible to the human eye, so optically the evaporating black hole might look like a dud. However, it is also possible that the Hawking radiation, rather than emerging directly, might power a hadronic fireball that would degrade the radiation into particles and gamma rays of less extreme energy, possibly making the evaporating black hole visible to the eye.
http://casa.colorado.edu/~ajsh/hawk.html
And:so only for very small black holes would this radiation be significant. Still, the effect is theoretically very interesting, and folks working on understanding how quantum theory and gravity fit together have spent a lot of energy trying to understand it and its consequences. The most drastic consequence is that a black hole, left alone and unfed, should radiate away its mass, slowly at first but then faster and faster as it shrinks, finally dying in a blaze of glory like a hydrogen bomb. However, the total lifetime of a black hole of M solar masses works out to be:
10^71 M3 seconds
http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/hawking.html
And:The typical Hawking radiation temperature from solar-mass sized black holes is as low as 0.0001 degree Kelvin (close to absolute zero, and radiation becomes more and more faint as the temperature decreases.) Though of fundamental importance in physics, Hawking radiation is very hard to observe directly from space. One curious feature about Hawking radiation is that the temperature is inversely proportional to the mass of the black hole. Thus the only black holes that might render detectable radiation would be the primordial "mini-holes" that may have been formed shortly after the Big Bang. Such black holes would have a mass of 10^-15 grams, smaller than the size of an atom. The possibility of detecting such mini-holes, however, is uncertain.
http://www.slac.stanford.edu/slac/media-info/20000605/chen.html
A black hole of one solar mass has a temperature of only 60 nanokelvins; in fact, such a black hole would absorb far more cosmic microwave background radiation than it emits. A black hole of 4.5 × 10²² kg (about the mass of the Moon) would be in equilibrium at 2.7 kelvins, absorbing as much radiation as it emits. Yet smaller primordial black holes would emit more than they absorb, and thereby lose mass.
How can you possibly object to "feel good words" Isn't that your specility? I though you bragged about your book full of explanations that are feel good but have no content.Billy T said:I am not refuting any widely accepted physics. I would appreciate your indication of which of the two different "explanations" of why black holes do evaporate is more satisfying to you. (gamma rays or VP particles escaping as cause.)
I also would appreciate some words about how something outside the EH, causes a reduction in mass at the point singularity of the BH. (This seems to be action at a distance with no stated mechanism - Einstein's "spooky" - sorry if my dyslexic scrambled "ein" into "ine" in last typing of his name.)
IMHO, it is reasonable to ask which of the different "explanations" is to be preferred and how the "action at a distance" is achieved. If you will answer these two concerns, I will stop calling the current words you and others have offered "feel good words."
Asking such questions does not make one a "crackpot." BTW I do not recognize the quote you gave as mine. Can you give the thread and post from which your are quoting? I think you must have miss read me or it was related to perception, not physics.
I might be properly be called a "crackpot" in the area of cognition, but not in physics. I do disagree with almost all cognitive scientists (Despite spending a year as guest scholar in Johns Hopkins U's cognitive science department.) The first post to philosophy thread "What Price Free Will" gives three independent proofs that the standard theory of how perception of 3D world is achieved from the 2D image on our retinas is simply wrong - but that does not prove my alternative ideas are correct.
To me, one must dispute widely accepted theory to be a crackpot, hence in physics I am not one, as I dispute nothing that is widely accepted in physics, including the evaporation of BHs. Surely one can ask questions and express a desire for a more a mechanistic understanding. I have even admitted that the loss of mass from a BH may be something, like quantum entanglement, that no human is ever going to really feel like it is understandable. (my "feel good") I am quite prepared to accept this about mass loss from BHs, as I have about quantum entanglement, but not willing to accept two different "explanations" as to why BHs evaporate, nor do I like (any more than Einstein did) action at a distance. I would much prefer to admit that this is a part of physics that humans must accept without pretending to have any set of words that explain the predictions that fall out of the math. To have two entirely different sets of "explanatory" words is embarrassing.
No. I did not mean to "brag." I hesitate to mention my book, unless asked about it or something in it is directly relevant to a post others have made.Integral said:How can you possibly object to "feel good words" Isn't that your specility? I though you bragged about your book full of explanations that are feel good but have no content.
A black hole is a region in space where the gravitational pull is so strong that even light cannot escape. It is formed when a massive star dies and collapses, causing an immense concentration of matter in a small space.
Black holes are black because their gravitational pull is so strong that nothing, including light, can escape from them. This makes them invisible to the naked eye, hence the term "black" hole.
Yes, black holes are really black. Although they emit some radiation, known as Hawking radiation, it is very faint and difficult to detect. This means that from a distance, black holes appear completely black.
No, we cannot see black holes directly. However, we can observe their effects on surrounding matter, such as stars and gas, which can help us infer their presence and study them.
Yes, there are several types of black holes, including stellar black holes, intermediate black holes, and supermassive black holes. These types differ in their size and mass, with supermassive black holes being the largest and most massive.
