ewildes3
- 8
What I'm making is kind of like a sprinkler or Aeolipile. I have a 2 blade propeller that I'd like to boost with an air tank(s). It has to go from 100rpm to 300rpm via a nozzle at the tips of blades. I'm trying to determine the minimum pressure and volume requirements for a tank of air that can do this.
I calculated that I needed a total torque of 1629.06N*m to go from 100 to 300rpm in 2 seconds (the amount of time isn't set in stone) but I've been stuck on the fluids aspect of this problem for a couple days now. I'm sure I'm making this harder than it needs to be by thinking so long on it. I'm just not confident in my assumptions.
All I want is an equation I can use to calculate the tangential force acting on the blade due to the flow of air from a tank at some pressure and volume through some pipe and out a 90 degree nozzle.
I'd very much appreciate your help and advice.
