Kinetic energy relative or absolute?
In summary, my friend asked a question concerning special relativity that initially took me by surprise and which has me wondering about the nature of energy in relativity theory. I believe that kinetic energy is not relative, but I am not sure if this is true in all frames of reference.
qftqed
Hello folks! I have just come from a night at the pub with fellow students of life where over many a pint several mysteries of the universe were discussed. One of my friends asked me a question concerning special relativity that initially took me by surprise and which has me wondering about the nature of energy in relativity theory. The question was this:
How is it that something can be said to have kinetic energy when, in its own reference frame, it has zero velocity? If it too is relative, what are the implications of that?
Initially I didn't have a good response, because I'd never given it any thought, but after a length of time I cobbled together what I think the answer is, but I would love to hear what the answer actually is if it's out there somewhere. My answer is something like this:
Kinetic energy is not relative! It is the work done in accelerating an object from 0 m/s up to its final velocity. Even though a moving object has zero velocity in its inertial reference frame, it needed to accelerate to get there, and this was done with respect to absolute space-time. Or something like that. My mind is a bit boggled at the moment, but I feel like this answer doesn't quite tell the whole story.
So what is the actual state of affairs?
This isn't true. It has zero kinetic energy in its rest frame.
Oh but it is.
This has nothing to do with space-time or even special relativity. Kinetic energy is relative in Galilean relativity as well. If I place a pencil on my desk I have done work against gravity to lift it up from my bag and onto the desk. The pencil is going from zero gravitational potential energy to some non-zero gravitational potential energy given by the height of my desk above the ground and so in its initial and final states it has zero kinetic energy. My doing work doesn't change that-I just need to do work in order to lift up the pencil against gravity.
As an aside, things don't acceleration "relative to space-time". They simply accelerate. This is true both in Newtonian mechanics and in relativity due to the nature of inertia in these theories. The same goes for rotation.
This isn't a relativity question, it's part of classical mechanics.
Despite the definition of kinetic energy as the work done in accelerating an object from zero meters/second to its final velocity, kinetic energy is still relative - because the definition of zero meters/second is itself relative and therefore everything that follows from it must also be relative. You won't get anything absolute until you look at how the moving object interacts with stuff around it.
An easy example: I shoot a 1000 kg elephant with an elephant rifle that fires a .1 kg bullet at a speed of one km/sec. Total kinetic energy if we take the elephant to be at rest is, by ##E_k=(mv^2)/2##, ##5x10^4## Joules. Take the bullet to be at rest and the elephant to be moving towards it at one km/sec, and the kinetic energy is ##5x10^8## Joules.
The absolute quantity here is the amount of energy delivered to the body of the elephant by the collision. That quantity is the same whether we analyze the problem in terms of the bullet hitting the elephant or the elephant hitting the bullet.
Ah, well now it seems obvious haha. I suppose having the question asked in the context of special relativity introduced unnecessary mystery to an otherwise simple problem. Even then, when I think about it, it's simple. Thanks (= case closed!
I can provide a response to this question about kinetic energy in relativity theory. First, it's important to understand that kinetic energy is a measure of an object's motion, specifically its motion relative to a reference frame. This means that the amount of kinetic energy an object has depends on the observer's frame of reference. In other words, the same object can have different amounts of kinetic energy depending on who is measuring it and from what perspective.
In relation to special relativity, which deals with objects moving at high speeds, it is important to note that the concept of absolute space and time is not applicable. Instead, space and time are relative and interconnected, and the laws of physics are the same in all inertial reference frames. This means that an object's velocity and kinetic energy are also relative to the observer's frame of reference.
So how can an object have kinetic energy while having zero velocity in its own reference frame? This is because relative velocity is not the only factor that contributes to an object's kinetic energy. The other factor is mass. In special relativity, an object's mass increases as its velocity increases. This means that even if an object has zero velocity in its own frame of reference, it still has mass and therefore has kinetic energy.
To put it simply, an object's kinetic energy is relative to the observer's frame of reference, but it is not relative to its own reference frame. This is because the object's mass, which is a crucial component of kinetic energy, is not relative and is consistent in all reference frames.
In conclusion, kinetic energy is a relative concept in special relativity, but it is not entirely relative as it also takes into account an object's mass, which is constant in all reference frames.
FAQ: Kinetic energy relative or absolute?
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion, which can be in the form of translational, rotational, or vibrational motion.
2. How is kinetic energy calculated?
Kinetic energy is calculated using the equation KE = 1/2 mv^2, where m is the mass of the object and v is its velocity.
3. What is relative kinetic energy?
Relative kinetic energy is the kinetic energy of an object in relation to another object. It takes into account the motion of both objects and is dependent on the frame of reference used to observe the objects.
4. What is absolute kinetic energy?
Absolute kinetic energy is the total kinetic energy of an object, regardless of its frame of reference. It is the sum of the kinetic energy of an object in relation to all other objects in its surroundings.
5. Is kinetic energy relative or absolute?
Kinetic energy can be both relative and absolute, depending on the context in which it is being measured. In some situations, it may be more useful to consider the relative kinetic energy between two objects, while in others, the absolute kinetic energy of an object may be more relevant.
