String Theory: Recent Findings & Theoretical Developments
  • Thread starter Ratzinger
In summary, string theory has had a lot of recent developments that have caused some to be pessimistic about the theory's future. However, there is still a lot of research being done in the field, and some have been optimistic about the possibility of string theory being correct.
Ratzinger
291
Have experimental findings and theoretical developments in the very recent time (like last three years) been in favour for or against string theory? Has optimism been growing or has it decreased?
No experimental evidence in favor of SST. Theoretical discovery of huge number, maybe infinite number, of inequivalent vacua causes dismay among some SST physicists and circle-the-wagons psychology in others. Revisions to estimated mass of top quark (experimental, from Tevatron) tighten the window for Higgs mass and may force supersymmetry theorists into unwanted fine tuning.
String theory seems to be mathematically consistent only when there are extra (to those normally perceived) spatial dimensions. How could these extra spatial dimensions be detected? One way is by look for modifications (for semi-technical reasons why, see below) in Newton's inverse square law for gravity at small distances. There ongoing investigations looking for such modification, but, so far, none have been detected.
I, too, have a question. If evidence for either supersymmetry or extra spatial dimensions is found, string theorists will jump all over the results and claim vindication. But, since (as far as i know) they are not sufficient conditions, will either of these results really be enough?
It seems that superstring theory implies supersymmetry and superstring theory implies extra spatial dimensions, but how likely is that these necessary conditions can be "true" without symmetry being true? Scientific theories are often "verified" (note the scare inverted commas) for a certain domain of validity by a finding a number of necessary conditions. In this case, how much is enough?
For what it's worth, finding *both* supersymmetry and extra spatial dimensions would go a long way towards bringing me around.
Now, why do extra dimensions modify Newton's inverse square law? First, a somewhat wordy motivation for the inverse square force in three spatial dimensions. Consider gravitational lines of force coming from a point mass. Consider two (massless) imaginary balls with radii R and r that both have the point mass at their centres. The lines of force cross the surfaces (boundaries) of the balls at points. The (relative) strength of gravity at these surfaces will be proportional to the number of crossing point per unit area. Since the same lines of force pierce both surfaces, the number of crossing points is the same for the two surfaces. However, the surface areas scale as radius squared, and thus the strength of gravity (number of points per unit area scales inversely to radius squared.
Now consider gravitational lines of for from a point mass in a universe that has four spatial dimensions. A ball now is a 4-dimensional spatia volumel, and the boundary ("surface") of a ball is a 3-dimensional object. Consequently, the number of crossing points per unit "surface area", i.e., the gravitational force, now scales inversely to radius cubed.
In practice, the extra spatial dimensions, if they exist, are probably folded up in a complicated manner, so the precise deviation from Newton's inverse square law is probably impossible to calculate.
Regards,
George
compliments on the prose style, which is as concentrated and salty as a boullion cube. if you hadna been a math/physicist you could have been a writer about science.
Oops, I meant to say "... how likely is it that these necessary conditions can be "true" without string theory being true?"
Opinion, anyone?
Regards,
George
Supersymmetry by itself, at least in its full-bore form, seems to require 10 dimensions. SST does not imply supersymmetry, it uses it as an assumption, and some of the counterintuitive stuff we ordinarily blame on SST is actually imported with supersymmetry. It is supersymmetry that is having problems due to the revised top quark mass. Not anywhere near falsification yet, but the SS partisans are running their fingers around their collars.
The light at the end of the Theory of Everything tunnel has been receding instead of approaching for the past couple years. It's been like trying to find one particular quarter on the bottom of a wishing well [and a really, really big one at that]. The search itself further muddies the water. A number of theorists have shelved their TOE ambitions and focused on more managable puzzles, like a workable theory of quantum gravity. I would say that is a good thing. The bull has too many horns to be defeated head to head.
If large extra dimensions are found experimentally, its a pretty good bet SST is on to something. If its just a vanilla SuSY, then it would take a lot more to convince me.
Incidentally there is a lot more wiggling room in the higgs sector for the SuSy/GUT models w.r.t the recent top quark revisions than there is in just the standard model.
I will say this, finetuning to one or two orders of magnitude doesn't really bother me, I mean there could in principle be all sorts of other physics going on at very high energies that has been neglected and influencing those numbers. Otoh, more than that starts becoming damn disturbing.
The problem, and the declining optimism doesn't just come from the experimental developments. Equally important, string theorists are finding it much harder than anticipated to derive theoretical predictions from the models. If you theory can't make concrete predictions, no amount of experiment does you any good.
One of the big virtues of the Loop Quantum Gravity program is that it has, a least, started to get to the point where it can say something about what the theory says about real life.
FAQ: String Theory: Recent Findings & Theoretical Developments
What is string theory?
String theory is a theoretical framework in physics that attempts to explain the fundamental nature of particles and forces in the universe. It proposes that the basic building blocks of matter are not particles, but infinitely small one-dimensional objects called strings.
What are the recent findings in string theory?
Recent findings in string theory have focused on the development of new mathematical techniques and models to test the theory's predictions. Some notable findings include the discovery of dualities between different string theories and the possibility of extra dimensions beyond the three spatial dimensions we are familiar with.
How has string theory evolved over time?
String theory has evolved significantly since its inception in the late 20th century. Initially, it was proposed as a way to unify the theories of general relativity and quantum mechanics. Over time, it has developed into a more complex and multi-dimensional theory with various interpretations and predictions.
What are the criticisms or challenges facing string theory?
One of the main criticisms of string theory is that it is currently untestable and lacks empirical evidence. Additionally, the theory's complexity and lack of a unified formulation have led to debates about its validity and usefulness in explaining the physical world.
How does string theory relate to other areas of physics?
String theory is closely related to other areas of physics, such as quantum mechanics, general relativity, and particle physics. It attempts to unify these various theories and provide a more comprehensive understanding of the fundamental principles governing the universe. However, there is still much debate and research needed to fully integrate string theory with other areas of physics.
