Answer Time Speed Problems: Calculate Distance from Earthquake
  • Thread starter MrMiyagi901
  • Tags
    Speed Time
In summary: So if the earthquake happened at 10:30 am, the transverse waves would have arrived at the seismograph at 10:38 am and the longitudinal waves would have arrived at 10:46 am.
MrMiyagi901
Ok well I've had a bit of trouble understanding this question
The velocity of the transverse waves produced by an earthquake is 6.17 km/s, while that of the longitudinal waves is 10.3039 km/s. A seismograph records the arival of the transverse waves 60.8 s after that of the longitudinal waves.
How far away was the earthquake? Answer in units of km
Yea i guess i just don't understand the way it's setup or something.
We do ask that you show an attempt at a problem, but:
We assume that the waves started at the same point at the same time. You know the difference in speeds. Given that, if you assume they traveled for an hour, you could figure out how far ahead the faster was than the slower, right? From that, you could figure out how long it would take for the slower wave to reach the point where the faster wave is. All you really have to do is work it backwards from there.
Does that help?
Treate that both rays are like objects that start from a common point , their velocities are given which remain constant , and the difference in arrival times at a distance 's' are given . Apply Translational Kinematics and show your work.
BJ
Since you are asked "How far away was the earthquake?", let D= distance to the earthquake, in km. The information you are given concerns time. How is time related to distance? Well, speed equals distance over time and you are told the speed- from s= D/t, t= D/s. For transverse waves speed= 6.17 km/s so to travel distance D requires D/6.17 seconds. For longitudinal waves speed 10.3039 km/s (it seems strange that they would give one speed to 3 significant figures and the other to 6!) so to travel distance D requires D/10.3039 seconds. You are told that the DIFFERENCE between those two times is 60.8 seconds.
Related to Answer Time Speed Problems: Calculate Distance from Earthquake
1. How do I calculate the distance from an earthquake?
To calculate the distance from an earthquake, you will need to use the formula D = S x T, where D is the distance in kilometers, S is the speed of sound in kilometers per second, and T is the time in seconds it takes for the sound to reach the seismometer. You can find the speed of sound for various mediums online, and the time can be obtained from the seismogram of the earthquake.
2. Why do I need to calculate the distance from an earthquake?
Calculating the distance from an earthquake is crucial in determining the location of the earthquake's epicenter. By knowing the distance from different seismometers, scientists can triangulate the epicenter and understand the magnitude and location of the earthquake.
3. How accurate are distance calculations from earthquakes?
The accuracy of the distance calculations from earthquakes depends on the precision of the seismometer used and the distance between the earthquake and the seismometer. Generally, distances calculated from seismometers within 100 km of the epicenter are more accurate than those calculated from farther distances.
4. Can I use the same formula to calculate distance for all types of earthquakes?
Yes, the formula D = S x T is applicable for calculating distances from all types of earthquakes, including shallow, deep, and surface earthquakes. However, the speed of sound may vary depending on the type of medium the sound is traveling through, such as air, water, or solid rock.
5. Is it possible to calculate the distance from an earthquake without a seismometer?
No, it is not possible to accurately calculate the distance from an earthquake without a seismometer. A seismometer measures the time it takes for the sound waves to reach it, which is crucial in the distance calculation. However, with advancements in technology, there are now smartphone apps that can use your phone's microphone to measure earthquake distances, but the accuracy may not be as reliable as a professional seismometer.
9K
12K
