Calculating Flow Rate: Pressure Source to Converging Nozzle
In summary: The equation for flow in a nozzle is Q=K*A*(2*144*g*ΔP/ρ), and the pressure loss across the nozzle is ΔP.
npc214
Hey everyone, sorry I posted this in two different forums. I think this forum was more applicable so I wanted to move it.
I have a fluid system of water coming from a pressure source. Then there is a converging nozzle, which I have calculated the resistance coefficient using Crane's Manual and it has an outlet to the atmosphere.
I have tried to simplify the system. The full system is a pressure source, converging nozzle which has outlet into original diameter at converging nozzle inlet followed by hose to outlet to atmosphere. (this is like a fire hose system - slightly different for my actual application)
The pressure of the pressure source is my independent variable, I am doing a sweep in excel. So if it helps for simplicity, you can assume the pressure is 100 psi.
How do I calculate the flow rate (in GPM)? Do I need to take away the outlet of the system?
Currently I am thinking using:
hL = [k(v)^2]/(2g)
ΔP = (ρ*hL)/144
then what for q??
Or I am thinking q = K*A*(2*144*g*ΔP/ρ)
but then what is ΔP?? is it the pressure drop across the converging nozzle or is it the pressure drop from the inlet to outlet at atmospheric?
The water will flow with exactly the amount of volume/capacity required to create a pressure drop which, in the length of pipe between the "main" (which is usually treated as just a pressure source and not a pipe) and the atmosphere, including the hose, will drop the pressure from 100 psig to atmospheric. Or, more directly, what volumetric flow rate will, in this specific system, result in a pressure head loss of 100 psig, or roughly 231 feet of head.
The first equation looks to me like an open channel fluid equation (though, where did the 144 come from?). The second looks closer, though I haven't used resistance coefficients in a while, so I forget how the formula is supposed to look. If there is a pressure source, I assume this is a piped flow, in which case you'd want to use the Darcy-Weisbach equation or the simpler Hazen-Williams simplification.
http://www.engineeringtoolbox.com/hazen-williams-water-d_797.html
http://www.engineeringtoolbox.com/darcy-weisbach-equation-d_646.html
These equations require iteration when solving for flow, but that's pretty much par for the course when doing fluid dynamics.
If you have K, though, you're pretty much good to go. Just check your equations, because they seem a little off to me.
This page has some good information on mathematically calculating flow through nozzles.
http://www.pipeflowcalculations.com/pipe-valve-fitting-flow/flow-in-valves-fittings.php
Here is a picture of the system. Thank you, I think your reply helps, but I am not concerned about frictional losses right now. Just the loss from the nozzle and what my flow rate will be. I feel like I'm missing one piece of the puzzle. Some input or assumption I don't have right quite yet.
Ok, yea, so if you know the pressure immediately before the nozzle and immediately after, you can use that as your delta P. If the nozzle is open to the atmosphere, then that pressure is 0 psig, or ~14.7 psia (at STP). Understand that if there is a hose after the nozzle, that will contribute to the losses, and hence will increase the pressure at the point just after the nozzle to above atmospheric. Basically, as I said in the first post, your flow comes from the fact that the high pressure system seeks to get rid of all it's excess energy (in the form of pressure). So the fluid flows from the pipe with enough capacity to lose all it's excess energy (pressure) by the time it exits to atmosphere.
I just want to reiterate that if your line prior to point 0 is not a close-by water/liquid main, then any piping between the main and the nozzle will contribute to losses from that 100 psi and will consequently lower the delta-P across the nozzle, thus lowering flow rate. With that said...take a look at that third link, that should give you a good idea of what you're looking at.
How did you find K? Did you use the Cv?
Thanks Travis_King, your second post helped me understand exactly what you're saying. I found K (from smaller diameter = 0.2072, from larger diameter = 13.8082), our source is a fire hydrant, so I suppose there are long pipes from the main to the hydrant, but we get consistently 75-80 psi at the hydrant. The system pictured above is an eductor or water jet pump attached to the hydrant typically there is a hose with a gun at the end, but sometimes we take the hose off and shoot the eductor right off the hydrant. There is some short pipe length (diffuser) after the converging nozzle in the eductor, but I think that can ignore that short length for now.
Could I simply use Bernoulli's... ? Q = A2*SQRT(2*144*g*dP/(rho(K-A2/A1+1))
and here dP would be source P - atm P?
Oh, ok. Yea, using the crane tables and plugging into those formulas with Beta; gotcha.
And yea, if it's a hydrant you're probably ok to treat the upstream pressure as that same 75-80 psi. There shouldn't be much losses prior to the nozzle. You'll likely lose a couple psi in the fire hose, so you can account for that later.
I think you'd be better off using the equations in the third link. I do a lot of hydraulic calculations and almost never use Bernoulli. It may work, give it a try with both.
To answer your question though, yes, dP is Psource-Patm. Be sure that if your source is 80 psig (gauge pressure) then you subtract 0 psig. If it is 80 psia (absolute) you subtract the 14.7 (or whatever it is at your altitude). Also note that in most equations, the dP is in feet H20, not psi.
http://www.engineeringtoolbox.com/pump-head-pressure-d_663.html
Ok, thanks so much Travis!
FAQ: Calculating Flow Rate: Pressure Source to Converging Nozzle
1. How do I calculate the flow rate in a system with a pressure source and converging nozzle?
The flow rate in this type of system can be calculated using the Bernoulli's equation, which takes into account the pressure, velocity, and height of the fluid. It is given by the equation: Q = A * v * ρ, where Q is the flow rate, A is the cross-sectional area of the nozzle, v is the velocity of the fluid, and ρ is the density of the fluid.
2. Can I use any unit of measurement for the flow rate calculation?
Yes, the flow rate can be calculated using any unit of measurement for the given parameters. However, it is important to ensure that all the units are consistent and in the correct SI units for accurate results.
3. What is the pressure source in this system?
The pressure source refers to any external force that is providing pressure to the fluid in the system. This can be a pump, compressor, or any other device that is used to generate the pressure required for the flow.
4. How does the converging nozzle affect the flow rate?
The converging nozzle is designed to accelerate the fluid and increase its velocity, which in turn increases the flow rate. The narrowing of the nozzle forces the fluid to pass through a smaller area, making it move faster and increasing the flow rate.
5. Are there any limitations to using the flow rate calculation for pressure source to converging nozzle systems?
Yes, the flow rate calculation for this type of system assumes that the fluid is incompressible and that there are no energy losses due to friction. In real-world scenarios, there may be other factors that can affect the flow rate, such as turbulence, viscosity, and other losses, which may not be accounted for in the calculation.
