Is Acceleration of Acceleration a Valid Concept in Physics?
In summary: This summarization has been very helpful.In summary, acceleration is motion at a velocity that is in a consistent state of change, right? So... v is in terms of m/s, a is in terms of m/s^2, and a^2 is in terms of m/s^3 or m/s^4.
Trepidation
29
Acceleration is motion at a velocity that is in a consistent state of change, right? So...
So what is motion at an acceleration that is in a consistent change?
or
a^2 is in terms of m/s^4
Is this 'acceleration of acceleration' ever used? Howabout acceleration of acceleration of acceleration, etc etc ad infinitum?
or
Just because something has a mathematical expression doesn't mean it is automatically physically useful or meaningful.
Zz.
Zz.
I know... The first part of my question was what the mathematical expression would be, and the second part was whether it would or would not be physically useful.
or
I don't think it's a^2 you want.
[tex]\vec{j} = \frac{d\vec{a}}{dt} = \frac{d^3\vec{x}}{dt^3}[/tex]
j is called 'jerk' (or sometimes 'jolt') and has units of m/s^3.
In physics jerk is rarely used, though in some areas of engineering (rollercoaster design would be the usual example) it is important.
The quantity:
[tex]\frac{d\vec{j}}{dt} = \frac{d^4\vec{x}}{dt^4}[/tex]
is often called 'jounce' and has even more limited use than jerk. Obviously you can keep on taking higher derivaives of dispalcement with respect to time without limit, but generally the higher the derivative the less it's use.
Thank you very much...
Related to Is Acceleration of Acceleration a Valid Concept in Physics?
1. What is acceleration of acceleration?
Acceleration of acceleration is also known as jerk or jolt, and it refers to the rate of change of acceleration over time. It is a measure of the change in acceleration over a given period of time.
2. How is acceleration of acceleration measured?
Acceleration of acceleration is measured in units of meters per second cubed (m/s^3) in the SI system. It can also be measured in feet per second cubed (ft/s^3) in the imperial system.
3. What causes changes in acceleration of acceleration?
Changes in acceleration of acceleration can be caused by external forces acting on an object, such as friction or air resistance. It can also be caused by changes in the velocity or direction of an object.
4. Can acceleration of acceleration be negative?
Yes, acceleration of acceleration can be negative. This occurs when the acceleration of an object is decreasing over time, causing a deceleration or slowing down of the object.
5. What are some real-world examples of acceleration of acceleration?
One example of acceleration of acceleration is when a car is accelerating from a stop and then suddenly brakes, causing a change in acceleration. Another example is when a roller coaster goes through a loop, resulting in a change in acceleration as it moves through the curve.
  • Mechanics
  • Mechanics
  • Mechanics
17K
