What is the significance of using pseudorapidity in HEP experiments?
In summary, particle physics experiments use a trigger system to select "interesting" events and only a small fraction of collisions are recorded. This creates a bias in the data. Additionally, there can be multiple collisions happening at once, called pile up. To study the overall particle distributions, a low rate of events is recorded with minimal trigger requirements. The pseudorapidity scale is used instead of the angle, as it is more convenient and invariant under Lorentz transformations. It is related to special relativity and for high energy particles, it is similar to the concept of rapidity.
HAMJOOP
32
I read some of the articles related to particle physics experiment and don't know the meaning of it.
1. minimum bias event
2. pile up
Also, η (pseudo-rapidity) is used instead of θ to describes the angular distribution, but why ?
Can someone explains to me ?
(1) experiments cannot keep all events, just a tiny bit passes the trigger steps. But those are not representative for all collisions any more (because you specifically look for "interesting" things - that's the idea of the trigger), so they are biased. To study the general particle distributions, a low rate of events is written to disk with just minimal trigger requirements (to make sure there was a collision at all, basically).
(2) multiple collisions happening in the same bunch crossing. Up to ~40 for ATLAS and CMS.
It is a more convenient scale. If you plot "interesting things" over the angle, you get a large peak for small θ and there is a huge difference between 1° and 3°, for example. This does not happen with pseudo-rapidity.
η (pseudo-rapidity) is something related to special relativity.
Is there any reasons related to special relativity for using η ?
Differences in rapidity are invariant under Lorentz transformations (along the beam axis). It's not exactly the same as the pseudorapidity η, but for large energy of the particles they are very similar.
Related to What is the significance of using pseudorapidity in HEP experiments?
What is a "HEP experiment"?
HEP stands for High Energy Physics and refers to experiments that study the fundamental particles and forces that make up the universe. These experiments often involve colliding particles at high energies to better understand their properties and interactions.
What is the Large Hadron Collider (LHC)?
The LHC is the world's largest and most powerful particle accelerator, located at the CERN laboratory in Switzerland. It is used for HEP experiments to collide particles at extremely high energies and has made groundbreaking discoveries, such as the Higgs boson.
What is a "particle detector"?
A particle detector is a device used in HEP experiments to detect and measure the particles produced from collisions. These detectors can range from simple devices that measure the presence of a particle to complex systems that can track the path and energy of a particle.
What are "quarks" and "leptons"?
Quarks and leptons are two types of fundamental particles that make up matter. Quarks are the building blocks of protons and neutrons, while leptons include particles like electrons and neutrinos. These particles are studied in HEP experiments to understand their properties and interactions.
What is "dark matter" and how is it studied in HEP experiments?
Dark matter is a type of matter that does not interact with light and is thought to make up about 85% of the total matter in the universe. HEP experiments study dark matter through its effects on other particles, such as the way it bends light or influences the rotation of galaxies.
