Am I doing this torque problem right?
  • Thread starter gamegene9060
  • Tags
    Torque
In summary: Everything makes sense now. In summary, the conversation discusses the concept of calculating torque using the cross product of position and force vectors. The correct method is using the perpendicular component of the force and the length of the beam, as shown in the first picture. The second picture shows a similar example using distances along the floor, which is also a valid method. However, it is important to thoroughly understand one method rather than learning multiple variations. Moments and torques are interchangeable terms, and the proper equilibrium equations must be written to solve a problem.
gamegene9060
http://i.imgur.com/KXYnkqL.png
I drew up the picture in cad so that you can look at it. The find torque would i take the cross product of the length of the beam (10m) and the component of the force that is applied perpendicular to the beam (50Nsin45°)? I then get ≈353.55Nm and then use the right hand rule to find that the direction is out of the page (or screen).
Is that all correct, cause another student said that I am supposed to multiply the horizontal component of the beam by the portion of the force perpendicular to the beam (10mcos45° * 50Nsin45) to find the magnitude of the torque. This seems backward to me cause that seems like a dot product and I thought that torque was defined as the cross product of the position vector and the force vector.
When calculating T = r x F, both r and F must be expressed in vector form. For your example, what are the r and F vectors? Forget about street physics. If you apply the correct formula with the correct data, you will get the correct value of the torque.
I'm sorry, you lost me, it has been a couple of years since I have done none street physics honestly. But it is the cross product of r and F vectors then? Because this other student is saying that you need to use the perpendicular distance (magnitude) instead of r (both a vector sum and not restrained to just the vertical or horizontal axis) and simply multiply it by the force and that still seems wrong to me. So I think that you are saying my approach is correct yet and oversimplification of the mechanics at work?
You are right, he is wrong.
alright, thank you. Now the same conversation but a new example, and he still insists that he is correct.
http://i.imgur.com/5iA1G4i.jpg
A ladder that is 10ft long, weighs 30lbs, and has a 180 lb man standing 5ft up it, resting at 60 degrees on a wall. I would approach this problem by first calculating the torque from the stop at the floor
180lbs cos60° * 2.5ft + 30lbs cos60° * 10ft = Fwall sin60° * 10ft (all trig functions used to find component of force that is perpendicular to the ladder)
and when I solve for Fwall i get ≈43.3lbs
then I would simply set the force of friction (or as he has in his problem, the person standing at the bottom of the ladder on a frictionless floor, god know how that works, lol) to that as they are the only horizontal forces, then the normal force from the ground would be the two weights added together. So Ffriction is also 43.3lbs and Fnormal is 210lbs.
He claims that you would do the same except use this equation instead at the beginning
180lbs cos60° * 2.5ft cos60° + 30lbs cos60° * 10ft cos60° = Fwall sin60° * 10ft sin60°
Solve Fwall for 25lbs
This does not make sense to me, yet he has actually showed this to me in his textbook. I have noticed that he always calls them moments instead of torques, but I thought that was just an old engineering convention but still meant the same thing as a torque. I have never heard of a dot product of a position vector and a force vector.
http://i.imgur.com/im0Z9AP.jpg
I find this confusing as I was a physics major until I ran out of money and I never heard of this stuff, yet he has a book written by a Dr. Thomas Burns that says I am wrong. Where is the discrepancy?
Moments and torques are the same thing. 'Torque' is the preferred term when talking about the energy generated by an engine, for example.
You can calculate moments as you have described in the example above, by getting the components of the forces acting normal to the ladder, or you can calculate the distances between forces measured along the floor. Taking moments about the foot of the ladder using these distances and the forces as shown in your second picture can be used to solve for the unknown reactions. It's just a matter of writing the proper equilibrium equations.
Your problem can also be solved using the old standby T = r x F. The important thing is to learn a method thoroughly which can be used to solve a problem. There may be several superficially different ways to approach a solution, but it is not required that you learn all the variations in these methods.
BTW, your equation doesn't match the diagram in the first picture: the weight of the ladder is centered at 5 feet from the end, not 10 feet. This mistake is also in your friend's equation.
For Fwall, I get 34.6 lbs
As long as ƩF = 0 and ƩM = 0, you are golden regardless of solution method.
ok, thank you for clearing that up. And woops, didnt realize i accidentally wrote down 10 instead of 5, good job picking that up
FAQ: Am I doing this torque problem right?
1.
What is torque and how is it calculated?
Torque is a measure of how much a force acting on an object causes that object to rotate. It is calculated by multiplying the force applied by the distance from the point of rotation, or pivot point, to the point where the force is applied. The unit of torque is Newton-meters (Nm).
2.
What are the key equations for solving torque problems?
The key equations for solving torque problems are:
  • Torque = Force x Distance
  • Net torque = Sum of all individual torques
  • If the object is in rotational equilibrium, then the net torque must equal zero.
3.
How do I know if I am using the correct units in my torque problem?
The units of torque are Newton-meters (Nm), so make sure that the units for force are in Newtons (N) and the units for distance are in meters (m). If the given values are in different units, you may need to convert them to the appropriate units before plugging them into the equation.
4.
What is the difference between clockwise and counterclockwise torque?
Clockwise torque causes an object to rotate in a clockwise direction, while counterclockwise torque causes an object to rotate in a counterclockwise direction. This is determined by the direction of the force relative to the pivot point.
5.
How can I check if my answer for a torque problem is correct?
You can check your answer by making sure that it is in the correct unit of torque (Nm) and by double-checking your calculations. You can also plug your answer back into the original equation to see if it results in the given values for force and distance. Lastly, it is always a good idea to have someone else review your work to catch any mistakes or errors.
