CERN - new radiation detector technology
In summary, this radiation detector is a High Voltage CMOS technology that is being researched for future applications in particle physics and other areas. It is cheaper, has a higher radiation tolerance, and has a higher signal to noise ratio.
CERN-tech
Where would you use our new radiation detector?
We are a student team from the Vienna University of Economics and Business. Currently we are working on project with the research center CERN and try to find different application possibilities for an innovative technology by interviewing potential users.
This technology is a High Voltage (ca. 120 V) CMOS radiation detector. It can detect charged particles and electromagnetic radiation. The technology’s benefits are the following:
- cheaper
- high radiation tolerance
- higher precision
- space saving
Due to your expertise we would like to ask, if you could think of ideas for application fields – no problem if they are utopian (feasibility check is done in the next step) . Maybe you also know some persons we could interview about this topic. Thanks!
HV CMOS detectors are investigated for the upgrades of the LHC experiments (at least LHCb, ATLAS and CMS, no idea about ALICE), the future Mu3e experiment and probably some more experiments.
Some numbers I remember:
If you have pixel sizes below (100µm)2, timing better than 25 ns, radiation hardness of the order of 1016 neq/cm2 fluence and 1GRad, a good signal to noise ratio after irradiation, some other factors I forgot and if several square meters of those detectors are not too expensive (<100€/cm2), the LHC experiments could be interested.
Oh, and the detectors should be thin (<300µm) to reduce multiple scattering.
For mu3e, most requirements are not so strict, but they plan to thin their sensors to less than 50µm if I remember correctly.
The upgrade coordinators of the experiments, or spokespersons, or whoever is somehow responsible for the project, will know who to contact.
Thank you very much for your answer!
Well, actually it is the technology developed for the LHC we are trying to find further applications for.
Maybe you can think of a list of similar or far different areas, where you could use this detector?
This is aun unanswerable question. Look at MFB's response - he gives numbers for pixel size, radiation hardness, cost, etc. You give none of those things - just the technology behind it. It would be like saying "We have a new vehicle, and it uses 10 liter diesel engine. What would you use it for?" What we really need to know is if this is a car, or a boat, or a hovercraft, or a small plane...
You need to post some specifics of what this technology can actually do, not the process by which it is made.
Ok, thank you Vanadium 50 for the feedback! I try to give some numbers:
all factors mfb mentioned apply to the technology!
radiation hardness of the order of 10^16 neq/cm2 fluence and 1GRad
thin (<300µm)
and some more:
120Volt
energy ~10keV
40 MHz (speed)
material = silicium
Does that help? And maybe remember it does not have to work 100% for sure, it should just be a brainstorming of fields, where particle detectors are used.
"Where particle detectors are used"
Apart from accelerator experiments and other particle physics experiments (dark matter, neutrinos, ...), everywhere where particles are accelerated for other reasons (medicine, industry, ...), some astronomy experiments, everywhere where X-rays are, PET scans (but then we are talking about ps timing), and all applications I forgot.
Related to CERN - new radiation detector technology
1. What is CERN and what do they do?
CERN, or the European Organization for Nuclear Research, is a European research organization that operates the largest particle physics laboratory in the world. It is located in Geneva, Switzerland and its main focus is to study the fundamental particles and forces that make up our universe.
2. What is the new radiation detector technology being developed at CERN?
The new radiation detector technology being developed at CERN is called the Time Projection Chamber (TPC). It is a type of particle detector that uses a combination of electric and magnetic fields to track and measure the paths of charged particles.
3. How is the TPC different from other radiation detectors?
The TPC is unique in that it can track the path of a particle in three dimensions, as well as measure its energy and velocity. This allows for more precise and detailed measurements of particle interactions, which can provide valuable insights into the fundamental building blocks of our universe.
4. What are the potential applications of this new radiation detector technology?
The TPC has potential applications in a variety of fields, including medical imaging, nuclear security, and environmental monitoring. It can also be used in particle accelerators to improve their efficiency and accuracy, leading to advancements in high-energy physics research.
5. When will the TPC be available for use?
The TPC is currently in the research and development phase at CERN. It is expected to be available for use in experiments within the next few years, but further testing and improvements may be necessary before it is fully implemented in various applications.
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Beyond the Standard Models
  • Nuclear Engineering
9K
