BigBang
- 6
What are they?
BigBang said:What are they?
So then the light emitted from the surface of a neutron star should include the emission spectrum of Fe, and perhaps other elements.Entropy said:Actually, the forces at the very surface of the neutron star are not strong enough to insue neutron degradation. The outer most surface of a neutron star is acutally composed of various atomic nuclei, mostly iron isotopes. Then as you barrow deeper neutrons will start to break free and form a neutron superfluid but still have protons and electrons mixed in with it. Then as you get even deeper it will eventually become entirely 100% neutrons. As for the core, it may just continue to be neutrons as well, but it might be that their is further degradation of neutrons into a type of quark matter.
As I mentioned to Entropy in the thread that you kifed his quote from, I've been unexposed to the subject for over 25 years and made a goof. I'd totally forgotten about the internal structure. Someone referred once to the core as possibly 'quark soup'. I've never heard the term 'hyperon'. Whazzzattt?Astronuc said:It appears the internal structure is open to discussion? Some baryonic mass or quark matter? Could hyperons form?
In general, yes, but it's a little more specialized. Bear in mind that along with its original mass, the collapsed star also retains its original magnetic field. And like the mass, it's incredibly concentrated. The parent star's angular momentum remains as well (more or less), so as it collapses it speeds up its spin. You therefore have an unimaginably strong magnetic field rotating at sometimes more than 5,000 rpm. In other words, a dynamo from hell. The synchrotron radiation alone from such a thing is enormous. The magnetic field also traps most radiation except for at the poles. If those poles are not aligned with the spin axis, then you get the lighthouse effect of twin high-energy beacons sweeping around at whatever the pulsar's rotation rate is.Astronuc said:I understand that neutron stars are X-ray (gamma?) emitters, because of the high temperature (~106-107 K) of surface or gas in vicinity of star?
BigBang said:NeutronStar,... What are they?
sorry, no offence meant, but i don't see how that's possible...Astronuc said:So then the light emitted from the surface of a neutron star should include the emission spectrum of Fe, and perhaps other elements.
No offense taken.Yaaks said:sorry, no offence meant, but i don't see how that's possible...Astronuc said:So then the light emitted from the surface of a neutron star should include the emission spectrum of Fe, and perhaps other elements.
Perhaps I should have concluded the statement with a question mark (?). The temperatures are very high near the surface, so obviously Fe and other isotopes would be ionized - and recombination/ionziation would be a continuous process. Since the temperatures of the plasma however are in the keV range apparently, I would expect emissions are in the X-ray region of the EM spectrum.The outer most surface of a neutron star is acutally composed of various atomic nuclei, mostly iron isotopes.
DB said:just to add a little fun facts bigbang, a neutron star is very small, only about 15-20 km in diameter yet its density is [tex]10^{15}g/cm^3[/tex]! making its gravitational force extremely strong. as well you would weigh [tex]10^{11}[/tex] times more on a neutron star then you would on earth!
pretty much a neutron star is the closest to the black hole of the post-supernova stellar stages.
When the mass is great enough, electronic repulsion between the atoms isn't strong enough to overcome gravity. It keeps contracting until the electrons and protons are forced together to form neutrons. The degenerate neutron pressure then prevents further collapse (unless the mass is big enough to overcome that, and then you get a black hole).misskitty said:Whoa. Why so small and so dense?! Are there any figures for estimating the gravitation of a neutron star?
Danger said:The gravitational calculations are exactly the same as for any other body of the same mass.
Since gravity is inversely proportional to the square of the distance, the surface gravity of a neutron star is several orders of magnitude stronger than the surface gravity of a large star, but at a distance greater than the radius of the normal star the gravitational pull should be the same.DB said:doesnt the small diameter yet extreme density have a stronger effect of warping spacetime making its gravitational pull much stronger then a large star with the same mass?
Correct, and more significantly the distance from the centres of the masses involved. You can get much closer to the centre of a smaller body.SGT said:Since gravity is inversely proportional to the square of the distance
I may be wrong, but it's my understanding that a neutron star is made of degenerate matter. In other words, it doesn't contain any "elements" in the normal chemical sense. All of the electrons are in a degenerate state and therefore there are no actual "atoms" with electrons orbiting around them in normal sense of the periodic table. All of the electrons are packed into the lowest possible quantum states because of the overwhelming force of gravity.misskitty said:So if we can't get the emission or absorption lines for a spectrum how do we know what elements are present in that star?
~Kitty
NeutronStar said:I may be wrong, but it's my understanding that a neutron star is made of degenerate matter.
misskitty said:Tiger, what do you mean specifically when you say 'highly ionized atomic nuclei'?
it cannot approach absolute 0 even after radiating all the energy
it has to loose energy and the eventually it will have nothing left. what will happen then?
The elements in a star form by the fusion process, which is not exactly random. Hydrogen rich stars opperate on the PP cycle, and others which generate or form from clouds which contain C, N and O, can work on the CNO cycle. Some stars can burn He, and fuse heavier elements, which require higher temperatures.misskitty said:Tiger, so there are just random elements flying around the stars? Are there any elements that seem to be in every star and others that never appear?
~Kitty
I would imagine it's just gamma radiation - there are no atoms in the core of a neutron star. Highly ionized atoms would produce mostly (if not completely) X-rays.SpaceTiger said:As for emission lines, you usually don't get those in stars unless there is a significant extended region of hot gas beyond the star's photosphere. Stars with heavy stellar winds or interacting binaries will sometimes have emission lines, but most of the time, the spectrum is thermal+absorption. Isolated neutron stars that we can see are usually very hot, so the gas is too heavily ionized even for absorption lines (at least in the optical and UV).
Neutronium is a colloquial and often misused term for an extremely dense phase of matter that occurs under the intense pressure found in the core of neutron stars and is currently not well understood. It is not an accepted term in astrophysics literature for reasons which will be explained below, but is used with some regularity in science fiction . . . .
Astronuc said:I would imagine it's just gamma radiation - there are no atoms in the core of a neutron star.
SpaceTiger said:We don't see the core of the neutron star, we see the surface. On the surface, there are indeed highly ionized atoms and degeneracy is negligible
I was thinking that there has to be a lot of Compton scattering of gamma radiation, hence there would be a fair amount of X-rays. It is true that 100 eV would be in ultraviolet. I suppose there is a distribution of temperature depending on distance from the region of degenerate matter.SpaceTiger said:Not really, the energy of the radiation that comes out depends largely on the temperature. In the case of a neutron star, all but the very youngest have temperatures <106 K, corresponding to a blackbody peak at <100 eV. Some neutron stars do emit a lot in the X-rays, but there are many cases of highly-ionized media (like HII regions) in which the majority of the radiation is in the optical or UV.
Dpes this not imply energies (temperatures) > 100 eV?Space Tiger said:Atoms with most or all of their electrons stripped and roaming free.
A neutron star is a type of celestial object that is formed from the collapsed core of a massive star after a supernova explosion. It is incredibly dense, with a mass of about 1.4 times that of the Sun, but a diameter of only about 12 miles.
Neutron stars are formed when a massive star runs out of nuclear fuel and can no longer support its own weight. The core of the star then collapses under its own gravity, causing the protons and electrons in the atoms to combine and form neutrons.
Neutron stars are unique because of their incredibly high density and strong gravitational pull. They also have a very strong magnetic field and can spin at incredibly fast speeds, up to hundreds of times per second.
Aside from their high density and fast spin, neutron stars also emit radiation, including X-rays and radio waves, due to their magnetic fields. They also have a very smooth surface, with mountains no higher than a few millimeters.
Studying neutron stars can help us better understand the behavior of matter under extreme conditions and the effects of strong gravitational fields. It can also provide insights into the formation and evolution of galaxies and the universe as a whole.
