Finding Time t for Instantaneous & Average Velocity: Particle Motion
  • Thread starter sammiyahc0
  • Tags
    Velocity
In summary, to find the time at which the instantaneous velocity is equal to the average velocity for the entire trip, you can use the formula (x2 - x1)/Δt where x represents the position. The average velocity is the change in position divided by the change in time. To find the instantaneous velocity, you can use the derivative of the position function, s(t). By setting the average velocity equal to the derivative, s'(t), and solving for t, you can determine the time at which the instantaneous velocity is equal to the average velocity.
sammiyahc0
The position of a particle moving in a straight line during a 10–second trip is s(t) = 3t2 − 3t + 5 cm.Find a time t at which the instantaneous velocity is equal to the average velocity for the entire trip.
Average velocity = (x2 - x1)/Δt
How do you find instantaneous velocity?
the derivative
what does x represent?
The position. x2 - x1 is the change in position. Your object starts at one point, and ten seconds later, it's somewhere else. That somewhere else is x2.
Your "s". The average speed, between t= 0 and t=10, is (s(10)- s(0))/(10 - 0). Calculate that, set it equal to s'(t) and solve for t.
Related to Finding Time t for Instantaneous & Average Velocity: Particle Motion
What is instantaneous velocity?
Instantaneous velocity is the velocity of an object at a specific moment in time. It is calculated by finding the slope of the tangent line on a position vs. time graph at that particular time.
How is instantaneous velocity different from average velocity?
Unlike average velocity, which is the total displacement divided by the total time, instantaneous velocity is the velocity at a specific instance in time. Average velocity takes into account the entire motion of an object, while instantaneous velocity focuses on a single point.
What is the formula for calculating instantaneous velocity?
The formula for calculating instantaneous velocity is v = lim Δt→0 (Δx/Δt), where v is velocity, Δx is displacement, and Δt is change in time. Essentially, it is the change in position divided by the change in time as the change in time approaches zero.
How is instantaneous velocity related to acceleration?
Instantaneous velocity and acceleration are closely related. Acceleration is the rate of change of velocity, so the instantaneous velocity at a specific time can be used to calculate the acceleration at that same time.
Why is instantaneous velocity important in physics?
Instantaneous velocity is important in physics because it allows us to understand the motion of objects at specific points in time. It also helps us to analyze and predict the behavior of objects in motion, and is a fundamental concept in many areas of physics, including kinematics, dynamics, and calculus-based mechanics.
  • Classical Physics
