Laplace's equation in two dimensions.
In summary, the conversation discusses the general solution to the two-dimensional Laplace's equation in polar coordinates and how it can be applied to handle cases where the solution space includes both the origin and an unbounded region. The conversation also touches on the issue of boundary conditions and the potential at infinity. The specific problem mentioned is that of an incomplete conducting cylindrical shell of infinite length and negligible thickness maintained at a potential V and of radius 'a'. The discussion concludes that this may be a difficult mathematical problem and suggests considering a numerical solution.
physwizard
153
Hi all,
Had a doubt regarding Laplace's equation.
In many textbooks, the general solution to the two dimensional Laplace's equation is mentioned as:
[itex]\Phi(\rho,\phi) = A_{0} + B_{0}ln(\rho) + \sum_{n=1}^{\infty}\rho^n(A_ncos(n\phi) + B_n sin(n\phi)) + \sum_{n=1}^{\infty}\rho^{-n}(C_n cos(n\phi) + D_n sin(n\phi))[/itex]
in polar coordinates.
For convenience, I will name the two summation terms as:
[itex]T_1 = \sum_{n=1}^{\infty}\rho^n(A_ncos(n\phi) + B_n sin(n\phi))[/itex]
[itex]T_2 = \sum_{n=1}^{\infty}\rho^{-n}(C_n cos(n\phi) + D_n sin(n\phi))[/itex]
Not much has really been mentioned on whether these two series, T1 and T2 converge or not. When the solution space does not include either zero or infinity it is generally implicitly assumed that they converge. When the solution space includes the origin, generally the procedure has been to equate the coefficients of the second series, T2, to zero, in other words, to exclude the second series from the solution.
In many physical problems of interest however, the solution space includes both the origin of the coordinate system and is an unbounded region in all directions. My question is, how can we use the above expansions to handle such cases? Especially when there is a boundary condition of zero at infinity. The radius of convergence doesn't seem to be known a priori as the coefficients are unknown.
For example, if you consider the case of an infinitely long conducting cable of arbitrary but uniform cross-section, (Arbitrary meaning that it need not be something geometrical or symmetric like a circle or a square, and could even be concave; and uniform meaning that the shape and area of the cross-section does not change in the 'z' direction so it can be reduced to a two dimensional problem.) maintained at a constant potential 'V', and where the potential is taken to be zero at infinity. It may often be convenient to choose the origin outside the cable. In this case, if I exclude the term T2 (for finiteness at the origin), again the boundary condition [itex]\Phi\rightarrow0[/itex] as [itex]\rho\rightarrow\infty[/itex] will imply that the coefficients in the term 'T1' become zero as well. So the solution appears to be trivially zero(obviously wrong!) even before I apply the boundary condition [itex]\Phi = V[/itex] at the surface of the cable.
Can anyone let me know what I am doing wrong? Can anybody throw some light on this?
Thanks.
When you move the origin outside the cylinder, you are forgetting that ##\Phi## is still allowed to blow up inside the cylinder, since the region of interest is only outside.
Also, in a 2-d problem, I don't think it is always consistent to set the potential to zero at infinity. For example, your cylinder, no matter what its shape, is going to look like a thin wire from very far away; therefore, at infinity the dominant term will be the logarithm.
Hi,
Thank you for your response. I agree that [itex]\Phi[/itex] is allowed to blow up inside the cylinder. But how is that helpful here? I agree with you that you can have the logarithm term in the expression for the potential. But that still does not appear to resolve the problem. We would not be able to have positive integral powers of [itex]\rho[/itex] in the solution. (As these could lead to the electric field being constant or infinite at infinity. While we expect the electric field to approach that of a system of line charges at infinity.) So if we assume that T1 = 0, we would get the solution as: [itex]\Phi = A_0 + B_0ln(\rho)[/itex] . Now we have only two unknown constants but applying the boundary conditions [itex]\Phi = V[/itex] at all points on the surface of the cable would result in an inconsistency(Infinite no. of equations but only two unknowns.). So what is going wrong here?
Now we have only two unknown constants but applying the boundary conditions Φ=V at all points on the surface of the cable would result in an inconsistency(Infinite no. of equations but only two unknowns.).
What do you mean by inconsistency? The solution of the problem is
\Phi = V \ln \frac{\rho}{R}.
This solution is not consistent with [itex]\Phi = V [/itex] everywhere on the surface of the conductor. If it equals V at one point on the surface of the conductor, it would not equal V at another point on the surface of the conductor which has a different value of [itex]\rho[/itex].
Perhaps I misunderstood the geometry you have in mind.
The above solution is intended for the region outside a long metallic cylinder. Inside the cylinder, the potential is constant and equal to the potential on the surface.
Hi, my original question was a general question for any conductor with arbitrary cross-section. This is related to the discussion we had on the other thread. I am trying to solve the 2 dimensional case first before attempting the 3 d one. The exact problem I had in mind was that of an incomplete(I will clarify the meaning of this) conducting cylinderical shell of infinite length and negligible thickness maintained at a potential V and of radius 'a'. This is not a complete cylinder but has an infinitely long slit from ##\phi = -\alpha## to ##\phi=+\alpha##. We would expect the potential to asymptotically approach that of a line charge at infinity, in other words ##\Phi \rightarrow k ln(\rho)## as ##\rho \rightarrow \infty## . Also, we would expect the field to be continuous at ##\rho=a## for ##\phi## = -##\alpha## to +##\alpha##.
That seems like a difficult mathematical problem. I would try to solve it numerically first. Generally, there may be some problems due to sharp edges - if they are too sharp, the Laplace equation may not have a solution - but I am not sure what will happen in your example.
Hi Jano,
Thanks for your response and highlighting the point that this problem has sharp edges. It is a bit disappointing that even relatively simple problems of practical importance are difficult to solve analytically.
FAQ: Laplace's equation in two dimensions.
What is Laplace's equation in two dimensions?
Laplace's equation in two dimensions is a partial differential equation that describes the relationship between a function and its second order derivatives. It is typically written as ∇²u = 0, where u is a function of two variables and ∇² represents the Laplace operator.
What is the physical significance of Laplace's equation in two dimensions?
Laplace's equation in two dimensions is commonly used in physics and engineering to model steady-state systems, where the behavior of a system does not change over time. It can also be used to describe the flow of electric or heat currents in two-dimensional systems.
What are the boundary conditions for Laplace's equation in two dimensions?
The boundary conditions for Laplace's equation in two dimensions are typically specified by the problem being solved. These conditions describe the values or behavior of the function at the boundaries of the system and are necessary to obtain a unique solution.
How is Laplace's equation in two dimensions solved?
Laplace's equation in two dimensions can be solved analytically using techniques such as separation of variables or by using complex analysis. It can also be solved numerically using methods such as finite differences or finite element analysis.
What are some applications of Laplace's equation in two dimensions?
Laplace's equation in two dimensions has many applications in physics, engineering, and mathematics. It is commonly used to model electrostatics, heat transfer, fluid dynamics, and diffusion processes. It is also used in image processing, signal processing, and computer graphics.
