- 12,480
- 3,614
What do you think about this explanation of EM-fields using SR?
https://www.youtube.com/watch?v=1TKSfAkWWN0
That tends to be the point that confuses most of the people that actually understand the argument being presented, so kudos on understanding the argument.Noyhcat said:I don't immediately get why the separation of the negatively charged particles doesn't contract from the man's reference frame, as they are moving relative to him, and therefore there would be a negative overall charge.
Thanks for the link, but I don't think it adresses Noyhcat's point, as it also starts out with the current already flowing and the wire being neutral in the lab frame.WannabeNewton said:As for Noyhcat, take a look here: http://physics.weber.edu/schroeder/mrr/MRRtalk.html as it explains things in a much more lucid manner than does the video commenter in my opinion.
DaleSpam said:That tends to be the point that confuses most of the people that actually understand the argument being presented, so kudos on understanding the argument.
The spacing of the electrons in the wire frame is determined by the observed fact that the wire is uncharged in the wire frame. This is a "boundary condition" that can be experimentally controlled.
What do you think about my idea in post #7, with both charge types moving in opposite directions in the wire's frame? Does it work out quantitatively? I don't think it would make the video more difficult to understand.pervect said:I'm afraid I don't know how to do 2) (explain the issue) without violating 3) (raising the height of the target audience).
What is the title of the book?WannabeNewton said:That's what Griffiths does in the aforementioned section.
Thanks, I will try to check it out. But the idea with both charge types moving is basically correct?WannabeNewton said:Introduction to Electrodynamics by David Griffiths: https://www.amazon.com/dp/013805326X/?tag=pfamazon01-20
atyy said:I like the video and DaleSpam's answer. One has to specify what is happening in one frame of reference, eg. there is a current in the wire, and the wire containing the current is uncharged in the lab frame. Relativity is a relationship between frames of reference, so if you specify what happens in one frame, it tells you what happens in another frame.
A.T. said:Thanks, I will try to check it out. But the idea with both charge types moving is basically correct?
WannabeNewton said:Yeah.
DaleSpam said:The spacing of the electrons in the wire frame is determined by the observed fact that the wire is uncharged in the wire frame. This is a "boundary condition" that can be experimentally controlled.
Once the spacing is determined in the wire frame, then it is determined in all frames.
That would only be true if the electrons were rigidly attached to each other, which they are not. Charge carriers in a conductor are, by definition, very mobile and able to change their position and spacing in response to any fields.universal_101 said:I think role of physics is in finding relations(mostly logical) between observations, for example what should we observe if we stop the current, and we all know it is an observed fact that the wire still remains electrically neutral. The point is, according to the SR length contraction explanation, it should not be neutral when we stop the current if it were to be neutral when there was a current.
Yes, it works out quantitatively. Using units where c=1 the current four-vector or four-current is ##J=(\rho,\mathbf{j})## where ρ is the charge density and j is the current density.A.T. said:What do you think about my idea in post #7, with both charge types moving in opposite directions in the wire's frame? Does it work out quantitatively?
DaleSpam said:That would only be true if the electrons were rigidly attached to each other, which they are not. Charge carriers in a conductor are, by definition, very mobile and able to change their position and spacing in response to any fields.
In the wire frame the wire is electrically neutral. The spacing of the charges must reflect that boundary condition.
If any additional electrons are required then they would come from the battery or other power source. However, usually no additional electrons are required. Usually, charge is just redistributed around the loop.universal_101 said:So if it is the spacing of the electrons that keeps changing while switching on and off the current, what do you suggest happens for a closed loop of current wire! ,where does the extra electrons go or come from ?
How does a particular redistribution of charges(electrons), as a result of the presence or absence of net electric field in the wire in a single direction, cancels out the effect of length contraction due to motion of electrons everywhere. A particular redistribution can only cancel out the effects at a particular point and not everywhere.DaleSpam said:If any additional electrons are required then they would come from the battery or other power source. However, usually no additional electrons are required. Usually, charge is just redistributed around the loop.
Consider an uncharged square loop of unit length (units where c=1) and width carrying a unit current clockwise. In the top wire the four-current is Jt=(0,1,0,0). In the right wire the four-current is Jr=(0,0,-1,0). In the bottom wire the four-current is Jb=(0,-1,0,0). And in the left wire the four current is Jl=(0,0,1,0).universal_101 said:How does a particular redistribution of charges(electrons), as a result of the presence or absence of net electric field in the wire in a single direction, cancels out the effect of length contraction due to motion of electrons everywhere. A particular redistribution can only cancel out the effects at a particular point and not everywhere.
Clearly not. I just mentioned it because there are times when there is a net charge and in such cases the charge comes from the power source. I never said that batteries are always needed, and in fact, I specifically said that usually the power source is not needed for the explanation.universal_101 said:And you already know we don't always need the batteries to produce the current !
Seriously! I thought we were discussing switching the current on and off, what you are describing is Lorentz invariant nature of current in two different frames.DaleSpam said:Consider an uncharged square loop of unit length (units where c=1) and width carrying a unit current clockwise. In the top wire the four-current is Jt=(0,1,0,0). In the right wire the four-current is Jr=(0,0,-1,0). In the bottom wire the four-current is Jb=(0,-1,0,0). And in the left wire the four current is Jl=(0,0,1,0).
Now, if we go to a frame moving at .6 c wrt the wire then the four-currents become Jt'=(-.75,1.25,0,0), Jr'=(0,0,-1,0), Jb'=(.75,-1.25,0,0), Jl'=(0,0,1,0). So the excess negative charge density on the top is balanced by an excess positive charge density on the bottom, with no net charge for the whole loop.
I think i was rather vague in my last post, what I meant was where do you get the extra electrons when the current is produced by the changing magnetic field, or let's say a current carrying superconducting wire, where current is due to changing magnetic field.DaleSpam said:Clearly not. I just mentioned it because there are times when there is a net charge and in such cases the charge comes from the power source. I never said that batteries are always needed, and in fact, I specifically said that usually the power source is not needed for the explanation.
Your posts are rather vague. You should carefully specify what you are interested in including the reference frame. I believe that I answered the question you asked.universal_101 said:Seriously! I thought we were discussing switching the current on and off, what you are describing is Lorentz invariant nature of current in two different frames.
What extra electrons? The point of the exercise is to show that there aren't any extra electrons.universal_101 said:what I meant was where do you get the extra electrons when the current is produced by the changing magnetic field, or let's say a current carrying superconducting wire, where current is due to changing magnetic field.
DrGreg said:In the rest frame of the wire, the spacing of electrons does not change, so no extra electrons are needed.
In an inertial frame in which the wire is moving and the electrons along one straight part of the wire are at rest, electrons in a different part of the closed loop (the return wire, if you like) are not at rest. So, in this frame, the electron density isn't constant: it's lower where the electrons are at rest and higher where the electrons are moving. Averaged out over the whole loop, the total number of electrons is unchanged.
I posted the diagram below over 18 months ago in a thread you took part in:
Click here for explanation in old thread
I'm asking same as the above concerned, except i don't get it ever.Noyhcat said:I don't immediately get why the separation of the negatively charged particles doesn't contract from the man's reference frame, as they are moving relative to him, and therefore there would be a negative overall charge.
Your response, ignoring the issue and instead you take your starting point with the current already flowing, ignoring how did you get there(which is incompatible with the current model and SR, and this is what i thought we were discussing).DaleSpam said:That tends to be the point that confuses most of the people that actually understand the argument being presented, so kudos on understanding the argument.
For example, instead of having an uncharged wire you could give the wire an excess positive charge by putting it at a very high voltage. If you did that then the spacing between electrons in the wire frame would be greater than the spacing between protons.
Pervect addressing the issue, but lost me on the difference between 2 and 3.pervect said:This is related to what I was trying to say earlier.
There are three possibilities:
1) Ignore the issue, which is what the video has done. Then you'll get questions like Noyhcat's.
2) Try to explain this in the video - which will raise the bar on the target audience
3) Raise the bar on the target as far as the "target audience" is concerned.
Overall, I favor 3, because ignoring the issue doesn't really work, and I'm afraid I don't know how to do 2) (explain the issue) without violating 3) (raising the height of the target audience).
Again taking the first option.atyy said:Maybe something like this:
We know that in the lab frame we can set up a wire with a current in it. We know we can do this in a way such that the wire is electrically neutral, because the wire neither attracts nor repels a charged particle that is stationary in the lab frame. Since we have set up the wire to be electrically neutral in the lab frame, the distance between positive charges is the same as the distance between negative charges in the lab frame. Now, will the wire attract or repel a charged particle that is moving in the lab frame? If the only force that affects charged particles is the electric force, since the wire is electrically neutral in the lab frame, it will neither attract nor repel a moving charged particle.
I think this summary shows what is or was my concern.DaleSpam said:I'm still not sure what you are asking then. In the wire's frame with no current the wire is uncharged. In the wire's frame with current the wire is uncharged. There is no difference in charge density in either case, so no excess or deficit of charges to be accounted for. If you aren't asking about any other frame then the scenario seems completely and obviously unobjectionable.
Can you clearly and explicitly state what your objection is?
Yes of-course, atleast in the present understanding of the situation in mainstream and that is because of the length contraction and supposedly it(LC) can also increase the density of matter by making it contract in the direction of relative motion !Drakkith said:Imagine we have a bunch of space probes (or whatever object you like) moving through space in a very long line, all at the same velocity. Observer A is moving parallel to the line of probes and at the same velocity while observer B is our stationary rest frame. Is the distance between the probes different for observers A and B?
universal_101 said:And how do you explain, if the current carrying wire is made of highly doped n-type semiconductor, when you don't have any holes to go by.
