- 5,844
- 552
The "definition" of synchronized clocks
This is a purely terminological question. Consider the following setup: we have two inertial observers A and B at rest with respect to one another each equipped with a clock (clock A and clock B respectively), a means of exchanging light signals between one another, and each equipped with a profuse of meter sticks. Using the meter sticks, the distance between A and B is established as ##L##. Furthermore, let ##\gamma_A##, ##\gamma_B## be the worldlines of A and B respectively, with ##t_A:\gamma_A \rightarrow \mathbb{R}##, ##t_B:\gamma_B \rightarrow \mathbb{R}## the local time (i.e. proper time) indicated by the hands of clocks A and B along the respective worldlines of A and B. We assume that the clocks are ideal i.e. isochronous.
Let A emit a light signal at an event ##p## on ##\gamma_A## with local time ##t_A## that is received at an event ##q## in space-time whereupon the signal is reflected and arrives back to A at an event ##p'## on ##\gamma_A## with local time ##t'_A##.
We define clocks A and B to be synchronized if, when ##q## is an event on ##\gamma_B## with local time ##t_B##, we have ##t_B = t_A + \frac{L}{c}##. If ##t_B \neq t_A + \frac{L}{c}## then B can instantaneously readjust the hand of clock B so as to read ##t_B = t_A + \frac{L}{c}##. Thus clocks A and B can always be synchronized (that this is a consistent method of synchronization was proven by Weyl, where consistent means symmetric and transitive). This is of course Poincare's operational procedure of clock synchronization. See the following paper: http://www.dma.unifi.it/~minguzzi/salamanca.pdf
But to what extent is this operational procedure of clock synchronization congruent to the intuitive notion of synchronized clocks? What I mean by this is, we normally think of clock A and clock B as being synchronized if whenever an event ##q## on ##\gamma_B## is simultaneous with an event ##p''## on ##\gamma_A##, clock B's hand at ##q## is in the same position as clock A's hand at ##p''## i.e. ##t_B = t''_A##. But this presupposes a notion of simultaneity that Poincare's operational procedure of clock synchronization does not. So if A and B use Poincare's synchronization procedure then in what sense are clocks A and B "synchronized" if no convention of simultaneity is defined?
Consider for example the following passage from the text "Concepts of Simultaneity: From Antiquity to Einstein and Beyond"-Jammer:
"As stated in the beginning of this chapter, we define 'simultaneity' as the 'temporal coincidence of events.' Assuming we have two clocks we regard the coincidence of their hands with certain numbers on their dials as an event. Then we can say that the clocks are 'synchronized at a certain moment of time' if and only if at that moment of time the hands of the two clocks are in the same position, that is, they indicate the same time... If the positions of the hands of the two clocks are the same at a certain moment of time they constitute two, generally separated, simultaneous events. It is therefore clear that the notion of 'synchronism' involves or presupposes the concept of 'simultaneity.'" (p.13)
Immediately we see a problem because the phrases "at a certain moment of time" and "at that moment of time" have no meaning whatsoever as given in the above passage; there is no absolute global time function available for us to make any sense of such phrases. Therefore at best one can interpret the definition of synchrony given in the passage for clocks A and B as stating that clocks A and B are synchronized if whenever an event ##q## on ##\gamma_B## is simultaneous with an event ##p''## on ##\gamma_A##, we have ##t_B = t''_A## which is exactly the "intuitive" definition of synchrony stated above. Therefore the "intuitive" definition of synchrony only makes sense if we have a convention of simultaneity to begin with.
Now if we adopt the ##\epsilon = \frac{1}{2}## convention of simultaneity, that is, ##t_A'' = \frac{1}{2}(t_A + t'_A)##, and consider the "intuitive" notion of clock synchronization then clocks A and B are synchronized if clock B's hand at ##q## reads the same time as clock A's hand at ##p''## meaning ##t_B = t_A + \frac{L}{c}## which follows trivially from the two-way speed of light. In other words, if we adopt the ##\epsilon = \frac{1}{2}## simultaneity convention and A and B want to synchronize their clocks in the sense that clock A's local time and clock B's local time are equal at simultaneous events, then A and B can arrange for this explicitly by using Poincare's operational method of synchronization.
But if we have no notion of simultaneity available then, as asked above, what does it even mean for clocks A and B to be "synchronized" after A and B employ Poincare's operational method of synchronization? What does it even mean to call this a synchronization convention?
I ask this terminological question partly because of the paper I linked above and partly because of the way some relativity texts make it seem like simultaneity and clock synchronization are equivalent from a physical (intuitive) standpoint.
For example, Friedman states in his text "Foundations of Space-time Theories: Relativistic Physics and Philosophy of Science" that "Our problem is to synchronize the clock at A with the clock at B, to say when, according to A-time, the light signal arrives at B. In other words, we must determine which event between ##t_A## and ##t'_A## at A is simultaneous (in F) with ##t_B##." (p.166)
Clearly a definition of simultaneity allows for us to adopt the "intuitive" definition of synchronized clocks and subsequently derive an operational means of actually synchronizing clocks in accordance with this "intuitive" definition of synchronized clocks.
But what about the converse? That is, does it even make sense to define some convention of clock synchronization, such as Poincare's, and then use this convention to define simultaneity of events, when it doesn't even make sense to talk about synchrony intuitively without simultaneity being defined in the first place? How should one interpret the term "synchronization" if such a procedure is adopted?
Sorry for being verbose and desultory but this terminological detail has me confused. Thanks in advance.
