Help solve all this question please
  • Thread starter tauwee
In summary, the conversation discusses the collision between two uniform smooth spheres, P and Q, on a smooth horizontal table. After the collision, P changes direction and collides with a vertical wall, while Q rebounds in the opposite direction. The coefficient of restitution between P and Q is represented by e and e' for the collision with the wall. The questions involve finding expressions for the velocities of P and Q after the collision and proving that e > 1/3 and e' > 1/9. The coefficient of restitution is a measure of the ratio of the final to initial relative velocities of two objects after a collision.
tauwee
help solve all this question please...:(
A uniform smooth sphere P,of mass 3m, is moving in a straight line with speed u on a smooth horizontal table.Another uniform smooth sphere Q, of mass and m and having the same radius as P, moving with speed 2u in the same straight line as P but in the opposite direction to P. The sphere P collides with the sphere Q directly. The velocities of P and Q after the collision are v and w respectively, measured in the direction of motion of P before the collision. The coefficient of restitution between P and Q is e.
a) Find an expression for v in terms of u and e.
b) Show that, if the direction of motion and P is changed by the collision, then e>1/3.
c) Find an expression for w in terms of u and e.
Following the collision with P, the sphere Q then collides with and rebounds from a vertical wall which is perpendicular to the direction of motion of Q. The coefficient of restitution between Q and the wall is e'
Given that e=5/9, and that P and Q collide again in the subsequent motion,
e) Show that e'>1/9.
Do you know any equations that may help?
this is the prove question...i don't know wht equation can solve :(
Can you define " The coefficient of restitution"?
a) Using the conservation of momentum and the coefficient of restitution, we can set up the following equations:
Conservation of momentum: 3mu + m(-2u) = 3mv + mw
Coefficient of restitution: (v-w)/(u-(-2u)) = 5/9
Solving for v, we get: v = (10/9)u
b) If the direction of motion of P is changed by the collision, then v will be in the opposite direction as u. This means that v will be negative. Substituting this into the equation for the coefficient of restitution, we get:
(-|v|-w)/(-|u|-(-2u)) = 5/9
Simplifying, we get: (v-w)/(3u) = 5/9
Substituting the value of v from part a), we get: (-10/9u - w)/(3u) = 5/9
Simplifying, we get: w = (-5/3)u
Since w is negative, this means that the direction of motion of Q is also changed by the collision. This also means that the coefficient of restitution must be greater than 1/3, as the negative sign indicates a reversal in direction.
c) Using the conservation of momentum and the coefficient of restitution, we can set up the following equations:
Solving for w, we get: w = (-5/3)u
e) Using the conservation of momentum and the coefficient of restitution, we can set up the following equations:
Conservation of momentum: 3mv + mw = 3mv' + m(-2v')
Coefficient of restitution: (v'-(-2v'))/(w-(-2v')) = e'
Substituting the values for v and w from part a) and c), we get:
(10/9u - (-4/3)u)/(5/3u - (-4/3)u) = e'
Simplifying, we get: (28/27) = e'
Since e' is greater than 1/3, this means that e' must also be greater than 1/9, as shown.
Related to Help solve all this question please
1. How can we solve all these questions?
Unfortunately, there is no single solution to solving all questions. Each question may require a different approach and method of solving. It is important to carefully analyze and understand each question in order to come up with an appropriate solution.
2. What steps should I take to solve a question?
The first step in solving a question is to carefully read and understand the question. Then, gather all the necessary information and data needed to solve the question. Next, break the question down into smaller parts and work through each part systematically. It is also important to check your work and make sure your solution is logical.
3. How do I approach a difficult question?
When faced with a difficult question, it is important to remain calm and not get overwhelmed. Break the question down into smaller parts and work through each part systematically. If you are still stuck, try looking for similar examples or seeking help from a colleague or teacher.
4. Can I use software or technology to help me solve questions?
Yes, there are many software and technology tools available that can assist in solving questions. However, it is important to understand the concepts and methods behind the solution rather than relying solely on technology. Always double-check your work and make sure the technology is giving you accurate results.
5. What should I do if I cannot solve a question?
If you are unable to solve a question, do not get discouraged. Take a break and come back to it later with a fresh perspective. You can also seek help from a colleague, teacher, or online resources. It is important to keep trying and not give up, as problem-solving skills can be improved with practice.
