Maxwell's equations from divergence of stress-energy tensor?
In summary, starting with the stress-energy tensor of the electromagnetic field and applying energy-momentum conservation, we can derive the vacuum version of Maxwell's equations. However, it is not possible to extend this to include source terms. The source terms can be derived from Maxwell's equations and the stress-energy tensor, but cannot be used to prove the conservation of energy-momentum for the electromagnetic field.
bcrowell
Staff Emeritus
Insights Author
431
If I start with the stress-energy tensor [itex]T^{\mu\nu}[/itex] of the electromagnetic field and then apply energy-momentum conservation [itex]\partial_\mu T^{\mu\nu}=0[/itex], I get a whole bunch of messy stuff, but, e.g., with [itex]\nu=x[/itex] part of it looks like [itex]-E_x \nabla\cdot E[/itex], which would vanish according to Maxwell's equations in a vacuum.
Is it true that you recover the complete vacuum version of Maxwell's equations by doing this? If so, is there any way to extend this to include the source terms?
##\nabla_{a}T^{ab} = -\frac{3}{2}F_{ac}\nabla^{[a}F^{bc]} + F_{c}{}{}^{b}\nabla_{a}F^{ac} =0##. From here you would have to somehow show that ##\nabla^{[a}F^{bc]} = 0## and ##\nabla_{a}F^{ac} =0##. I don't immediately see a way to do that; even if you can show that the two surviving terms in ##\nabla_a T^{ab} = 0## are independent of each other, you'd still be left with ##F_{ac}\nabla^{[a}F^{bc]} = 0## and ## F_{c}{}{}^{b}\nabla_{a}F^{ac} =0##.
If I am understanding MTW section 20.6 correctly, they say that Maxwell's equations can be derived from the Einstein field equation (G=T), which should be covariant conservation of energy, and the form of the stress-energy tensor.
But Exercise 20.8 is "The Maxwell equations cannot be derived from conservation of stress energy when (E.B) = 0 over an extended region".
Likes 1 person
Awesome find bud! They proceed directly from what I wrote down above to first show that ##\nabla^{[a}F^{bc]} = 0##, which leaves ##F_{c}{}{}^{b}\nabla_a F^{ac} = 0## and they then argue that this can only vanish if ##\nabla_a F^{ac} = 0## by using invariants of the electromagnetic field. Their calculation is quite elegant.
Excellent -- thanks, atyy and WannabeNewton!
As for the source terms, usually one uses Maxwell's equations and the Maxwell stress-energy tensor to show that ##\nabla_a T^{ab} = j_{a}F^{ab}## but if you take this relation for granted and work backwards then you'd get ##F_{c}{}{}^{b}\nabla_{a}F^{ac} = j^{c}F_{c}{}{}^{b}##; since this must hold for arbitrary electromagnetic fields you can easily conclude that ##\nabla_a F^{ac} = j^c##. The only thing is that you can't use Maxwell's equations to prove that ##\nabla_a T^{ab} = j_{a}F^{ab}## like one normally does so if you want to work backwards you'd have to argue that ##\nabla_a T^{ab} = j_{a}F^{ab}## is true.
EDIT: and it's easy to argue this so as long as you assume that the total energy-momentum of the combined electromagnetic field + interacting charged fluid system is still conserved. Because if we have a charged fluid with some stress-energy tensor ##T_{\text{mat}}^{ab}## then we have ##\nabla_a T_{\text{mat}}^{ab} = \mathcal{F}^b##, where ##\mathcal{F}^b## is the 4-force density on the charged fluid. Since the charged fluid is interacting with the electromagnetic field, the 4-force density comes directly from the Lorentz 4-force, whose density is simply ##\mathcal{F}^b = -j_{a}F^{ab}##. So if the total energy-momentum is conserved then we will have ##\nabla_a T^{ab}_{\text{em}} = j_a F^{ab}##.
FAQ: Maxwell's equations from divergence of stress-energy tensor?
What are Maxwell's equations?
Maxwell's equations are a set of four fundamental equations that describe the behavior of electromagnetic fields. They were developed by James Clerk Maxwell in the 19th century and are one of the cornerstones of classical electromagnetism.
What is the divergence of stress-energy tensor?
The divergence of stress-energy tensor is a mathematical quantity that describes how energy and momentum are distributed in a given region of space. It is derived from the stress-energy tensor, which is a mathematical object that combines information about the energy density, momentum density, and stress in a given system.
How are Maxwell's equations related to the divergence of stress-energy tensor?
In Maxwell's theory of electromagnetism, the stress-energy tensor is one of the sources of the electromagnetic field. This means that the distribution of energy and momentum in a given system, as described by the divergence of stress-energy tensor, directly affects the behavior of the electromagnetic field described by Maxwell's equations.
What is the physical significance of the divergence of stress-energy tensor?
The divergence of stress-energy tensor is a crucial quantity in physics as it describes the flow of energy and momentum in a system. It is used in various fields, including electromagnetism, general relativity, and fluid dynamics, to understand the behavior of physical systems.
What are some real-world applications of Maxwell's equations and the divergence of stress-energy tensor?
Maxwell's equations and the divergence of stress-energy tensor have many practical applications, such as in the design of electronic devices, the development of communication technologies, and the study of electromagnetic fields in space. They are also used in medical imaging, weather forecasting, and remote sensing. In general, these equations help us understand and manipulate electromagnetic phenomena, which have a wide range of applications in our daily lives.
