How Can You Determine the Size of a Hole in a Gas-Filled Container?
In summary, The referenced equation for determining the size of a hole in a container filled with gas based on starting and ending pressure, time interval, density, and volume may have a mistake in the calculation of velocity. It should be based on mean pressure instead of half of the differential pressure. This calculation is only valid for isothermal conditions and there are different equations for adiabatic flow. A suggested resource for further calculations is the Crane Technical Paper 410. The calculations should be done with absolute pressure and the coefficient of discharge is assumed to be 1, which may introduce some error but may not be significant at lower pressures.
CAF
Hi everyone, this is my first post here. It looks like this is a great community so I am hoping for some help in either a better explanation or different approach to my problem: How can you determine the size of a hole in a container that is filled with gas given the starting pressure, ending pressure, time interval between starting and ending, density of the gas, and volume of the container? I found a reference but after playing around with the equations I couldn't get it to work out to the same answer the authors did. I don't know if there is an error in their work or if I am making a mistake figuring it out (probably the latter). Anyway, here is the reference where I got my equations from: http://www.piug.org.uk/IUGNewsletter3-2.pdf , pages 2 to 3. They get an answer of 472 microns, when I calculate it I get 459 microns. I am trying to set it up in excel so I can enter different values and have it calculate the hole size for any given leak rate.
I hope I explained this clearly, thanks in advance for any and all suggestions.
CAF
The procedure given in the above link is OK except that velocity calculation should be based on mean pressure which is (P1+P2)/2. The author of the paper knows it, as he used it in his sample calculation, but mistakenly cited it as the half of differential pressure.
You should note that this calculation only holds good for isothermal condition. This can be used, without any problem, for checking leak rates at low pressures. Leakage from high pressure containers is, generally, adiabatic in nature and there are different sets of equations for different types of flow. Search for "flow through orifices".
This link gives you the details of calculating leak rates http://www.air-dispersion.com/feature2.html
For all practical purposes, I strongly suggest getting your hands on Crane Technical Paper 410.
Thanks Quark!
I think I will stick with the equations in the reference since the pressures I am dealing with are no where near those in the link you posted, typically less than 250 Pa. I just have a couple of basic math questions about the equations.
First, when I try to duplicate the calculations done in the sample, I get n=27.27 , judging by the filled in example on the top right column of page 3 the author somehow got 0.03.
Next, I get confused when the equation is simplified to the next one down where it starts with "2,000". Did they just cancel a bunch of stuff out or what?
When I try to just plug all my numbers into the top right equation on page 3 I get a=159, even when I use n=0.03 as the author does.
Lastly, how is it that pi suddenly appears in the last equation on page 3 when it is nowhere to be seen in the preceding equations?
Thank you for your patience, I know these answers are probably obvious to you guys.
Note that the pressures should be absolute. You calculated the leak rate as n = (100*140/110)-100 which is wrong. You should rather calculate (100*100140/100110)-100. The calculation approximates the atmospheric pressure as 100000 Pa where as it is actually 101325 Pa (but the error is not significant).
Area = Pi*d^2/4, so d = 2*(a/Pi)^1/2. If you observe, area is given in sq.mm. So calculated diameter from the above formula will be in mm. 1mm = 1000 microns. That explains 2000 = 2*1000
Regarding a = 159, do the calculation carefully.
Sweet
Quark,
Your explanation of it being in absolute pressure makes a ton of sense, I couldn't figure out why one of the other equations had 100125 in it, it makes sense now. To get the equations to work though, I had to adjust the mean pressure by subtracting 100000 from it. Why is it that you don't use the absolute pressure for the mean pressure also, as you do for the initial and final? Anyway, I think I am all set now, thank you very much, your help was invaluable.
The equation for the velocity is a simplified and modified version of the Bernoulli's principle. It is assumed that the potential energy is converted into kinetic energy totally. At no flow conditions, the absolute pressure inside is Po+P1 where Po is ambient pressure and external pressure is Po. As the gas flows out, the mean pressure is considered and its absolute value is Po+(P1+P2)/2. The differential pressure that is causing flow is internal pressure - external pressure (i.e Po+Pm-Po) = Pm which is the mean gauge pressure.
The main drawback with this calculation is that, the coefficient of discharge is considered as 1 and this is not a practical case. But with lower pressures, the error may not be significant.
Just curious, are you working with Isolators?
Would 2nd this, trying to find an accurate discharge coefficient can be quite a task in itself and the small error which is done in this case likely doesn't matter.
FAQ: How Can You Determine the Size of a Hole in a Gas-Filled Container?
1. How does the size of a leak or hole affect the leak rate?
The size of a leak or hole directly affects the leak rate. The larger the size of the leak or hole, the greater the amount of fluid or gas that can pass through it in a given time, resulting in a higher leak rate.
2. Is it possible for a small leak or hole to have a high leak rate?
Yes, it is possible for a small leak or hole to have a high leak rate. This can occur if the leak or hole is in a high-pressure system, where even a small opening can result in a significant amount of fluid or gas escaping.
3. How is the leak rate calculated?
The leak rate is typically calculated by measuring the amount of fluid or gas that escapes through a leak or hole in a given amount of time. This measurement is then compared to the total volume of fluid or gas in the system to determine the leak rate.
4. Does the shape of a leak or hole affect the leak rate?
Yes, the shape of a leak or hole can affect the leak rate. For example, a long and narrow crack may have a lower leak rate compared to a round hole of the same size, as the longer path for the fluid or gas to escape may result in a slower leak rate.
5. How can the leak rate be reduced?
The most effective way to reduce the leak rate is to identify and repair the source of the leak. This can be done by using leak detection tools and techniques, such as pressure testing or using gas sensors. Proper maintenance and regular inspections can also help prevent leaks from occurring.
