False Fallacy: Adding Powers of 2 to Infinity Equals -1
  • Thread starter anis91
In summary, the conversation discusses a mathematical fallacy where adding powers of 2 to infinity is equated to -1. The fallacy exploits the fact that infinity can be of different sizes, but this is proven to be false as two countable infinities cannot be of different sizes. The conversation also delves into the concept of divergent series and the extended real number system. It is concluded that the fallacy is due to an undefined expression and the impossibility of assigning a consistent value to infinity minus infinity. The idea of different sizes of infinity is also addressed and disproved.
anis91
hey guys this day my friend showed me a falacy that stunned my mind, it was like this:
let's say we add powers of 2 til the infinity,
so 1+2+4+8+16+32...
we don't know the answer, right? but we know we can multiply the whole thing by one, so
1*(1+2+4+8+16+32...) = 1*1+1*2+1*4... same thing
now, we know that 1 = 2-1,
so
1*(1+2+4+8+16+32...) = (2-1)*(1+2+4+8+16+32...)
1+2+4+8+16+32... = 2+4+8+16+32+64... -1-2-4-8-16-32
almost every numbers and it's negative counterpart cancel each other
so
1+2+4+8+16+32... = [STRIKE]2+4+8+16+32+64[/STRIKE]...-1[STRIKE]-2-4-8-16-32[/STRIKE]
so
1+2+4+8+16+32...= -1
i want a convincing reason why this is false, a very convincing one (e.g.: not logic)
Mathematics news on Phys.org
The falacy is the fact that they math you did assumes that the 2 sets are of the same size. When they are infact not.
the 2+4+8... set is larger than the -1-2-4 etc one by 1 term
Since they both go to infinity that extra term has to also be infinity and the answer would therefore be infinty.
The falacy is exploiting the fact that infinity can be of different sizes
You can also do it this way:
1 + 2 + 4 + 8 + ... = 1 + (-1 + 3) + (-3 + 7) + (-7 + 15) + ...
= (1 - 1) + (3 - 3) + (7 - 7) + ...
= 0
The real answer is that an infinite sum is inherently not well defined. You cannot add an infinite set of numbers together. So, you have to come up with a formal definition of what you mean by an infinite sum. See, for example:
http://en.wikipedia.org/wiki/Series_(mathematics)
let's keep adding these number til infinity...
every number of the set 2+4+8... is 2*|a| it's counter part from the set -1-2-4... let's say it is its double.
now, pretend that we reached a VERY large number in the first set, it will be double it's counterpart, right?
now since these series are powers of two (with the second being negative ones) even if we reach a very high number, in the negative series, we'll find one right AFTER it's counterpart that cancels it, up until infinity, so why bother since we will always find a number that will cancel it out?
so if all numbers cancel out each other, none of them will stay, except for -1, thus, you didn't convince me enough.
HAHA good point
Well frame it in another way then
You have 2 sets of number
2,4,8 etc call this A
and -1,-2,-4 etc call this B
In your original argument you say that A[N] + B[N-1] = 0 leaving you with just B[0] = -1
Well what if instead you did A[N] + B[N] (which is in my mind more correct cause the size of both sets are same size)
That leaves you with 1,2,4... the sum of which would be infinty
in the first method as I tried to state before you'll always have 1 left over in A that you didnt account for even if you extend it to infinty, but I think this way illistrates it better :)
Likes 1 person
so 1+2+4+8+16+32...
This is wrong, as (1 + 2 + 4 + ...) is NOT a number. So, you can't multiply it by 1.
This makes absolutely no sense, two countable infinities cannot be of different sizes.
It is possible to enlarge the set of real numbers to include ##\infty## and ##-\infty##, resulting in the extended real number system. In this system, ##1 + 2 + 4 + \ldots = \infty##, and it is perfectly valid to multiply this by ##1## to obtain ##1 \cdot \infty = \infty##. The problem isn't really with that step. The next step, however, is problematic. Expressions of the form ##\infty - \infty## are undefined, even in the extended real number system. So this is undefined:
$$(2 + 4 + 8 + \ldots) - (1 + 2 + 4 + \ldots)$$
because both of the parenthesized items are ##\infty##.
The reason ##\infty - \infty## is undefined is because there is no way to define it consistently. To see this, suppose we assigned some definite value, ##\infty - \infty = x##, where ##x## is some real number. Now ##1 + \infty = \infty##, so we may write
$$x = \infty - \infty = (1 + \infty) - \infty = 1 + (\infty - \infty) = 1 + x$$
But ##x = 1 + x## is impossible for any real number ##x##: subtracting ##x## from both sides, we get ##0 = 1##.
Likes 1 person
yes they can,
don't believe me?
watch this vid, until the end, it proves that some infinities are bigger than other infinities
http://www.youtube.com/watch?v=A-QoutHCu4o
anis91 said:
yes they can,
don't believe me?
Yes, there are different sizes of infinities. The reals are "bigger" than the integers, for example.
However, 1MileCrash is absolutely correct. Two countably infinite sets cannot be of different sizes because one can construct a one-to-one, onto mapping between them. All countably infinite sets have the same cardinality, ##\aleph_0##, or aleph-null. Read about Hilbert's hotel.
anis91 said:
yes they can,
don't believe me?
To be countable means that it is the same size as the naturals (i.e. a bijection to the naturals). That's the definition of countable.
If something is larger then it is not countable.
jbunniii said:
It is possible to enlarge the set of real numbers to include ##\infty## and ##-\infty##, resulting in the extended real number system. In this system, ##1 + 2 + 4 + \ldots = \infty##, and it is perfectly valid to multiply this by ##1## to obtain ##1 \cdot \infty = \infty##. The problem isn't really with that step. .
The laws of arithmetic cover only finite additions and multiplications. There is no rule of arithmetic to tell you how to add an infinite number of numbers together.
So, until you've defined what is meant by 1 + 2 + 3 ... you have a recipe for fallacies, contradictions and error.
Maybe it's too austere to say that 1 + 2 + 3 ... is simply not defined, as that takes all the fun out of proving and disproving these wacky results!
Likes 1 person
It's defined as an ordered formal sum. Whether it is convergent is a completely different question.
Nonsense. Adding an infinite number of numbers together is what infinite series, or for that matter, Riemann integration, are all about. 1/2+1/4+1/8+… might have been confusing to Zeno, but it should not be confusing to those living in the 21st century. It is one.
Infinite sums can result in some apparently weird results. One is the loss of associativity for conditionally convergent series. An absolutely convergent series will always add to the same number no matter how the terms are rearranged. Rearrange the terms of 1/2+1/4+1/8+… and you will always get one. That is no longer the case with conditionally convergent series. Consider the series 1-1/2+1/3-1/4+…, or ##\sum_{n=1}^{\infty} (-1)^{n+1}/n##. This is log(2). Rearrange the terms in the series and you'll get another result. You can get any result you want! So don't rearrange the terms. Addition is not necessarily associative when it comes to infinite series.
What about non-convergent series such as 1+2+4+8+…, 1+2+3+4+…, or 1+1+1+1+…? One obvious answer is that these are divergent series. The sum is infinite for each of these series, end of story. These obvious answers did not stop some of the best minds in mathematics such as Euler, Abel, and Hardy from toying with such series. These can rigorously be given finite values.
Divergent series such as these occasionally appear in advanced physics. The regularization techniques used to get rid of those infinities were crucial in developing quantum field theory. "As everyone knows, 1+1+1+1+…=-1/2."
One key problem with aligning quantum mechanics and general relativity is that these infinities keep popping up and the regularization techniques that worked so well with QED don't work in this regard.
Hey, steady on Mentor. There's no need to get insulting. When did infinite series and Riemann integration become part of "arithmetic"?
a(b + c) = ab + ac (is the distributive law)
But:
[itex]a\sum_{i=1}^{\infty}b_i = \sum_{i=1}^{\infty}ab_i[/itex]
Can only be given meaning through defining limits and mathematical analysis. In particular, it cannot be deduced from the distributive law.
So, unless you are using the limit of partial sums, then high-school students are going to run into these paradoxes - essentially by assuming that there is nothing untoward with infinite sums.
My point is that for those without a grasp of mathematical analysis and the rigorous treatment of infinite series, an infinite sum is (at that point in their mathematical development) undefined.
In the same way, once someone has mastered infinite countable sums, they may run into problems with, say:
[itex]\sum_{i \in R}b_i[/itex]
Until they realize that this is not defined by "infinite series" and a new definition of what this sum might mean is required.
anis91 said:
yes they can,
don't believe me?
Not to "echo" the others, but in both series, we have a list of numbers. There is a first place, second place, third place, and so on.
The only difference between the two series is what symbol "occupies" the places, and that surely means nothing for its cardinality of the series.
In other words, you can't have two infinite "lists" and have them be of different sizes. Being bigger than this type of infinity means (essentially) that it cannot be put into a list in that way.
(2-1)*(1+2+4+8+16+32...) does not equal 2+4+8+16+32+64... -1-2-4-8-16-32
Related to False Fallacy: Adding Powers of 2 to Infinity Equals -1
What is the False Fallacy: Adding Powers of 2 to Infinity Equals -1?
The False Fallacy: Adding Powers of 2 to Infinity Equals -1 is a mathematical concept that claims that the sum of all powers of 2 (2^1 + 2^2 + 2^3 + ...) up to infinity is equal to -1. This is not a valid mathematical equation and is considered a false fallacy.
Why is this considered a false fallacy?
This is considered a false fallacy because it goes against the principles of mathematics. In mathematics, infinity is not considered a real number and thus cannot be treated as such in equations. Additionally, the sum of any infinite series must converge to a finite value, not -1.
What are the consequences of believing in this false fallacy?
Believing in this false fallacy can lead to incorrect mathematical calculations and misunderstandings. It can also lead to the acceptance of other false mathematical claims, which can be harmful in fields such as science and engineering where precision and accuracy are crucial.
Why do some people still believe in this false fallacy?
Some people may still believe in this false fallacy due to a misunderstanding of mathematical concepts or a lack of mathematical knowledge. It may also be perpetuated by misinformation or incorrect teachings.
What is the correct mathematical explanation for the sum of all powers of 2?
The sum of all powers of 2 (2^1 + 2^2 + 2^3 + ...) up to infinity is undefined. However, it can be approximated to a large value, but it will never converge to a finite value. This can be mathematically represented by the limit of the series as it approaches infinity.
  • General Math
