Expert Tips for Shaping a Paper Propeller to Catch Air Efficiently
  • Thread starter Integral0
In summary, you need to get the whole length of the prop blade working at the same pitch for maximum efficency. You can do this by cutting the blades from an old spackle bucket, mounting them on a hub, and running a wire through all the blades at about halfway out from the center to hold the pitch.
Integral0
49
How do you shape (shape in meaning-> bending angles that will catch air, not shaping the design itself) a propeller out of a paper that will catch air (I got a Lou-vee Air car but it won't move b/c it is not pulling any air when spinning or pushign the air)?
The same way as a fan is shaped.
Your prop is made of paper? I have trouble thinking of a way to shape a piece of paper so it will push any appreciable amount of air; the paper would rather just bend to relieve the pressure. I'll give it further thought but in the meanwhile, how about cardboard for the prop?
Re
the best or hardest material I can use is manila folders . . . I am not sure how to create the angle of attack for the propeller to scoop air
http://www.phs.provo.k12.ut.us/~ericr/aircarsix.html
(its not mine, but I want it to work like it)
I wound up my Lou-vee Air car but it wouldn't budge.
Interesting.
Have you tried:
First, buy a metal/plastic fan with the right size that you want.
Soak your cardboard in a mixture of warm water and starch. Some experimentation required to get the mixture 'wet' enough to soak the paper but fluid enough so that it doesn't leave gobs of starch on the paper.
Put your soaked paper on the fan's blades. It should fit easily like a paper-mache. Wait for it to harden.
Voila :smile:
Angle of attack too high - add more twist at the leading edge. The trailing edge should be straight. As an added benefit, a correct twist will make even a single layer oak tag propeller quite rigid. The angle of attack at the tips should be near zero. Again, just like a fan (or actually, yours looks more like a propeller).
The high angle of attack shown in the photo may be needed to compensate for the flattening of the prop at speed.
Hi
You need to get the whole length of the prop blade working at the same pitch for maximum efficency. Pitch is the distance a prop will travel forward into the air in one revolution, much like a screw thread. The tip of the blade is going around a much larges circle than the middle but still advancing forward by the same amount so
the middle of the blade must be angled more steeply than the tip.
The centre of the prop is not going around a circle at all, it is advancing straight forward and so the blade there is aligned along the prop shaft.
Lets take for example a prop of 200 mm dia and 100 mm pitch.
The radius to the tip is 100 mm the circumferance for 1 rotation is:
2 x Pi x R
where R = radious
we get 2 x 3.141 x 100 = 628 mm
Now in 628 mm the tip advances 100 mm and the angle between the prop shaft and blade is 90 - invTan (P/C)
where P = pitch and C = circum (628)
we get 90 - invTan (100/628) = 81 deg
Using this we get "
Rad 50, angle 72 deg
Rad 10, angle 32 deg
If you can make a prop so the blades twist somthing like that, it will work fine.
I had to build a wind turbine for one of my nieces years ago and I cut the blades from an old spackle bucket, mounted them on a hub and ran a wire through all the blades at about halfway out from the center to hold the pitch. I couldn't believe how strong it was. If your dealing with a small car try a plastic cup instead. the changing radii of these containers makes the blade change angle of attack as you go from the hub out.
Related to Expert Tips for Shaping a Paper Propeller to Catch Air Efficiently
1. How does the shape of a propeller affect its performance?
The shape of a propeller is crucial in determining how efficiently it converts rotational power into thrust. A propeller with a well-designed shape will produce more thrust with less power, resulting in better performance.
2. What factors influence the shape of a propeller?
The shape of a propeller is influenced by several factors, including the size and weight of the aircraft or vessel, the desired speed and maneuverability, and the type of engine or motor powering the propeller.
3. How do you determine the optimal shape for a propeller?
The optimal shape for a propeller is determined through a combination of theoretical calculations, computer simulations, and physical testing. This process takes into account various performance parameters, such as thrust, efficiency, and noise level.
4. Can the shape of a propeller be modified for different purposes?
Yes, the shape of a propeller can be modified to suit different applications. For example, a propeller designed for high-speed aircraft will have a different shape than one used for slower, more fuel-efficient ships. Changes in materials and manufacturing techniques also allow for more customized and efficient propeller designs.
5. How has technology advanced the shaping of propellers?
Technology has greatly advanced the shaping of propellers through the use of computer-aided design (CAD) software and advanced materials, such as carbon fiber. These advancements have allowed for more precise and efficient propeller designs, resulting in improved performance and reduced fuel consumption.
  • Aerospace Engineering
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • DIY Projects
  • Classical Physics
