Graviton Theory: Inertial vs Gravitational Mass
In summary: You disagree with the claim that it is impossible to obtain the Einstein-Hilbert action, starting from the standard action for gravitons in linear theory and iterating repeatedly.
werty
36
gravitons ??
is the inertial mass proportinal to the gravitational mass in the graviton theory of gravitation ? I ask this because I can see easily how GR imply that the two masses must be equal since spacetime curvature acts at everypoint in the body. But with gravitons I can't understand how a particle field can get to everypoint of the body with equal strength. For example electric fields and waves only affect the surface of materials the inside is almost unaffected by the electric fields acting on the bodys perimeter. How is this problem solved in string theory and other theories that try to use particles as force carriers ?
You shouldn't think of gravitons as one particle at a time, but as a flood of particles zipping through every point of the object and collectively generating gravitational/inertial effects. The superstring graviton is claimed to satisfy the same equations as Einstein's curvature, so it would have the same effects re: the principle of equivalence.
selfAdjoint said:
The superstring graviton is claimed to satisfy the same equations as Einstein's curvature,...
But the claim is challenged, isn't it?
http://arxiv.org/abs/gr-qc/0409089
From Gravitons to Gravity: Myths and Reality
T.Padmanabhan
19 pages
"There is a general belief, reinforced by statements in standard textbooks, that:
(i) one can obtain the full non-linear Einstein's theory of gravity by coupling a massless, spin-2 field... self-consistently to the total energy momentum tensor, including its own;
(ii) this procedure is unique and leads to Einstein-Hilbert action and
(iii) it only uses standard concepts in Lorentz invariant field theory and does not involve any geometrical assumptions.
After providing several reasons why such beliefs are suspect -- and critically re-examining several previous attempts -- we provide a detailed analysis aimed at clarifying the situation.
First, we prove that it is impossible to obtain the Einstein-Hilbert action, starting from the standard action for gravitons in linear theory and iterating repeatedly. Second, we..."
A good time to recall the contribution that Thanu Padmanabhan made to this discussion last year.
Does this mean that gravitons arent absorbed by the material in anyway?
Oh no, they have to interact; by "zipping through" I meant some woud get so far before interacting and some less far, but all regions of the object (remember it's "mostly empty space") would get particles. To call this absorption though, I have my doubts. I would expect that a quark for example would interact with a graviton, and change its course and then emit another graviton, and so on.
T.Padmanabhan
19 pages
What about cohomologically deforming Pauli-Fierz into Hilbert-Einstein via BRST techniques...?I've seen some articles by M.Henneaux on this.
It has to go the other way,too.I don't know what this Thanu Padmanabhan claims.
Daniel.
Daniel.
What part of impossible did you disagree with? If Padmanabham is correct not BRST nor anything else will save the graviton. 'Course I tend not to take what physicists call proofs very seriously, but even so, accept, refute, or get out of the way.
My own comments on gravitons are always contingent on the SST claim being correct, and I do always remember Padmanabham's paper.
selfAdjoint said:
...I do always remember Padmanabham's paper.
I remember now, it was you who called it to our attention! in the thread
String Gravitons yield GR. NOT
that you started September last year.
https://www.physicsforums.com/showthread.php?t=44414
selfAdjoint said:
This paper does a lot of testing of different kinds, and concludes that the string theorists assertion that the graviton reproduces the physics of GR in flat spacetime is a myth.
I haven't read any courses about current particle theories but it seem to me that any theory with particles interacting with materials would have imply that the shape and type of material place a role. Like the neutrinos zipping through Earth they zipp through different material and different shapes with different efficiency even though they are so tiny. Gravitons on the other hand must interact pretty much since gravitation is very strong compared to neutrino pressure. Perhaps the extra dimension in string theory helps to conserve intertialmass=gravitationalmass ?
You are certainly correct about the interaction, although note that gravity is by far the weakest of the four forces. Its large scale effects are due to the fact that it has only one sign, unlike electromagnetism, and is long range, unlike the strong and weak forces. So it can span large distances and accumulate without any negative "charges". Then from its weakness the idea of a strong interaction is somewhat diminished.
I don't know what you mean about shapes. Elementary particles are pointlike; their dimensions are not important in their interactions. There are of course crystals, but I think gravity is better thought of as acting at the subatomic level. Somehow gravity must interact with the "gluon sea" whose binding energy supplies most of the mass in our macroscopic world.
I mean that I think that non-geometric theory of gravitation must imply that gravitation mass should be dependent of the shape and composition of bodies. Eg. an object should be able to give gravitational shadow to another if it is explained with a particle theory however weakly interacting it is. What do you think of this belief ?
It's no good. First, there is no sign of any gravitational shadow. Second your idea of particle interactions in still too naive. You seem to think the gravitons are like little baseballs. Probably you would do better not to think of gravitons at all, since after all they are not firmly predicted, and go back to spacetime curvature as the source of gravity.
Padmanabhans paper is more or less incorrect, and never made it to publication. His actions were not gauge invariant under his own prescription, and as such he draws wrong conclusions.
Fundamentally, the papers problem was he linearized gravity too much, so he had no way of ever retreiving the Einstein Hilbert action (a manifestly non linear action)
The correct way to quantize a spin 2 gauge invariant particle is found in Veltmann's paper in the 70s or by one of Weinbergs papers.
Ok, its just that that all other particle theories give rise to 'shadowing'. Even if the particle is as quantum mechanical as it can be and still remain a particle It must obey some sort of solution near 'things' and those solution I believe must be dependent on shape and decomposition of the 'thing'. Always different solutions for different potential and so on.
Even if we can get the einstein equations that still don't tell us that gravitational mass is equal to inertial mass, that will have to come as an axiom if not proved some other way.
No its not an axiom, its determined experimentally.
Haelfix said:
Padmanabhans paper is more or less incorrect, and never made it to publication. His actions were not gauge invariant...
Thanks, this is good to know! I was wondering, since it raised issues that never seemed to get settled, how it would play out. Is there an easy way to find out, after 6 months or so, if an arxiv preprint has not gotten published?
raj07 said:
consider deep inelastic scattering of e-p.assuming that a graviton acts as a propogater in this interaction how would it effect the structure functions of the proton.now we have a spin 2(graviton) instead of the usual spin 1(photon).basically what is the effect of this spin change on the structure functions of proton.
Can you please stop asking this question in all threads etc. you can find? Spamming is not okay.
It was finally published last year! :)
Journal reference: Int.J.Mod.Phys.D17:367-398,2008
DOI: 10.1142/S0218271808012085
BTW, it has now a nice number of citations, not from the authors of collaborators.
http://arxiv.org/cits/gr-qc/0409089
I also found this article:
http://arxiv.org/abs/0906.0926
Bootstrapping gravity: a consistent approach to energy-momentum self-coupling
Authors: Luke M. Butcher, Michael Hobson, Anthony Lasenby
(Submitted on 4 Jun 2009)
Abstract: It is generally believed that coupling the graviton (a classical Fierz-Pauli massless spin-2 field) to its own energy-momentum tensor successfully recreates the dynamics of the Einstein field equations order by order; however the validity of this idea has recently been brought into serious doubt [1]. To remedy this confusion, we present a graviton action for which energy-momentum self-coupling is indeed consistent with the Einstein field equations. The Hilbert energy-momentum tensor for this graviton is calculated explicitly and shown to supply the correct second-order term in the field equations. A formalism for perturbative expansions of metric-based gravitational theories is then developed, and these techniques employed to demonstrate that our graviton action is a starting point for a straightforward energy-momentum self-coupling procedure that, order by order, generates the Einstein-Hilbert action (up to a classically irrelevant surface term). The perturbative formalism is extended to include matter and a cosmological constant, and interactions between perturbations of a free matter field and the gravitational field are studied in a vacuum background. Finally, the effect of a non-vacuum background is examined, and the graviton is found to develop a non-vanishing "mass-term" in the action.
FAQ: Graviton Theory: Inertial vs Gravitational Mass
What is the difference between inertial and gravitational mass?
Inertial mass is a measure of an object's resistance to change in motion, while gravitational mass is a measure of the strength of an object's gravitational pull. In other words, inertial mass determines how an object will respond to a force, while gravitational mass determines how much gravitational force it will exert on other objects.
Why is the concept of graviton important in graviton theory?
Graviton theory is a proposed theory of gravity that seeks to explain how gravity works at a fundamental level. The concept of gravitons, which are hypothetical particles that are believed to transmit the force of gravity, is important in this theory because it helps to unify gravity with other fundamental forces in physics.
How does graviton theory differ from Einstein's theory of general relativity?
Einstein's theory of general relativity describes gravity as a curvature of space-time caused by the presence of matter and energy, while graviton theory seeks to explain gravity as a force transmitted by gravitons. While both theories have been successful in making accurate predictions, graviton theory is still a largely unproven and controversial concept.
What evidence supports the existence of gravitons?
Currently, there is no direct evidence for the existence of gravitons. However, some experiments, such as the detection of gravitational waves, indirectly support the concept of gravitons. Additionally, gravitons are a crucial component of many theories that seek to unify gravity with other fundamental forces, which adds to their plausibility.
Is graviton theory the only theory that seeks to explain gravity?
No, there are several other theories that seek to explain gravity, including Einstein's theory of general relativity, string theory, and loop quantum gravity. Each of these theories has its own strengths and limitations, and scientists are still working to find a unifying theory that can fully explain the force of gravity.
