Einstein's Derivation, why is light velocity c-v and c+v?
In summary, Einstein's derivation in his 1905 paper on the Electrodynamics of Moving Bodies involves defining a new coordinate system Kg, related to the original coordinate system K by a Galilei transform, to solve for the equation tau(x',t') = Sx'*x' + St'*t' + tau0, which leads to the famous equation 1/2(1/(c-v
Perspicacious
76
Why is light velocity c-v and c+v in Einstein's derivation, On the Electrodynamics of Moving Bodies (Annalen der Physik vol XVII 1905 p 891-921)?
If you are referring to
§ 2. On the Relativity of Lengths and Times
[tex]t_B - t_A = \displaystyle \frac{r_{AB}}{c-v}[/tex] and [tex]t'_A - t_B = \displaystyle \frac{r_{AB}}{c+v}[/tex]
(see http://www.fourmilab.ch/etexts/einstein/specrel/www/ ),
light velocity is c.
2. Any ray of light moves in the ``stationary'' system of co-ordinates with the determined velocity c, whether the ray be emitted by a stationary or by a moving body.
[tex]t_B - t_A = \displaystyle \frac{r_{AB}}{c-v}[/tex] comes from [tex]c(t_B - t_A) = r_{AB} + v(t_B - t_A)[/tex],
where [tex]c(t_B - t_A)[/tex] is the distance that light travelled, and [tex]v(t_B - t_A)[/tex] is the distance that the moving-observer (the rod) travelled.
Note that all of these variables are measured in the "stationary system".
Thanks. I got that. Now what's the meaning to the expression, "If we place x'=x-vt, it is clear that a point at rest in the system k must have a system of values x', y, z, independent of time" and the sentences that come next? What is being set up for the big equation that follows? What is [tex]\tau[/tex]? I can't get past Einstein's tortured explanation.
A while ago on this usenet thread I posted my own attempt to follow Einstein's derivation of the Lorentz transform in his original 1905 paper. Here it is:
First Einstein assumes you have to coordinate systems defined by
measurements on a system of rigid measuring rods and clocks, K and k,
with all the spatial axes parallel and with k moving at velocity v along
K's x-axis. K's coordinates are (x,y,z,t) while k's coordinates are (xi,
eta, zeta, tau). Then he defines a new coordinate x'=x-vt, and says "it
values x', y, z, independent of time". Although he doesn't state it this
way, what he has effectively done is to introduce a *third* coordinate
system Kg, with y,z,t coordinates identical to K, but with x' coordinate
given by x-vt. To make this a little clearer, I'm going to modify his
notation and say that coordinate system Kg uses coordinates x',y',z',t',
with these coordinates related to K's coordinates x,y,z,t by a Galilei
transform:
x'=x-vt
y'=y
z'=z
t'=t
An important thing to notice is that, unlike k and K, Kg doesn't
necessarily correspond to the measurements of any observer using a
system of measuring-rods and clocks; it isn't really an inertial
reference frame at all. So, the postulate that all observers must
measure the speed of light to be c in their own rest frame doesn't apply
to Kg. In fact, since we know light must travel at c in both directions
in K, and Kg is related to K by a Galilei transform, it must be true
that light travels at (c-v) in the +x' direction of Kg, and (c-v) in the
-x' direction of Kg.
So now a light beam is sent from the origin of k at tau0, reflected by a
mirror at rest in k at tau1, and returned to the origin at tau2. As
Einstein said, any point which is at rest in k must also be at rest in
this new coordinate system which I am calling Kg, so neither the point
of origin nor the mirror are moving in Kg. So if the origin of Kg
coincides with the origin of k, and if we say the mirror is at position
x'=xm' in Kg, then since light travels at (c-v) in the +x' direction of
Kg, the light will take time xm'/(c-v) to reach the mirror in Kg, and
since light travels at (c+v) in the -x' direction of Kg, it will take an
additional time of xm'/(c+v) to return to the origin. Thus, if the light
is emitted at t'=t0' in Kg's frame, it is reflected at t'=t0' +
xm'/(c-v), and returns to the origin at t'=t0' + xm'/(c-v) + xm'/(c+v)
So, if k's coordinate tau is expressed as a function of Kg's coordinates
like tau(x',y',z',t') then we have:
tau0 = tau(0, 0, 0, t0')
tau1 = tau(xm', 0, 0, t0' + xm'/(c-v))
tau2 = tau(0, 0, 0, t0' + xm'/(c-v) + xm'/(c+v))
Now, since k represents the actual measurements of a non-accelerating
observer using his measuring-rods and clocks, we know that light must
travel at c in both directions in this coordinate system, and since the
origin and the mirror are at rest in k, the light must take the same
amount of time to reach the mirror as it takes to be reflected back to
the origin in k. So, this gives 1/2(tau0 + tau2) = tau1, which
substituting in the expressions above gives
1/2[tau(0, 0, 0, t0') + tau(0, 0, 0, t0' + xm'/(c-v) + xm'/(c+v))] =
Then he goes from this to the equation 1/2(1/(c-v) + 1/(c+v))*(dtau/dt')
= dtau/dx' + (1/c-v)*(dtau/dt'), which also confused me for a little
while because I didn't know what calculus rule he was using to go from
the last equation to this one. But then I realized that if you just
ignore the y' and z' coordinates and look at tau(x',t'), then since he
says "if x' is chosen infinitesimally small", you can just assume tau is
a slanted plane in the 3D space with x',t' as the horizontal axes and
tau as the vertical axes. The general equation for a slanted plane in
these coordinates which goes through some point xp', tp', and taup would be:
tau(x',t') = Sx'*(x' - xp') + St'*(t' - tp') + taup
Where Sx' is the slope of the plane along the x' axis and St' is the
slope of the plane along the t' axis. If we say this plane must go
through the three points tau0, tau1 and tau2 earlier, then we can use
tau0's coordinates for xp', tp' and taup, giving:
So, plugging in tau1 = tau(xm', t0' + xm'/(c-v)) gives
tau1 = Sx'*xm' + St'*(t0' + xm'/(c-v)) + tau0
And plugging in tau2 = tau(0, t0' + xm'/(c-v) + xm'/(c+v)) gives:
tau2 = St'*(t0' + xm'/(c-v) + xm'/(c+v)) + tau0
So plugging these into 1/2(tau0 + tau2) = tau1 gives:
1/2(tau0 + St'*(t0' + xm'/(c-v) + xm'/(c+v)) + tau0 ) = Sx'*xm' +
With a little algebra, this reduces to:
(1/2)*St'*(1/(c-v) + 1/(c+v)) = Sx' + St'*(1/(c-v))
And since tau(x',t') is just a plane, of course St' = dtau/dt' and Sx' =
dtau/dx', so this gives the equation 1/2(1/(c-v) + 1/(c+v))*(dtau/dt') =
dtau/dx' + (1/c-v)*(dtau/dt') which Einstein got.
He then reduces this to dtau/dx' + dtau/dt'*(v/(c^2 - v^2)) = 0, which
is just algebra. He also says that light moves along the y'-axis and
z'-axis of Kg at velocity squareroot(c^2 - v^2), which isn't too hard to
see--a light beam moving vertically along the zeta-axis of k will also
be moving vertically along the z'-axis of Kg since these coordinate
systems aren't moving wrt one another, but in K the light beam must be
moving diagonally since k is moving at v in k, so if you look at a
triangle with ct as the hypotenuse and vt as the horizontal side, the
vertical side must have length t*squareroot(c^2 - v^2), and since z'=z
and t'=t the light beam must also travel that distance in time t' in
Kg's coordinate system. The same kind of argument shows the velocity is
also squareroot(c^2 - v^2) in the y'-direction.
Since tau(x',y',z',t') is a linear function (ie tau(x',y',z',t') = Ax' +
By' + Cz' + Dt'), then from this you can conclude that if dtau/dx' +
dtau/dt'*(v/(c^2 - v^2)) = 0 for a light ray moving along the x'-axis,
tau(x',t') must have the form tau = a(t' - vx'/(c^2 - v^2)) where a is
some function of v (so that dtau/dt' = a and dtau/dx' = -av/(c^2 - v^2),
which means dtau/dx' = (-v/(c^2 - v^2))*dtau/dt').
Next he says that in the k coordinate system the light ray's position as
a function of time would just be xi(tau)=c*tau, so plugging that
expression for tau in gives xi=ac(t' - vx'/(c^2 - v^2)). But in system
Kg, this light ray is moving at velocity (c-v), so its t' coordinate as
a function of x' is t'(x') = x'/(c-v). Plugging this in gives xi =
ac(x'/(c-v) - vx'/(c^2 - v^2)) = a*(c^2/(c^2 - v^2))*x'.
Similarly, if light is going in the eta-direction then eta(tau)=c*tau,
so plugging in tau = a(t' - vx'/(c^2 - v^2)) gives eta=ac(t' - vx'/(c^2
- v^2)). In Kg this ray is moving at squareroot(c^2 - v^2) in the
y'-direction, so t'(y')=y'/squareroot(c^2 - v^2), and plugging this in
gives eta= a(y'/squareroot(c^2 - v^2) - vx'/(c^2 - v^2))...since x'=0
for this ray, this reduces to eta=(ac/squareroot(c^2 - v^2))* y'. The
relation between zeta and z' is exactly the same, so we have:
xi = a*(c^2/(c^2 - v^2))*x'
eta = (ac/squareroot(c^2 - v^2))* y'
zeta=(ac/squareroot(c^2 - v^2))* z'
Since the relation between Kg coordinates (x',y',z',t') and K
coordinates (x,y,z,t) is just x'=x-vt, y'=y, z'=z, t'=t, we can plug in
and simplify to get:
tau = Phi(v) * Beta * (t - vx/c^2)
xi = Phi(v) * Beta * (x - vt)
eta = Phi(v) * y
zeta = Phi(v) * z
Where where Beta = c/squareroot(c^2 - v^2) = 1/squareroot(1 - v^2/c^2),
and Phi(v) = ac/squareroot(c^2 - v^2) (since a was an undetermined
function of v in the first place he just writes Phi(v)).
To find Phi(v), he then imagines a coordinate system K' which is moving
at -v relative to k (and unlike Kg, this coordinate system is supposed
to correspond to the measurements made on a system of measuring-rods and
clocks, so it's a valid inertial reference frame). *He uses
(x',y',z',t') for the K' coordinate system, but since I've already used
that for Kg, let's call the K'-coordinates (x",y",z",t"). Then the
transform from k-coordinates to K'-coordinates would have to be:
t" = Phi(-v) * Beta(-v) * (tau + v*xi/c^2) = Phi(v)*Phi(-v)*t
x" = Phi(-v) * Beta(-v) * (xi + v*tau) = Phi(v)*Phi(-v)*x
y" = Phi(-v) * eta = Phi(v)*Phi(-v)*y
z" = Phi(-v) * zeta = Phi(v)*Phi(-v)*z
If K' is moving at -v in the k-system, and k is moving at +v in the
K-system, then K and K' should really be the same system, so
Phi(v)*Phi(-v) should be 1. Then he argues that if you have a rod of
lenght l lying along the eta-axis of k and at rest in that system, then
if you transform the coordinates of its ends into the K-system, you find
that its length in the K-system is l/Phi(v), and by symmetry he argues
that the length of a vertical rod moving horizontally can only depend on
the magnitude of the velocity and not the direction, so l/Phi(v) =
l/Phi(-v), which means Phi(v) = Phi(-v)...combining with Phi(v)*Phi(-v)
= 1 which he obtained earlier, he concludes that Phi(v)=1, which gives
him the Lorentz transform.
are you Daryl McCullough? or no, what is a different post in that thread? i thought this post from Daryl was interesting (answering essentially why it's [itex]8 \pi[/itex] instead of [itex]4 \pi[/itex], where that extra factor of 2 comes from). i just thought it would be cool to point that out to Daryl if you're the same.
No, my post was this one.
FAQ: Einstein's Derivation, why is light velocity c-v and c+v?
How did Einstein derive the equation for the speed of light?
Einstein derived the equation for the speed of light, c, using the principles of special relativity. He found that the speed of light is constant in all inertial frames of reference, and that it is the maximum speed at which all energy and information can travel in the universe. This led to his famous equation E=mc^2, which relates mass and energy.
Why is the speed of light denoted as c in Einstein's equation?
The speed of light is denoted as c because it stands for "constant" or "celeritas" in Latin. Einstein used the letter c to represent the speed of light in his equations to emphasize its fundamental and unchanging nature.
What is the significance of the addition and subtraction of velocities in Einstein's derivation?
Einstein's derivation shows that the velocity of light is not affected by the velocity of the observer or the source of light. This means that the speed of light is constant regardless of the direction or speed of the observer or the source. This is in contrast to classical physics, where velocities can be added or subtracted.
How does Einstein's equation explain the relationship between mass and energy?
Einstein's equation, E=mc^2, shows that mass and energy are equivalent and can be converted into each other. It explains that mass is a form of stored energy, and that a small amount of mass can release a large amount of energy. This relationship is fundamental to understanding the behavior of matter and energy in the universe.
Can Einstein's derivation be applied to objects other than light?
Yes, Einstein's derivation can be applied to any object or particle that has a constant speed in all inertial frames of reference. This includes not only light, but also other particles with rest mass, such as electrons and protons. Einstein's theory of relativity has been extensively tested and has been shown to accurately describe the behavior of all forms of matter and energy in the universe.
