Why can there be no arcing in a perfect vacuum?
  • Thread starter iScience
  • Tags
    Vacuum
In summary, the conversation discusses the concept of breakdown and arcing in air, as well as the role of air in creating a path for electrons to flow. It also touches on the function of vacuum tubes and the difference between anode and cathode. The possibility of producing an arc in a perfect vacuum is also mentioned, with the explanation that gas species can still be excited and ionized in this environment. Finally, there is a brief discussion about the colors of electrons and the function of phosphors in a CRT TV.
iScience
466
i understand why there can be no breakdown, however "arcing" is just the transfer of electrons. a breakdown in air just provides a path for the electrons to take. But if you have two sharp surfaces, like a needle, pointing towards each other, separated by some distance d, let's even say that d is small, and if you apply a high enough voltage between the two needles, what is preventing the electrons on the anode surface from getting sapped off to the positively charged needle? why is air needed for this?
You don't need air to get a current flow. Without air, a few electrons will just flow from one side to the other - they cannot ionize more particles on their way. If the energy is not sufficient to kick out atoms on the other side, you don't get an arc, you just get a current flow.
In air you can see the ionized atoms. In a vacuum, there are no atoms or very few to ionize so you do not see the path of the electrons. Vacuum tubes operate with a voltage difference between the anode and cathode and work just fine in a vacuum, demonstrating that there is electron flow. Your CRT, a large vacuum tube, of which there is less and less around, operate also on the principle of electron flow within an evacuated chamber. How else would there be anything to see on the display.
you mean the electrons of the material on the anode side?
well i thought it worked on the same principle as a crooke's tube; ie electron guns (anode) ejecting electrons to some phosphor screen or .. something like that. but if the electrons are not visible, ie if there is no light emitting beam as seen in a crooke's tube, how can there be an image from invisible rays? this would imply some excitation mechanism on the receiving cathode end however to my knowledge this is not the case. To my knowledge there is the red electron beam, the green electron beam, and the blue electron beam. and the screen that is being shot at selects the percentages of each color. is this incorrect?
also, I've seen the electron supplier being called the cathode before, and I've seen it being called the anode before, which is it?..
An "anode" is usually a surface that has a higher potential than the "cathode". This means that either the anode is at a high positive potential, while the cathode is grounded, or the cathode is at a high negative potential while the anode (or the rest of the system) is grounded. The latter is a common configuration in accelerator facilities that produce or study photocathodes quantum efficiency.
To produce an "arc", which is a flash of light that is a result of vacuum breakdown, there has to be some gas specie in the vessel that are excited and/or ionized. Even in a "perfect vacuum", one can still have this. The field-emission electrons that were emitted from these sharp protrusions actually can be accelerated to rather high energies due to the external field. When they hit the surface of the anode, they can cause an increase in the temperature of the surface, thus liberating atoms/molecules into the vacuum. These are the gas specie that can be ionized by the bombarding electrons.
A detailed mechanism for this can be found in an extensive review of this process written by Fred Schwirzke's in "The Physics of Vacuum Breakdown" (IEEE, Plasma Science, 1993).
Zz.
but i don't understand, this could be self contradictory then, if i call the electron source (high negative potential) the anode.. i can call the other side the anode as well because it will be the high positive potential.
a perfect vacuum is one that has no matter in it.. and that do you mean by "field-emission electron emitted"? can you please reword?
Why would you do that? It is called cathode.
iScience, I think the How TV Works article in the electronics section of the howstuffworks web page may be worth a look before the thread continues. Maybe it's just me, but the thread is becoming unclear.
Coloured electrons? That would be very exotic. It's the phosphors they strike that govern the colour in a crt TV picture
A Cathode, by definition, is always a source of negative charges and an Anode is always a source of positive charges. If you have read anything other than that then you should suspect the source - or perhaps you should read it again more carefully.
Ha. Let's drag it back to clarity then. :smile:
sophiecentaur said:
A Cathode, by definition, is always a source of negative charges and an Anode is always a source of positive charges. If you have read anything other than that then you should suspect the source.
are you meaning to say that i should be suspicious of the source? or that the cathode is always the "source" of whatever context? ie, source of holes, source of electrons?
Please, please, please, read, read, read.
You should be suspicious of the source of information, not the source of electrons.
Also, I don't think you're going to get too far with this thread without some reading. Please take note of ZapperZ's citation and google cathode ray tube explanations, alternately you may watch a video here http://highered.mcgraw-hill.com/olcweb/cgi/pluginpop.cgi?it=swf::100%25::100%25::/sites/dl/free/0072512644/117354/01_Cathode_Ray_Tube.swf::Cathode%20Ray%20Tube and always double check information that is not peer reviewed.
Did you read my post? Is a Hole a negative ion? Or were you just being saucy?
If there is EVER a poster child to strengthen our constant insistence on citing one's source, this thread is it!
https://www.physicsforums.com/blog.php?b=2703
This could have easily been handled in the first few posts had the source of this mistake been cited (i.e. electrons coming out of anodes??!). Instead, we are now dealing with terminology (is the cathode an electron source, or is the anode an electron source) while the physics of vacuum breakdown is buried DEEEP down.
iScience: You could have easily revealed your source and we could have tackled it early on. Instead, you chose to simply counter it simply via unverified contradictions without a single valid citation.
This thread appears to have been answered (i.e. the original question, not the mistaken understanding of what one call an electron source). Thus, it is done.
And take note: I want to hear NO MORE COMPLAINTS the next time I ask someone to provide a valid reference as a source!
Zz.
FAQ: Why can there be no arcing in a perfect vacuum?
1. Why can't electricity arc in a perfect vacuum?
Arcing refers to the flow of electricity through air or another medium, creating a visible spark or discharge. In a perfect vacuum, there are no particles for the electricity to flow through, therefore there can be no arcing.
2. What exactly is a perfect vacuum?
A perfect vacuum is a space that contains absolutely no matter, including gas particles, dust, or any other substance. It is the complete absence of particles and is virtually impossible to achieve in real-world conditions.
3. Can electricity travel through a perfect vacuum at all?
While electricity cannot arc in a perfect vacuum, it can still travel in the form of electromagnetic waves. These waves, including radio waves and light, can travel through a vacuum as they do not require a medium to propagate.
4. Is it possible to create a perfect vacuum in a laboratory setting?
No, it is not possible to create a perfect vacuum in a laboratory setting. Even the most advanced vacuum chambers still contain trace amounts of gas particles. However, scientists can create very low-pressure environments, which are close to but not quite perfect vacuums.
5. Are there any practical applications for understanding why there can be no arcing in a perfect vacuum?
Yes, understanding the properties of a perfect vacuum is important in fields such as space exploration and particle physics. In space, the lack of particles in a vacuum allows spacecraft to travel without resistance. In particle accelerators, a vacuum is necessary to prevent interference from gas particles in the path of accelerated particles.
