How can I calculate the speed needed for a 30-year journey to Alpha Centauri?
  • Thread starter texasman1979
  • Tags
    Speed Year
In summary: The formula is F=ma (force = mass * acceleration). So, if you want to accelerate 130 t at 1g, you multiply 130 t by 9.8 m/s^2, and get 1274 kN.
texasman1979
47
related to my other thread: https://www.physicsforums.com/showthread.php?t=732462
Here's the hypothetical scenario:
A trip from Earth to alpha centauri in 30 years. Steadily accelerating to half way then turning around and steadily decelerating.
Trying to figure out a way to figure speeds along the time line.
I don't want the answer, but the math formula to figure it out.
Thx.
30 years -- time line
4.2 lightyears -- relative distance to stars
Astronomy news on Phys.org
calc thrust non rocket engine
related to my other thread: https://www.physicsforums.com/showthread.php?t=732459
Writing a fiction scifi book.
The spacecraft will have a magnetic based propulsion system. In the book the spacecraft weighs 130 metric tons.
I would like some educated numbers to go by for figuring thrust and speed from 0 thrust to 1g.
Obviously, with a non rocket type propulsion there would be no mass loss as fuel is burned cause there wouldn't be any fuel. So i don't divulge too much of the story line pretend it is solar based energy making electricity making a magnetic field.
This is a book I'm writing, but there is some real science behind it and I'm wanting it to be as real as it can be.
Thx.
I merged your threads, as the questions are closely related. This is not really astrophysics, so the thread could get moved.
For a uniform acceleration "a", starting at rest, and neglecting relativistic effects, the distance traveled after time t is given by ##s=\frac{1}{2} a t^2##. You know t and s (half the distance and time), so you can calculate a. With that, the velocity is just acceleration*time.
The deceleration part works the same way, just backwards.
F=m*a
Calculate a, and you can get F.
What is a "magnetic based propulsion system"? You have to accelerate something backwards. Mass from the rocket, mass or light incoming from some external source, or interstellar medium. You do need fuel to power your ship - even if you have a system that does not need reaction mass.
two parts to this.
In space, once you are going 1,000,000 miles per hour you are going to continue going 1,000,000 miles per hour till some force acts to modify that.
In my story and inventor makes a new type of ship set in the next few decades. As far as the details to that, you'll have to read the book. :)
So, a 30 year trip to Alpha Centauri, binary star system. The character and his craft will begin in Earth's orbit and sling shot around a couple planets to achieve system exit velocity. Then he will continue to accelerate toward Alpha Centauri for 15 years and then turn around and decelerate the next 15 years.
At the same time the ship weighs 130 metric tons. That's 286600.6 pounds. How many pounds of thrust would be needed to gain 1 gforce from the acceleration?
I am having a bit of trouble relating your math with the principles I have stated. I would help me a great deal if you related the math to my particular problem so i can relate the two better.
thx.
That's the m in F=ma. Convert to kilograms.
that's the acceleration a(use the value in m/s^2)
Plug these in and you get the force(thrust) in Newtons.
Same with s=at^2. s is half the distance to αCen in metres; a is the acceleration you're looking for; t is the time to get half way there, in seconds. Just plug the values in.
By the way, at 1g constant acceleration, you'll get there in 3.5 years on-board time, and 5.8 Earth time, as relativistic effects start to play a role at that speeds.
To get there in 30 years, you need about 0.02 g acceleration(here, relativistic effects are negligible).
You may find these resourses useful:
http://www.projectrho.com/rocket/calculators.php
in particular this one:
http://mysite.verizon.net/res148h4j/javascript/script_starship.html
how did you come up with those times and g forces? that web page?
how do i figure that manually?
That is not necessary, your ship is so powerful it would be a waste of time (several years) to use gravitational slingshots within our solar system for a tiny velocity gain.
I considered all those principles for the formulas and explanations I posted.Metric units are much more convenient.
Related to How can I calculate the speed needed for a 30-year journey to Alpha Centauri?
What is Calc speed 30 year journey?
Calc speed 30 year journey is a scientific calculation used to determine the speed of an object over a 30 year period. It takes into account factors such as acceleration, velocity, and time to calculate the speed.
Why is Calc speed 30 year journey important?
Calc speed 30 year journey is important because it can provide valuable information about the speed at which an object is moving over a long period of time. This can be useful for predicting future movements or understanding past patterns.
How accurate is Calc speed 30 year journey?
Calc speed 30 year journey can be very accurate if all the necessary variables are known and measured precisely. However, small errors or uncertainties in the measurements can affect the accuracy of the calculation.
What types of objects can be analyzed using Calc speed 30 year journey?
Calc speed 30 year journey can be used to analyze the speed of any object that is in motion over a 30 year period, such as a car, a planet, or a satellite. The calculation can also be applied to non-physical entities, such as economic growth or population growth.
Can Calc speed 30 year journey be used for shorter or longer time periods?
Yes, Calc speed 30 year journey can be used for shorter or longer time periods depending on the needs of the calculation. However, the accuracy of the calculation may decrease for longer time periods due to potential changes in variables over time.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
11K
