What are the principal nuclear fusion reactions and their reaction rates?
In summary: This is a summary of the article. In summary, the researchers found that several reactions have high reaction rates, but only one reaches the necessary temperatures to be a practical fusion reactor fuel.
Astronuc
Staff Emeritus
2023 Award
22,186
6,854
Some principal nuclear fusion reactions which have been considered are:
1) D + T -> n + 4He
2) D + 3He -> H + 4He
3) D + D -> H + T / 3He + n
4) T + T -> 4He + 2n
5) T + 3He -> (various products)
6) H + 11B -> 3 (4He)
from G. H. Miley, H. Towner and N. Ivich, U. of Illinois Nucl. Eng. Report COO-2218-17 (1974)
with the reaction rates in the figure
Astronuc,
Thank You.
We see why D-T fusion is the leading contender.
Boron fusion is at the bottom, and doesn't overtake D-T fusion until
you get to Megavolt temperatures; that is temperatures at which the
average kinetic energy of the material is on the same order as the
nuclear binding energy.
Dr. Gregory Greenman
Physicist
I have seen the first five as being considered canidates for fusion reactors, but I had no clue Boron was a practical material.
I take that as: fusion occurs because kinetic energy forces the atoms together because it overcomes the repulsion between the nuclei. Is that what you are saying?
That's a condition for any of the fusion reaction.
No I was making a comment pertinent to the curve from Miley, et al;
posted by Astronuc.
The graph shows that the D-T reaction has the highest reaction rate of
any of the reactions being considered, while the Boron reaction has the
lowest - over most of the temperature range.
It is only at the extreme high end that the that the Boron reaction
goes from last place to first place. However, the graph shows that this
happens at temperatures around 1000 KeV = 1 MeV, and above.
At temperatures of 1 MeV; the average kinetic energy of the particles
will be the same order of magnitude as the nuclear binding energy.
That means that a 1 MeV temperature is EXTREMELY, EXTREMELY HOT -
even by fusion standards.
Physicist
I see that I'm mistake here.
Upon closer inspection, I see the (T + He3) [curve 5] and ( H + B-11 ) [ curve 6]
don't cross - they "kiss" but the (H + B-11 ) turns over. It is the (T + He3)
[curve 5] that ends up taking first place from the D-T reaction - again only
at extreme temperature.
Physicist
Physicist
Interesting:http://nuclearweaponarchive.org/Nwfaq/Nfaq4-3.html
Some handwaving:http://nuclearweaponarchive.org/Nwfaq/Nfaq4.html
and some first principles:http://nuclearweaponarchive.org/Nwfaq/Nfaq4-1.html#Nfaq4.1.7
if one cursors down, there are some graphs showing various reflector materials.
FAQ: What are the principal nuclear fusion reactions and their reaction rates?
What is nuclear fusion and how does it work?
Nuclear fusion is a process in which two or more atomic nuclei combine to form a heavier nucleus, releasing a large amount of energy. This process occurs in the core of stars, including our sun, where the intense heat and pressure cause hydrogen atoms to fuse together and form helium. This releases a tremendous amount of energy in the form of light and heat.
What are the potential benefits of nuclear fusion reactions?
Nuclear fusion reactions have the potential to provide a nearly limitless supply of clean energy. Unlike nuclear fission, which produces radioactive waste, fusion reactions produce no long-lasting or highly radioactive waste products. Additionally, fusion reactions do not emit greenhouse gases or contribute to air pollution.
What are the challenges in achieving sustainable nuclear fusion reactions?
The main challenge in achieving sustainable nuclear fusion reactions is creating and sustaining the extreme conditions necessary for fusion to occur. This includes heating the fuel to millions of degrees Celsius and containing it within a magnetic field to prevent it from touching the walls of the containment vessel. Scientists are also working to find materials that can withstand the intense heat and radiation produced by fusion reactions.
How close are we to achieving sustainable nuclear fusion reactions?
While significant progress has been made in the field of fusion energy, we are still decades away from achieving sustainable fusion reactions. Scientists have successfully produced small-scale fusion reactions, but the challenge lies in scaling up these reactions to produce a net energy gain. Many research projects and experiments are currently underway to address these challenges.
Are there any safety concerns associated with nuclear fusion reactions?
Nuclear fusion reactions are considered to be much safer than nuclear fission reactions, as they do not produce highly radioactive waste and do not have the potential for a runaway reaction. However, there are still some safety concerns related to handling and containing the extremely hot and high-energy fuel, as well as the potential for accidents or equipment failure. These concerns are being addressed through rigorous testing and safety protocols in fusion research facilities.
