A QM problem on finding eigenvalues
In summary: R}} \psi (x) e^{-\kappa \left |x\right |} \ dx (19)...where \psi (x) is associated to the eigenvector |v\rangle with eigenvalue -\lambda^{2} of the operator \hat{H} ,we infer that the negative spectrum we are searching for,is associated to the wavefunction \psi (x)=\frac{\chi}{\sqrt{\kappa}} e^{-\kappa \left |x\right |} (20)which
skpang82
Hi. I have this problem which i am stuck at:
Consider a one-dimensional Hamilton operator of the form
[tex] H = \frac{P^2}{2M} - |v\rangle V \langle v| [/tex]
where the potential strength V is a postive constant and [tex] |v \rangle\langle v| [/tex] is a normalised projector, [tex] \langle v|v \rangle = 1 [/tex]. Determine all negative eigenvalues of H if [tex] |v \rangle [/tex] has the position wave function [tex] \langle x|v \rangle = \sqrt{\kappa} e^{- \kappa |x|} [/tex] with [tex] \kappa > 0 [/tex].
It seems to me the only step i could take is to apply Hamilton H to x bra and v ket:
[tex] \langle x|H|v \rangle = - \frac{\hbar ^2}{2M} \left( \frac{\partial}{\partial x} \right)^2 \langle x|v \rangle -\langle x|v \rangle V [/tex]
which gives [tex] = - \left( \frac{\hbar ^2 \kappa ^2}{2M} + V \right) \langle x|v \rangle [/tex]
So how do I proceed (if i am right thus far)?
Can someone give me some hints as to how to solve this problem?
Thanks.
Please make sure you post problems such as this in the Homework Help section.
Zz.
try to write the hamiltonian in the p basis.
Seratend.
Hi.
I am sorry, but i don't understand what you mean by writing the hamiltonian in the p basis.
(and i will remember to post such problems in the Homework Help section next time, sorry about that :-p )
I don't know how to solve this problem, but I'd like to. I'm not sure what good it does to write the hamiltonian in the p basis. Maybe seratend can elaborate on that?
for instance,
[tex]\langle p | v \rangle = \int_{-\infty}^{+\infty} \langle p | x \rangle \langle x | v \rangle dx
= \sqrt{\frac{\kappa}{2 \pi \hbar}} \int_{-\infty}^{+\infty} e^{-\kappa |x| - ipx/ \hbar}dx
= \sqrt{\frac{2}{\pi}} \frac{(\hbar \kappa)^{3/2}}{\hbar^2 \kappa^2 + p^2}[/tex]
or something close to that at least. Then the matrix elements of H in the p basis are
[tex]\langle p | \hat{H} | p^\prime \rangle
= \langle p | \frac{\hat{p}^2}{2m} | p^\prime \rangle - V \langle p | v \rangle \langle v | p^\prime \rangle
= \frac{p^2}{2m} \delta (p - p^\prime) - V \langle p | v \rangle \langle v | p^\prime \rangle[/tex]
but I don't see how this simplifies when you substitute this in the SE
[tex]\langle p | \hat{H} | \Psi \rangle = \int_{-\infty}^{+\infty}\langle p | \hat{H} | p^\prime \rangle \langle p^\prime | \Psi \rangle d p^\prime
= E \langle p | \Psi \rangle[/tex]
it looks like an ugly integral equation. Was this the procedure seratend was talking about?
nobody knows how to do this problem?
The difficult part of this problem is what to do with the potential operator [tex] |v\rangle V \langle v| [/tex] . If instead, the author had asked for the same problem with just [tex] V(x) [/tex], you'd have known exactly what to do. The mixing of bra ket notation with wave function notation is confusing.
To solve the problem, you have to look for eigenfunctions, say a wave function [tex] \psi(x) [/tex]. When you look at the problem in this way, you will realize that the potential operator when applied to the wave function will give:
[tex]|v\rangle V \langle v| |\psi \rangle == \kappa V e^{-\kappa |x|} \int e^{-\kappa |x|} \psi(x) dx [/tex].
In other words, you may think of [tex] |v\rangle V \langle v| [/tex] as a set of instuctions for how to operate on a wave function. In this case, the instructions say "the result of this operator on a wave function is the product of three things. There is a ket [tex]|v\rangle[/tex], a number V, and a number given by the inner product of [tex]\langle v | [/tex] with the wave function. The result of the operator is the product of these three things (one ket and two scalars)."
I don't think that I've ruined your learning experience by pointing this out. I doubt that the author intended you to work so hard on setting it up.
The main problem with the way that QM is taught is that it requires so much mathematical sophistication that the learners have difficulty finding time to appreciate the theory.
Carl
Do you mean: [tex] \sum_{v} |v\rangle\langle v| = 1[/tex]? Or just [tex] | v \rangle \langle v|=1[/tex]?
Here's what i get.
[tex] \hat{H}|\psi\rangle=E|\psi\rangle [/tex] (1)
[tex] \hat{H}=\frac{1}{2m}\hat{P}^{2}-V|v\rangle\langle v| [/tex] (2)
I'm going to project (1) on a set of linear functionals [itex] \{\langle x|\} [/itex] which obey the completitude relation
[tex] \int_{\mathbb{R}} |x\rangle\langle x| \ dx =\hat{1} [/tex] (3)
Okay.Therefore
[tex] \langle x|\hat{H}|\psi\rangle=\left\langle x\left |\frac{1}{2m}\hat{P}^{2}\right|\psi\right\rangle -V\langle x|v\rangle\langle v|\psi\rangle [/tex] (4)
[tex] \langle x|\hat{H}|\psi\rangle=-\frac{\hbar^{2}}{2m}\frac{d^{2}\psi(x)}{dx^{2}}-V\sqrt{\kappa}e^{-\kappa \left |x\right |}\langle v|\psi\rangle [/tex] (5)
I make use of (3)
[tex] \langle v|\psi\rangle =\int_{\mathbb{R}} \langle v|x\rangle\langle x|\psi\rangle \ dx=\sqrt{\kappa} \int_{\mathbb{R}} \psi (x) e^{-\kappa \left |x\right |} \ dx [/tex] (6)
So,(5) becomes
[tex] \langle x|\hat{H}|\psi\rangle=-\frac{\hbar^{2}}{2m}\frac{d^{2}\psi(x)}{dx^{2}}-\kappa V \int_{\mathbb{R}} \psi (x) e^{-\kappa \left |x\right |} \ dx [/tex] (7)
The equation (1) in the basis [itex] \{\langle x|\} [/itex] is
[tex] \langle x|\hat{H}|\psi\rangle=E\langle x|\psi\rangle [/tex] (8)
Coupling (7) & (8),we reach an integro-differential equation for the wavefunction [itex] \psi (x) [/itex].
[tex] -\frac{\hbar^{2}}{2m}\frac{d^{2}\psi(x)}{dx^{2}}-\kappa V \int_{\mathbb{R}} \psi (x) e^{-\kappa \left |x\right |} \ dx =E\psi (x) [/tex] (9)
Let's solve this equation,searching for plane-wave solutions (wave packets).
To be continued.
Daniel.
A first observation for (9) is that,for example,
[tex] \psi (x)=-\psi (-x) [/tex] (10)
(odd solutions),then the equation becomes
[tex] -\frac{\hbar^{2}}{2m} \frac{d^{2}\psi (x)}{dx^{2}}=E\psi (x) [/tex] (11)
together with the condition (10).Let's solve the equation (11),together with the energy spectrum be entirely negative,i.e.
[tex] E=-\lambda^{2} \ ,\lambda\in\mathbb{R}-\{0\} [/tex] (12)
Then the ODE (11) becomes
[tex]-\frac{\hbar^{2}}{2m} \frac{d^{2}\psi (x)}{dx^{2}}=-\lambda^{2} \psi (x) [/tex] (13)
Choosing an exponential solution [itex] \psi (x) \sim e^{\chi x} [/itex] (14),we get
[tex] \frac{\hbar^{2}}{2m}\chi^{2}=\lambda^{2} [/tex] (15)
with the solutions
[tex] \chi_{1,2}=\pm\sqrt{\frac{2m\lambda^{2}}{\hbar^{2}}} =:\pm k \ ,k>0[/tex] (16)
The wavefunction is
[tex]\psi (x)=C_{1}e^{+ k x}+C_{2}e^{-k x} [/tex] (17)
Coupling (17) and (10),we get
[tex] \psi (x)=\bar{C}\sinh k x [/tex] (18)
But the wavefunction (18) is not normalizable,therefore the negative spectrum which,by virtue of the equation (12),is the whole negative semiaxis,doesn't correspond to physical states described by ODD wavefunctions.
Since one can show that any real function defined on all [itex] \mathbb{R} [/itex] can be written as a sum between an odd function & an even function,we conclude that the integro differential equation (9) should have EVEN wavefunctions as solutions.
To be contnued.
Daniel.
So let's search for even solutions as wavepackets for the equation (9)
[tex]\psi (x)=\frac{1}{\sqrt{2\pi\hbar}}\int_{\mathbb{R}} \tilde{\psi}(p) \ e^{\frac{1}{i\hbar}px} \ dp [/tex] (19)
[tex]\frac{d^{2}\psi (x)}{dx^{2}}=-\frac{1}{\hbar^{2}}\frac{1}{\sqrt{2\pi\hbar}}\int_{\mathbb{R}} p^{2} \ \tilde{\psi}(p) \ e^{\frac{1}{i\hbar}px} \ dp [/tex] (20)
Coupling (19),(20) and (9),one gets (after a bunch of simplifications)
[tex]\int_{\mathbb{R}} \left(\frac{p^{2}}{2m}-\kappa V e^{-\kappa |x|}-E\right) \tilde{\psi} (p) \ e^{\frac{1}{i\hbar}px} \ dp=0 [/tex] (21)
The solution to the equation (21) is simply
[tex] \tilde{\psi}(p)=\delta \left(\frac{p^{2}}{2m}-\kappa V e^{-\kappa |x|}-E\right) [/tex] (22)
One can go on now and find the EVEN wavefunction,solution of (9) which are,of course,
[tex]\psi (x)=\int_{\mathbb{R}}\delta \left(\frac{p^{2}}{2m}-\kappa V e^{-\kappa |x|}-E\right) e^{\frac{1}{i\hbar}px} \ dp \ \ \ \mbox{with} \ \ \psi (x)=\psi (-x)[/tex] (23)
To be continued.
Daniel.
Here's the nice thing.Let's think about equation (22).What does it mean...
[tex] \tilde{\psi}(p)=\delta\left(\frac{p^{2}}{2m}-\kappa V e^{-\kappa|x|}-E\right)=\left\{\begin{array}{ccc} 0 &\mbox{when}&\frac{p^{2}}{2m}\neq\kappa V e^{-\kappa |x|}+E \\ \infty & \mbox{when} & \frac{p^{2}}{2m}=\kappa V e^{-\kappa |x|}+E \end{array}\right \end{array}\right [/tex] (24)
Let's concentrate on this equation:
[tex] \frac{p^{2}}{2m}-\kappa V e^{-\kappa |x|} =E [/tex] (25)
We want to have E<0.So it's fair to say,that
[tex] \frac{p^{2}}{2m}<\kappa V e^{-\kappa |x|} [/tex] (26)
In the asymptotic limit [itex] x \rightarrow \pm \infty [/itex] (27),the RHS tends to 0.The only way (26) can be then fulfilled is that [itex] p=0 \ \ \mbox{when} \ x \rightarrow \pm \infty [/itex] (28).
So the particle is at rest at infinity.This is another requirement imposed to the wavefunction,besides the even character.The expectation value of the momentum operator computed with the wavefunction that we found must go to zero in the asymptotic limit of the particle's coordinate.
To be continued.
Daniel.
And now to your dissapointment,i'll leave it to the OP (or someone else) so finish the problem.
The integral in the equation (21) can be simply computed if you take a look at post #3 of this thread https://www.physicsforums.com/showthread.php?t=61393&highlight=delta+Dirac and aply the theory exactly on this case.
You'll get 2 solutions.Now,due to the analysis made before,you'll see that,either the [itex] \cos [/itex] in the eventual wavefunction,or the [itex] \cosh [/itex] are nonnormalizable wavefunctions,therefore,do not describe physical states.
So the answer to the problem should be
"The potential
[tex] \hat{V}=V|v\rangle \langle v| [/tex]
does not admit physical states for a continuous energy spectrum [itex] \{E\}\subseteq\mathbb{R}^{-} [/itex]".
Surely,one must ask whether that potential admits bound states (discrete energy spectrum contained again in the negative semiaxis).I'll invite the curious reader to solve the integro-differential eq.(9) with the requirement of even wavefunctions (i hope u see why) through other method than the one described (viz.Fourier decomposition -->wave packets--->continuous spectrum).
Daniel.
for instance,
Sorry, I thought it was evident. You have done almost all the job to solve it, at least formally.
[tex]\langle p | \hat{H} | \Psi \rangle = \frac{p^2}{2m}\langle p | \Psi \rangle - V \langle p | v \rangle \int_{-\infty}^{+\infty}\ \langle v | p^\prime \rangle \Psi (p^\prime) d p^\prime=E \langle p | \Psi \rangle \ \ (a)[/tex]
Now, you have the contant [itex] C(\Psi)= \int_{-\infty}^{+\infty}\ \langle v | p^\prime \rangle \Psi (p^\prime) d p^\prime[/itex] in the equation above (that will be used to define the energy quantification conditions).
You have therefore the direct resolution:
[tex] \Psi(p) = \frac{ V \langle p | v \rangle C(\psi)}{\frac{p^2}{2m}-E} \ \ (b)[/tex]
And using the equation for the constant: [itex] C(\Psi)= \int_{-\infty}^{+\infty}\ \langle v | p^\prime \rangle \Psi (p^\prime) d p^\prime[/itex]
you get:
[tex] C(\Psi)= \int_{-\infty}^{+\infty}\ \langle v | p \rangle \frac{ V \langle p | v \rangle C(\psi)}{\frac{p^2}{2m}-E} dp \ \ (c)[/itex]
Or if you prefer:
[tex] 1= \int_{-\infty}^{+\infty}\ \frac{ V \langle v | p \rangle \langle p | v \rangle}{\frac{p^2}{2m}-E} dp \ \ (d)[/itex]
If E <0, there is no problem. You get the result f(E)=1 and solving it you get energy values. If E>0, there is no solutions (to get [itex] \psi(p) [/itex] as a function): we need to enlarge the space to include the free solutions.
Seratend.
P.S. These results assume that the solution and its derivatives are is L^2 . If not, the operator p^2 should be changed in order to take into account the discontinuities.
P.P.S. I think dexter has done an error in the beginning of its demo in the formula:
[tex] \langle x|\hat{H}|\psi\rangle=-\frac{\hbar^{2}}{2m}\frac{d^{2}\psi(x)}{dx^{2}}-\kappa V \int_{\mathbb{R}} \psi (x) e^{-\kappa \left |x\right |} \ dx \ \ (7) [/tex]
He has forgotten the function exp(-k|x|) in front of the constant integral:
[tex] \langle x|\hat{H}|\psi\rangle=-\frac{\hbar^{2}}{2m}\frac{d^{2}\psi(x)}{dx^{2}}-\kappa V e^{-\kappa \left |x\right |} \int_{\mathbb{R}} \psi (x^\prime) e^{-\kappa \left |x^\prime \right |} \ dx \ \ (7) [/tex]
However, I have not read carefully all what dexter has written (and I may be wrong).
Yep,it should have been twice.Okay.I think the OP could solve it,the line is clear enough.
Daniel.
Daniel.
What does mean OP?
Seratend.
Original Poster (the one who starts the thread).
Daniel.
Daniel.
I thought it was the (h)orrible Person :biggrin:
Seratend
First of all, thanks to both seratend and dexter for all the help!
I follow seratend's method. That was very slick. dexter, I'm still digesting your method. Some things that you find obvious I find...well...not obvious :-p. I know seratend had already pointed out the missing exponential factor, but in going from equation (9) to equation (21), what happened to the integral over x?
thanks again
It disappered.Because it was an odd function integrated on a symmetrical domain wrt the origin and that is automatically 0...
Even in the wrong form of the integro-diff.eq (9),the results in (10-21) are correct,becasue those factors do not interviene.
Daniel.
Okay, I see that the odd integral is zero. But in that case, where did the
[tex]\kappa V e^{-\kappa |x|}[/tex]
in
come from? Sorry I'm not catching on...
I'm sorry,but since I've left out that factor,that equation is no longer correct.That had come from trying to write everything under the same integral and factor the Fourier transform of the wavefunction.
Daniel.
No problem. I was concerned that I was missing some math concept. Thank you.
No,no.Nothing too funky.Just Fourier unidimensional.You should know that before attempting problems on QM.
May i know where did u get this problem from?It's a very interesting potential there.
Daniel.
I have no idea where it's from. The OP for this thread is skpang82. I hope he comes back to look at the recent developments.
If you just want to get your homework done, and you don't want to go through a lot more work than you have to (or have your homework look like it was solved for you by a string theorist), then take a look at my previous comment. That breaks the problem down into an inhomogenous differential equation. There is an obvious particular solution, [tex]e^{-\kappa |x|}[/tex]. To find the general solutions, solve the homogeneous DE to get [tex]e^{kx}[/tex] as the form of the general solutions of the homogeneous equation where [tex]k[/tex] is a constant. Then the arbitrary solutions of the general equation can be obtained by substituting the following form:
[tex]\psi(x) = e^{-\kappa|x|} + A e^{-Bx} + C e^{-Dx} [/tex]
where A, B, C and D are constants you will have to determine, and you will likely have to stitch together two different solutions at the origin using the continuity arguments you are already familiar with.
The author of this problem had no intention on turning it into a bad PhD thesis, LOL. For more information on solving inhomogeneous differential equations, see, for example:
http://hyperphysics.phy-astr.gsu.edu/hbase/math/deinhom.html
Carl
I don't know how u came up with a nonhomgenous diff.eq.It looked like an integro-diff.one to me.:confused:
Daniel.
Daniel.
The potential operator converts all wave functions to some multiple (depending on the particular wave function) of [tex]e^{-\kappa |x|}[/tex], so it's not a very complicated integral equation.
You can easily evaluate the action of the potential operator on all the possible functions of the form [tex]e^{kx}[/tex], which happens to cover the solutions to the homogeneous problem as well as the particular solution. Thus the "integro-diff" equation is converted to a standard inhomogeneous differential equation with very little work. Then you can apply the usual methods of solving that sort of DE.
Carl
I see things a bit differently. First, there's no need for any integral equation. A straightforward application of appropriate unitary transformations gives;
<x| H0 |y> = - GRAD squared delta(x-y)
And, by definition of the problem, <x|v>V<v|y> = V exp(-2kx) delta(x-y) for x>0
The Hamiltonian is diagonal in configuration space.
To get past the formal stuff, set y = exp(ax), and you will find that the ensuing Schrodinger Eq. is Bessel's Eq (in y), given the right a.
Regards,
Reilly Atkinson
To me, it looks like
<x|v>V<v|y> = kV exp(-k|x|)exp(-k|y|)
How did you get a delta function?
  • #31
HackaB Think about a slighly different version, say a spin dependent problem, with
H0(m,n) = S*S + V (|m><n| where S is spin (S*S has eigenvalues s(s=1), and the |m> states are Sz eigenstates. The problem specifies the potential to be proportional to a "projector", a single state projection operator. The only choice of m & n that conforms to the properties of a single-state projection operator is m=n. Generalize this reasoning, and get the delta function.
Regards,
Reilly Atkinson
  • #32
By the way, Seratend's solution is the correct one for the non-diagonal version -- the projection operator is replaced by a transition operator. -- which is the equation and solution that Cooper used in his original Cooper Pair paper.
Regards,
Reilly Atkinson
  • #33
So you do not agree that <x|v>V<v|y> = kV exp(-k|x|)exp(-k|y|) ?
I'm sorry, but I don't follow this reasoning. |v> is not a "single state" in the x-representation. So I do not see how a delta function would arise. Could you show the mathematical steps to get it?
What is a transition operator? Is it similar to a projection operator?
  • #34
HackaB -- I blew it with the Bessels -- too good to be true, I suppose. So with egg on my face, I retract the delta function, and remain,
Reilly Atkinson
  • #35
If the assistance this thread has given the OP, has not convinced him that quantum mechanics is impossibly difficult, I wonder what it would take.
Carl
FAQ: A QM problem on finding eigenvalues
What is a QM problem on finding eigenvalues?
A QM (Quantum Mechanics) problem on finding eigenvalues is a mathematical problem that involves finding the values of a particular matrix that satisfy a specific equation. In quantum mechanics, eigenvalues represent the possible states of a quantum system.
Why is finding eigenvalues important in quantum mechanics?
Finding eigenvalues is important in quantum mechanics because they represent the possible states of a quantum system. These states determine the behavior and properties of the system, making it crucial to accurately determine the eigenvalues in order to understand and predict its behavior.
What are some common methods for solving QM problems on finding eigenvalues?
Some common methods for solving QM problems on finding eigenvalues include the power method, the Jacobi method, and the QR algorithm. These methods involve iterative processes that converge to the desired eigenvalues.
Are there any real-world applications of QM problems on finding eigenvalues?
Yes, there are many real-world applications of QM problems on finding eigenvalues. Some examples include quantum computing, quantum chemistry, and quantum cryptography. These fields rely on accurately determining eigenvalues to understand and manipulate quantum systems.
Can QM problems on finding eigenvalues be solved analytically?
In some cases, QM problems on finding eigenvalues can be solved analytically, meaning that a closed-form solution exists. However, in most cases, these problems require numerical methods to approximate the eigenvalues. This is due to the complexity of the equations and the large number of variables involved.
