Torque / Pulley / Weight question
In summary, the conversation is about a question regarding a solid disc pulley system with a 5kg mass, a radius of 0.5m, and a metal block with a mass of 10kg attached to one end of the rope. The question asks for the acceleration of the falling block, the velocity of the block at 2 metres, and the torque on the pulley's shaft. The conversation includes calculations for the pulley's inertia, acceleration, and torque, as well as discussions about the equation for torque, units for angular acceleration, and the location of the calculated torque.
pjb73
Hi
I'm 40 and teaching myself physics from the internet and have the following question but don't where to start!
Here is the question:
A solid disc pulley with a 5kg mass, radius of 0.5m has one layer of thin rope coiled around it. On the other end of the rope is a metal block with a mass of 10kg.
Calculate the following (without take rope friction into account. also the rope does not slip):
1. Acceleration of the falling block.
2. Velocity of the falling block at 2 metres.
3. The on the pulleys shaft (Radius of pulleys shaft is 30mm).
So far I have I drawn a diagram showing the forces on the block (F upwards and m2g down), and the forces on the pulley (F downwards at the edge of the pulley) (for both the block and the pulley, F is the force due to the rope).
Have I missed anything and what should do next?
Thanks.
Vector Mechanics for Engineers; Statics, by Beer, Johnston and Eisenberg has many examples with pulleys and ropes ;)
Can anyone give me the link to any useful resources on the internet?
If you google the title I gave you, you'll find some pretty interesting results ;)
Thanks Aero_UoP
You have missed the accelerations of the block and the pulley, and accounting for them is what you should be doing next.
Thanks for your reply voko.
ok, so I have followed the above advise. Would you please check my following calculations so I can be sure I understand correctly.
To calculate angular acceleration 1st calculate pulley inertia:
pulley inertia(I) = 1/2mr2 (2 represents squared)
I = 1/2 x 5 x 0.25
I = 0.625
acceleration(a) = hanging mass weight divided by mass of hanging mass plus pulleys inertia divided by radius squared.
a = 98 / (10 + (0.625 / 0.25))
a = 98 / (10 + 2.5)
a = 7.84 m/s
To calculate the torque:
Torque(T) = Inertia x Angular Acceleration
T = 0.625 x 7.84
T = 4.9Nm
Would someone let if the above calculations are correct?
Many thanks.
The most interesting part is this equation: are you sure you can explain how you got it?
T = 0.625 x 7.84
T = 4.9Nm
The equation is correct; however, "7.84" is not angular acceleration; it is the (linear) acceleration of the hanging mass that you calculated above.
I can explain how I got the acceleration equation. Is the equation correct?
Assuming the acceleration equation to be correct. To calculate the torque:
and... Angular Acceleration = a/r = 7.84/0.5 = 15.68 m/s
T = 0.625 x 15.68
T = 9.8Nm
Is the above correct?
Also did I use the correct units for Angular Acceleration (m/s) or should it be rads/sec?
And Also, is the calculated torque on the edge of the pulley (as apposed to being on the shaft of the pulley)?
Thanks again for your help
It is correct.
T = 0.625 x 15.68
T = 9.8Nm
Correct, except the units for angular acceleration.
Neither is correct. Linear acceleration is ## m s^{-2} ##, and angular acceleration is ## s^{-2} ##. You could say angular acceleration is ## rad \cdot s^{-2} ## because radians are technically dimensionless.
Torque is the same all around. You calculated the torque assuming the force was applied at the edge.
Thank you very much voko for all your help :)
FAQ: Torque / Pulley / Weight question
What is torque?
Torque is a measure of the rotational force applied to an object. It is calculated by multiplying the force applied by the distance from the axis of rotation.
How is torque related to pulleys?
Pulleys are used to change the direction of a force, but they also affect the amount of torque required to move an object. The more pulleys used, the less torque is needed to lift a given weight.
How does weight affect torque?
The weight of an object affects the amount of torque needed to move it. A heavier object will require more torque to overcome its weight and begin rotating, while a lighter object will require less torque.
Can torque be negative?
Yes, torque can be negative. This occurs when the force applied to an object is in the opposite direction of the rotation. In this case, the object would be rotating in the opposite direction.
How can I calculate torque in a pulley system?
To calculate torque in a pulley system, you will need to know the radius of the pulley, the force being applied, and the angle at which the force is being applied. You can then use the formula Torque = Force x Radius x sin(angle) to calculate the torque.
