Exploring Atomic Power: Understanding Fission, Fusion, and Antimatter Reactions
In summary, a neutron is shot at a nucleus and causes it to split apart. This process releases energy.
Line
216
Exactly how does it work when you split an atom? A neutron is shot at a nucleus. Does the nucleus split apart because of the force of the neutron hiting it? I saw something about the neutron sticking to the nucleus and it becomes unstable and splits.
Also wonder how do you accelerate a neutron if it has no charge? I would think using an electron would be a lot easier or is it to small to cause a nucleus to break?
I'm also now understanding how prt of the nucleus becomes energy and how it even has energy. WHat kind of energy is it containing? Is it kinetic? Standard models show the nucleus standing still while the electrons whirl all around it. The nucleus is probrably moving too. and I just can't understand fission, fussion, and antimatter reactions. Am I right ,just by hitting an atom part of it become energy?
I believe there are different ways of getting power out of nuclear reactions. I may very well be wrong (and I'm probably the last person who should be answering) but in nuclear reactors, you have naturally decaying fuel that doesn't need the extra neutron. In a nuclear detonation however, you have an atom that is somewhat unstable and then you add a neutron. This makes it incredibly unstable and starts the chain reaction and BOOM. The reason they wouldn't use an electron as far as i can tell is that 1) I'm not sure if it would make it unstable and 2) it would be very difficult to overcome the coulomb interaction.
To understand how a part become san energy:
Well of course there's the basic E=mc², when a nucleus split, there's a missing mass usually, when u calculate the mass for the resulting nuclei, and this missing mass turns into energy using the above equation...
It's no longer called atomic power btw, it's the nuclear power, the nucleus is everything in these reactions...
Because u need a lot of information hyperphysics is a great site...
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
uH huh but I'm not understansing the physics behind it.
Is it the force of the particle slaming into one another that causes the sonversion into energy? Like you slame to peices of wood together they'll break into smaller peices. If you slame 2 molecules together they'll make smaller peices. Well particles are the smallest known peices of matter. It seems since you can't beak them down further the only way they go is to become energy.
That's not how the process works. A nucleus will become unstable and a fission reaction will occur when a neutron is introduced. The nucleus, without hte neutron, is somewhat stable, but when you add the neutron, it becomes very unstable and will undergo fission. It's not about smashing something into something else like you would smash a baseball into a glass mirror.
When a "stable" atom absorbs another neutron, what you have typically is an unstable isotope (i.e. an atom with the SAME number of proton, but with different number of neutrons or atomic mass number). This isotope then decays via a nuclear reaction.
In a typical nuclear reactor, a slow (or what they call thermal neutron) is captured by the uranium atom. This unstable uranium atom then decays via a fission process that releases energy. You can't just shoot a neutron at the uranium to achieve this exact process, because a fast neutron will not give the same type of reaction. That's why the the whole reactor is in water, because water has hydrogen that has about the same mass a neutrons and can effectively slow down these neutrons.
So no, it is not simply a "hit the atom with a neutron and BAM" type of a process.
Zz.
It turns out that there are a few atoms which are unstable with respect to fission, the most common being U-233, U-235 and Pu-239. Some heavier isotopes of Pu and heavier transuranics will undergo spontaneous fission.
As ZapperZ mentioned, neutrons are absorbed by uranium, prinicipally U-235 in a water reactor. The hydrogen in the water slows the fast neutrons (E > 1MeV) released in the fission process so that they are more readily absorbed by U-235. Commercial power reactors, generally known as Light Water Reactors, use this process, and the neutrons are called 'thermal' neutrons because they are generally in thermal equilibrium with the environment in the reactor. U-235 have a relatively low rate of spontaenous fission, whereas Pu-239 and heavier isotopes have higher rates.
When U-235 absorbs a neutron, it becomes U-236. Most of the time, U-236 (the nucleus is 'excited', i.e. has energy in excess of its stability) will fission, but it could in same cases emit a gamma-ray and decay to a lower energy state (Reprocessed uranium contains some fraction of U-236). Similarly Pu-239 absorbs a neutron and becomes an excited Pu-240, which may fission, or in some cases emit a gamma-ray to become more stable. Successive n-captures will result in the production of Pu241 and Pu242, which will decay to Am241 and Cm-242 through beta dacay. Pu242 may absorb a neutron becoming Pu-243 which decays to Am-243.
As has been pointed out, neutron capture by a U235 nucleus is the trigger that causes U235 to become unstable, undergo fission and release energy. It may be helpful to think of that trigger as being half way down the back of a golf ball cup and is activated by being hit by a golf ball. The ball has to have just the right speed to fall into the hole and strike the back. If it is too fast, it goes over the hole. If it is too slow, it doesn't reach the back of the cup.
A U235 nucleus undergoing fission, produces very high energy neutrons. In order for these neutrons to trigger other fission events (ie. fall into and strike the back of the cup), these neutrons have to be slowed down (to about 1/1000th of their original speed). If they collide with something much more massive, they just bounce off and retain most of their energy. If they strike something close to their own mass, they will lose much more energy per collision. Since hydrogen has virtually the same mass as a neutron, a few successive collisions with hydrogen nuclei will reduce the speed dramatically. H1 has a tendency to capture these free neutrons whereas heavy hydrogen or deuterium H2 does not. So heavy water is a much better moderator.
AM
Well, yes and no. Actually hydrogen, H1 is the best moderator in terms of its moderatation ability. A neutron can lose almost all of its kinetic energy if it happens to have perfect head on collision with a proton. Most of the time though, it has a slightly off-center scattering collision.
However, as Andrew correctly pointed out, H can also absorb neutrons, especially at thermal energies, and it then becomes D (H2). This is one reason that UO2 fuel in light water reactors (LWRs) must be enriched well above the 0.71% by weight of U-235 in natural U. Current licensed limits are 5%, although special provisions are made for slightly higher enrichments for special types of fuel, e.g. fuel used in special experimental reactors. Such fuel is fabricated at special facilities under special licensing.
Fuel must be enriched not only because neutrons are absorbed by H, but also by core structural materials, fission products which accumulate in the fuel as it operates, and also because it is consumed. Modern LWR fuel operates to exposures (burnups) of up to 50-55 GWd/tU for peak assemblies, and up to peak fuel rod exposures of approximately 62 GWd/tU. Peak pellets might reach 65-67 GWd/tU. Under special tests for demonstration purposes, commerical fuel has been irradiated to burnups of 85-90 GWd/tU, and IIRC near 100 GWd/tU; however this is limited to a few special fuel rods. In contrast, fast reactor fuel in FFTR was irradiated to maximum burnups of up to 180-200 GWd/tU. A burnup of 9.7 GWd/tU is approximately 1.0% FIMA (fissions per initial metal atoms).
The Canadians opted to develop heavy water reactors, which go by the name CANDU (Canadian Deuterium Uranium). The CANDU reactors have used natural U, also in the form of UO2, however more recently AECL has introduced CANDU with a slight increase in enrichment for higher exposure (burnup).
Ok but hwo do you get a neutron to accelrate in the first place. I mean protons and electrons have electric charges which allows them to be manipulated. Neutron is neutron so how do you control it?
You don't. The neutrons that initiate this came out of the fission process itself - that's why it is a self-sustaining chain reaction. It already has a kinetic energy when it is liberated during the nuclear reaction.
Zz.
Neutrons are simply liberated in the fission process - usually two or three, but sometimes 4 per fission. They have a range of energies above 1 MeV.
Otherwise, neutrons can be generated from a reaction between a high energy alpha particle (several MeV - from a radioisotope of Pu or Po) and Be or an interaction of high energy (> 1.5 MeV) gamma-ray with Be.
Sb-Be sources are used as startup sources in commerical nuclear plants so that there is a source of neutrons for the in-core and ex-core neutron detectors to detect while the core is subcritical or at very low power.
A third source of neutrons, other than fission are a handful of fission product radionuclides which produce delayed neutrons. These neutrons account for about 0.7% of neutrons in a nuclear reactor (particularly while the system is critical) and that fraction is sufficient to provide for control of the fission process.
OK got that, but I'm not getting why matter becomes energy. I would think if you broke a nucleus that 2 remaining parts would be eqaul to the once whole.
No! If this were the case, fusion and fission wouldn't happen, stars wouldn't burn, and we wouldn't be here. If you take a bunch of protons and neutrons and cram them together to form a nucleus, the resulting nucleus will have less than the sum of all the protons and neutrons that went into it. We call this difference the mass defect. The more tightly bound and stable the nucleus is, the larger the value of the mass defect and the less the resulting nucleus weighs.
When a U-235 atom fissions, it usually splits into 2 lighter nuclei plus 2-3 neutrons. The sum of all the masses of the nuclei and neutrons released will be less than that of the original atom that fissioned. This mass difference between the products and the reactants shows up as the kinetic energy of the products, which is what we use to heat the water which goes on to produce electricity.
Ok but I'm not understanding that. So just split in nucleus or ram 2 together some mass turns up missing?
In terms of the number of thermal neutrons available D2O is by far the best moderator. If one takes the neutron scattering cross-section multiplied by the energy lost per collision and divided by the neutron capture cross-section, D2O is about 80 times more effective as a moderator than H2O.
AM
Yes, I would agree that using the moderating ratio ([itex]\xi\frac{\Sigma_s}{\Sigma_a}[/itex]) as the criterion, there is an advantage to D2O.
On the other hand, this advantage is somewhat mitigated by the fact that neutrons have a much greater diffusion length in D2O, so the escape probability is much greater for a D2O moderated system than for a H2O moderated system.
That site says the mass of the nucleus is les s than the sum of the neutrons and protons. Makes no sense.
SO when mass converts to energy is it an entire particle or just part of a neutron or proton that disappears?
Line said:
That site says the mass of the nucleus is less than the sum of the neutrons and protons. Makes no sense.
For lighter elements, the nucleus has less mass than the sum of its parts. The difference in mass is released as energy. For heavier fissionable elements (e.g. uranium) the opposite occurs: the separate parts have less mass than the nucleus.
Fusion results from two protons coming close enough to overcome electric repulsion and 'feel' the strong attraction of the nuclear force. When this occurs, the energy release is tremendous due to the enormous strength of the nuclear force.
For fissionable nuclei, which are much heavier (higher atomic number) than helium, the nucleus has more mass than the parts after fission occurs. Fission occurs when the coulomb repulsion is able to overcome the attractive nuclear force that keeps outer nucleons stuck in the nucleus. Fission is really an electromagnetic energy release, whereas fusion is a nuclear energy release.
AM
OK but I'm not understanding why a nucleus would have different masses than it's own parts.And what just what is it that causes matter to become energy? I understand the nuclear spliting and fusing but not that matter-energy transformations.
Couldn't you just accelerate 2 nuclei to the point where they are forced together?
You are pondering one of the most fundamental questions of physics: how is it that energy has inertia? We don't really understand the mechanics of how it occurs although there are theories about it (look up Higgs Boson). We do, however, know from relativity that energy and mass are equivalent: [itex]E = mc^2[/itex]. If an object releases energy it must lose mass. For chemical or mechanical energies the loss of mass is so small as to be imperceptible. But the energies involved in nuclear reactions are so huge that differences in mass are perceptible.
When two protons overcome their coulomb repulsion and feel that huge nuclear force attraction, a huge amount of energy is released. Think of the energy that would be released if a large asteroid the size of the Earth 'feels' the Earth's gravitational attraction and collides with the Earth releasing a huge amount of energy in the collision. Multiply that by about 41 orders of magnitude in terms of energy/unit mass and you will have the amount of energy that would be released/unit mass if you replace the asteroid and the Earth with two protons within range of each others' strong nuclear force.
That energy is so enormous that it creates a measureable loss of mass. The sum of the masses of the parts before the earth/asteroid collision is also more than mass afterward. But the proportion is so small ([itex]10^{(-41)}[/itex] less) that it is not practically measureable. It was not until Einstein that we began to look for it. It was not until nuclear reactions were considered that we found it.
Certainly. That is what particle accelerators often do.
AM
Adding to what Andrew Mason mentioned, it is not so simple to accelerate nuclei together, and it becomes more difficicult as the mass and atomic number increase.
Forcing two nuclei together is precisely the fusion process. Two protons colliding and forming a deuteron is the basis of the PP cycle in stellar fusion.
http://csep10.phys.utk.edu/astr162/lect/energy/ppchain.html
On earth, physicists and engineers are trying for easier goals using fusion of D+T and D+D. These reactions require special machines - fusion reactors - such as the Tokamak or Inertial confinement system - in order to maintain controlled thermonuclear reactions. To force nuclei together, the nuclei must be brough close enough to allow the nuclear forces to overcome the coulomb repulsion. In a tokamak, the nuclei are simply heated to a high temperature 10's of keV or 100,000's K to give the nuclei sufficient energy to collide and fuse. It is difficult to do this because the nuclei are in the form of a plasma, ionized gas which is usually confined in a magnetic field, and so the nuclei and electrons lose energy continually due to cyclotron radiation, collision (scattering), and recombination.
More exotic reactions such as D+Li or p+H are conceivable, but very difficult on earth.
Accelerators can do and are used to do very exotic reactions, but they consume a lot more energy than they produce, and so accelerators are limited to experiments to study the structure and nature of matter.
There has been some ideas to use particle accelerators to transmute transactinide element residues leftover from the fission process.
OK so an accelerators would use more energy to fuse 2 nuclei than heating them?
And on the other, so every time to object collide they loos emass? Averytime you move an object it looses mass?
Yes, more or less that is the case. Accelerators work on a packet of particles, so there is more that one being accelerated. These packets can be collided with a stationary target or collided with an on-coming target (e.g. in the colliding accelerators). However, the particles don't necessarily collide perfectly, and many will scatter. Using an accelerator in order to fuse atoms is for the most part very inefficient, and invariably one puts much more energy in than is produced. If this were not the case, we would be using accelerators now to produce energy.
In an exothermic fusion reaction, yes the mass-defect means that some mass is transformed into energy - usually the kinetic energy of the products, which have slightly less mass than the initial reactants.
No, in general this is not true. In fact, one can accelerate and collide two groups of protons and produce more mass in the form of new protons and anti-protons. However, invariably the anti-proton finds a proton, and they annihilate each other. One can collide electrons too.
But again, more energy is put in than is usefully produced.
WHy would it take more energy in an accelelrator?
I mean the heat used to trigger a fusion reaction is awesome. I'd think an accelerator would be cheaper.
I could have sworn we had a whole thread on this issue already...
Please take note that there is an optimum 'scattering cross-secton' for a nuclear fusion to take place. You can't just smash two H nuclei together and expect them to fuse and produce nuclear fusion. If it does, particle physics at the Tevatron would be a "nuclear physics" experiment, not a high-energy physics experiment. At some point, you would have cross over the energy treshold and you no longer fuse things, but SMASH things apart.
I have already discussed the absurd difficulties of using particle accelerators as a nuclear fusion device. I will not repeat those here.
https://www.physicsforums.com/showthread.php?t=90734
Zz.
It would seem the heating up particles would use far more energy.
You mean you just can't send a few particle through and accelrator and fuse them? If you have enough you ought to have enough heat to generate a fusion reaction. Or is there someway to turn off the magnetic fields?
Now I'm not talking about nuclear reactios. If a took the nucleaus of an iron atom and counted the particles in it. The mass of the particles would be more thand the nucleus?
  • #31
OK, now you're no longer making any sense.
Zz.
  • #32
An accelerator is very very inefficient. Only a tiny fraction of the energy that goes into running it, ends up as increased energy of the particles that it's accelerating. Even if you get the particles to fuse and release energy, you're not going to come close to "paying back" all the energy that you pumped into the accelerator in the first place.
Related to Exploring Atomic Power: Understanding Fission, Fusion, and Antimatter Reactions
1. What is atomic power and how does it work?
Atomic power is the energy released from the splitting or combining of atomic particles, specifically in fission, fusion, and antimatter reactions. In fission, the nucleus of an atom is split into two smaller nuclei, releasing energy in the form of heat and radiation. In fusion, two or more nuclei are combined to form a larger nucleus, also releasing energy. Antimatter reactions involve the annihilation of matter and antimatter, resulting in the release of large amounts of energy. This energy can be harnessed and used to generate electricity.
2. What is the difference between fission and fusion?
The main difference between fission and fusion is the type of reaction that takes place. In fission, a heavy nucleus is split into two smaller nuclei, while in fusion, two or more lighter nuclei are combined to form a larger nucleus. Fission reactions are used in current nuclear power plants, while fusion reactions are still being researched and developed as a potential source of clean energy.
3. Is atomic power safe?
The safety of atomic power depends on the specific type of reaction and the precautions taken in its use. Fission reactions, while providing a large amount of energy, also produce radioactive waste that must be carefully stored and disposed of. Fusion reactions, on the other hand, produce less radioactive waste but require extremely high temperatures and pressures to be sustained. Antimatter reactions are highly unstable and have not yet been successfully harnessed for practical use.
4. What are the potential benefits of using atomic power?
One of the main benefits of atomic power is its high energy output. Fission reactions, for example, release millions of times more energy per unit mass than traditional fossil fuels. Additionally, atomic power does not produce greenhouse gases or air pollution, making it a potential source of clean energy. If fusion reactions can be successfully harnessed, they could provide a virtually limitless supply of energy.
5. What are the current challenges in exploring atomic power?
One of the main challenges in exploring atomic power is the potential for accidents or disasters, such as nuclear meltdowns or radiation leaks. Another challenge is the high cost of building and maintaining nuclear power plants, as well as the safe disposal of radioactive waste. In the case of fusion reactions, the main challenge is finding a way to sustain the extremely high temperatures and pressures needed for the reaction to occur. Additionally, the use of antimatter reactions is still in the early stages of research and development, with many technical challenges to overcome before it can be used as a practical source of energy.
