New study shows Dark Matter isn't needed? Relativty explains it?
In summary, the study found that general relativity should be used to study galactic dynamics instead of Newtonian theory. The study concludes that there is no need for dark matter halos to explain the mass detected within galactic clusters.
Cosmo16
140
new study shows Dark Matter mat not exist? Relativty explains it?
Look here
http://www.space.com/scienceastronomy/051010_dark_matter.html"
Is this valid reasoning? I noticed it hadn't been submitted to peer review.
Astronomy news on Phys.org
General Relativity Resolves Galactic Rotation Without Exotic Dark Matter has been submitted to Ap.J. it will be interesting to see if it passes peer review.
The case it makes is obvious; that the dynamics of a diffuse collection of orbiting masses, such as a spiral galaxy, has to be calculated in the non-linear theory of GR rather than the linear Newtonian theory. Apparently, and surprisingly, this has not been done before and the consequent mismatch between galactic dynamics and Newtonian theory has led to the invocation of galactic halo DM. However, Cooperstock and Tieu claim that when properly calculated there is no mis-match at all!.
However, in dismissing general relativity in favor of Newtonian gravitational theory for the study of galactic dynamics, insufficient attention has been paid to the fact that the stars that compose the galaxies are essentially in motion under gravity alone (“gravitationally bound”). It has been known since the time of Eddington that the gravitationally bound problem in general relativity is an intrinsically non-linear problem even when the conditions are such that the field is weak and the motions are non-relativistic, at least in the time-dependent case. Most significantly, we have found that under these conditions, the general relativistic analysis of the problem is also non-linear for the stationary (non-time-dependent) case at hand. Thus the intrinsically linear Newtonian-based approach used to this point has been inadequate for the description of the galactic dynamics and Einstein’s general relativity should be brought into the analysis within the framework of established gravitational theory. This is anessential departure from conventional thinking on the subject and it leads to major consequences as we discuss in what follows. We will demonstrate that via general relativity, the generating potentials producing the observed flattened galactic rotation curves are necessarily linked to the mass density distributions of the flattened disks, obviating any necessity for dark matter halos in the total galactic composition.
I think their calculations appear sound, although I have not checked them throroughly. However they conclude:
Moreover, it will be of interest to extend this general relativistic approach to the other relevant areas of astrophysics with the aim of determining whether there is any scope remaining for the presence of any exotic dark matter in the universe. Clearly the absence of such exotic dark matter would have considerable significance.
I cannot concur with the absence of DM as there is other evidence for extra-galactic DM from lensing and other effects in rich cluster IGM. However it may not be exotic, if Omegabaryon ~ 0.2 - 0.3, there would be no need to invoke hypothetical exotic non-baryonic DM to explain the mass detected within galactic clusters. Such a high Omegabaryon is predicted by the strictly linear expansion model.
Garth
Again:- If this analysis by Cooperstock and Tieu stands up then it would have profound implications for the 'mainstream model'. In particular there would be a problem with galaxy formation within the time scale that model allows.
The present model relies on the quick concentration of non-interacting DM to form the potential wells into which baryonic matter can fall, which then forms the visible galaxies. However if these galactic haloes are only an artifact of inappropriate Newtonian dynamics then more time would be required for the galaxies, now seen at high z to form.
The most extreme example of this is the Hubble ultra deep field object UDF033238.7-274839.8 aka HUDF-JD2 , a 6 x 1011Msolar galaxy at z = 6.5 when the universe was only 860 Myrs old, (age given by Ned Wright's calculator allowing for DE). Also we have high-z quasars with significant iron abundances, and iron is the last element to be formed in fusion processes, such as APM 08279+5255at z = 3.91 whose age is 2.1 Gyr when the universe was only 1.6 Gyrs old (according to LCDM model expansion).
The strictly linear expansion model gives a universe age of 2 to 3 times the LCDM model.
Garth
Personally I suspect that the answer lies in the manner of Operation of Gravity, which is, to this date, seemingly, still unknown, in Completeness.
It may simply be that intergalactic gravity behaves slightly dfferently then the observable gravitational interactions seen at our local scale.
It may sum differently, it may simply be that in summing, it can drag much more of space around with it then had ever been previously thought of, if it can drag space around, then it can also drag around the contents of that space around without, persay, energy loss or general interactivity.
You'll need to express your ideas with a mathematically described testable theory, GR, MOND and SCC are such examples.
But first we have to get the GR analysis right!
Garth
Really :rolleyes: so words won't do for you, interesting as that is the foundation of Mathematics, words.
ana one ana two ana three .. .. .. .. ..
But I appreciate your answer, for what it is worth. :approve:
Your concepts are fine, as points for discussion, but they will need to be quantified and not just 'hand waving'. I'm not criticising, my hands 'wave' as much as anybody's! However, having a mathematically described theory that makes testable predictions is way we separate out those ideas that 'work' and reflect reality in some way from those that are to fall by the wayside.
Modified gravity is MOND and your "if it can drag space around" is the gravitomagnetic effect being tested at this moment by Gravity Probe B, who knows what its answer will be?
Garth
There has been a rebuttal of the paper that you can see here. The rebuttal basically says that the model is "unphysical". It's yet to be seen if this "unphysical" explanation is substantial or not.
Welcome to these Forums Pyro! And thank you for that link.
We argue that in this model the gravitational field is generated not only by the galaxy matter, but by a thin, singular disk as well. The model should therefore be considered unphysical.
In fact I do not agree with its conclusion that the Cooperstock & Tieu galaxy model is 'unphysical', the galaxy does have a disk - the galactic disk in which the spiral arms are embedded, it consists of stars, dust and gas including massive molecular clouds. The total galactic mass Cooperstock & Tieu require is 21×1010M which is totally realistic.
Garth
O.K. here it is, mathematically.
Garth
Thanks, I was aware of how science gets done, the answer mathematically would be ∞ = 1 (No, I am NOT joking) which needs to be broken down to be effective in it's descripton of reality, otherwise, no one will understand it, it needs explaining, sorry, but it is done with words, first, then math.
As Einstein himself stated, "Theory is that which shows us where to look" if I have a theory that is, ostensibly, complete and therefore shows 'what is' as such, then thereafter it would-could be mathematized, as to show it's validity, just that I do believe that it is not as simple as just one equation.
The concepts I have in my head are not based upon mathematical reasonings, {Persay thought they include math knowledge} they are based upon observation{s} of reality and Lots of Currently known Scienctific evidence, after all, there is ony about ten percent of it left to know.
LD
.. .. .. .. Hops off .. .. .. .. .. Stage .. .. .. .. ... {Whoooops!} .. .. .. .. .. ..I'll get off of this thread now, go find turtle, he should be back, any moment now
W00t? I was under the impression that astronomers/astrophysists always used GR, I mean you'd think that there is a significant difference between the two when you're talking about these kind of things.
I'm shocked that no one has done this before.
Agreed, words describe what the symbols represent in a mathematical formulation. The mathematical formulation part is what appears to be missing in this example.
:smile:
I love how the rebuttal paper cites "Introduction to Relativity". I'll let you guys know if we ever find dust disks distributed as a delta function in z.
SpaceTiger said:
:smile:
:smile:
Actually, isn't it possible that this singular disk models the galaxy quite good? Would a more realistic model really give a much different result? (I'm asking because I don't know...)
EL said:
:smile:
I concur that's my point - even if their analysis leaves something to be desired the necessity of using GR rather than Newton to predict galactic rotation profiles would seem basic, don't you think?
Garth
EL said:
:smile:
In some spiral galaxies, there are disks that are relatively thin, but certainly not well-approximated by a delta function. The point in the rebuttal paper was that there was an extra source of gravity in addition to that which they were using to model the luminous matter of a "real" galaxy. In other words, they were unknowingly including dark matter. :smile:
As for your latter question, I'm relatively sure (though I've not done the calculations myself) that the Newtonian approximation will be valid if GR is properly applied.
Ah, that explains a lot! Thanks. (Have to admit I didn't read the rebuttal too carefully.)
Yes, that's what I think too.
Anyway, it's strange that CERN newsletter took it up after the rebuttal was written...
http://science.slashdot.org/science/...tid=160&tid=14
I'm going to hide behind the skirt here, Garth... Can we say with any confidence what disc model might work? I think the observational evidence is really thin. Another objection: since when did CERN jump into the fray? I don't think that is even relevant to this conversation.
EL said:
Anyway, it's strange that CERN put it on their webpage after the rebuttal was written...
Yeah, we were just talking about this at (very late) dinner. One of the guys here says he knows the people that wrote the CERN article and he says they're pretty distant from the mainstream. I wouldn't take it as an endorsement by everyone at CERN and, to my knowledge, nobody in the mainstream is taking it seriously.
As SpaceTiger pointed out, the model of the shape of the galaxy is really not the problem. The problem is that they seem to have invoked an extra source of gravity they didn't mean too...
Yes, that I'm pretty sure of too. Can we see the paper as debunked now, or do you think there could be some errors in the debunking?
Well, I pretty much ignored it from the get-go. There were two reasons for that. The first was that, if it were true, it would only explain one small part of the dark matter problem, leaving the rest horribly inconsistent. In other words, the same amount of dark matter that's needed to solve the dynamical problems is that needed to solve the problems of structure formation and the CMB power spectrum. If one part were solved in some other way, we would be left hanging on the other two.
The other reason was that I have a good bit of faith in the people that do these models. This is a pretty simple issue to have overlooked for so many years. I wouldn't be surprised if the same calculation had been done correctly many times before by other folks.
Anyway, yeah, it's debunked in my mind.
O.k.
Agreed so I would need the Latex equivalent of "The sum of all things, going to infinity, is equal to one"
But as I had already acknowledge it needs elucidation {mathematically as well} to fit into the minds of everyone else.
Till then, I will, probably, just shut up, Thanks
curious
Just a question from the curious, is it not possible that gravity acts in some manner unseen to-or by us that could afford it a Disc of energy-alone that is {somehow} dragging around the rest of the Galaxy, with a variant in it's function pertinant to the elementals, timely available, of the construct of any given galaxy, calculated not 'across the board' of known galaxies but taking into account the relative ages, as per distribution, of the See-therefore 'known' galaxies and-or their respective centers?
Just a question, mind you.
Gravity acting in a manner that we can't see is called philosophy. Gravity acting in a manner inconsistent with GR is possible only in the regimes in which the theory has not been tested. This includes the strong field and cosmological limits.
The "elementals" were, as far as I know, done away with in science hundreds of years ago.
Astronomers always make the appropriate considerations for age when taking their measurements. Of course, one can create arbitrarily complicated theories which are consistent with the observations and invoke, for example, time variations in the laws of physics. However, these theories will have no predictive power.
Gravity already acts in a Manner that we cannot "see", what we "see" is the resultant of gravities Force acting-at work. A stationary car {Parked} is gravity acting, and no one can "see" it doing it, although you can, in your head, 'envision' it.
"Elementals" refers to the reality of elements of Chemistry, (Periodic table of elements) as the state of matter, temperature and type of Atom-molecule (Ergo Composition) might just have more effect, gravitationally, then is currently thought, or known.
No need of time variation in the laws of physics, simply the notation that what is Observed, 13.5 Billion Light years away, is also that NEW.
Therefore perhaps operating on-in a manner that is yet not understood, from this perspective, as this perspective is where we have taken all of our Known {current} 'rules of physics' from, not from "there".
Could be some {very} Slight Differences we don't realize just yet, the View has some obscuring factors to it, doesn't it.
Luminesence?
Lets try it this way, take a gas cloud 20 K in diameter, G^M/r so we will use M = 1 so all we have left is G/r {By the way there was an experiment, done in Germany, wherein the value of G has been brought into question, back in the 90's Last century (I love saying that)} so I will run into our gas cloud with a heating source, {this is, after all, a 'thought experiment', so I can do that, "run into a Gas cloud"} release several thousands of thousands of caloric values (BTU's) and the gas cloud will, upon the timing of the radiant exchange factors relevant to the type of Gas that it is, {Which chemical element(al) it actually is} expand it's r value, so does it's potential G/r value change, as well?
"What is there" {Liqid-solid-gas} is just as important, if not moreso, to "how it is functioning" as 'How it is functioning' is Based upon What is there!
Does that bring more "light" to your understanding of it?
It's just "so" last Century
Whoops, got to fix some of this, the Gas cloud is 20 Kms, it's supposed to be G^m/r {not M the capitalisation} and let's say that when I expanded the Gas cloud (No Jokes about that :-p please ) it became 40 Kms in Dia.
Asks' us the Question of; "Did the G value actually reduce, by half, of what it was-had been, even though our Mass has remained-remains the same?"
This question is so "last century" I' :!) saying that :approve: :-p :-p
No, that's a measurable effect. In science, we're only concerned with measurable effects. If that's not what you mean by what we can "see", then I can assure that the distinction you're making is scientifically uninteresting.
The noun form of "elemental" is not used in that way, so please use the word "element" in the future if you want people to understand you. Nobody is going to think that you're unintelligent if you use the standard meanings of words.
No idea what you're trying to say. The same applies to your other posts, which read more like a philosophy text than a scientific query. You need to be more precise if you wish to understand something scientific. For example, sentences like the following:
This would be completely ignored by most scientists if asked to them. I'm willing to make an attempt at answering your question, but you need to be more specific. The one question that sort of makes sense is the following:
If a cloud of constant mass and density expands to a larger radius, then yes, its potential energy increases (all of the elements expand in approximately the same way). If you mean the gravitational potential on the surface, then your formula is correct. If you mean the total potential energy of the cloud, then it's given by:
[tex]U=\frac{3}{5}\frac{GM^2}{r}[/tex]
  • #32
Sorry a bit 'off thread' but
What I mean by 'See' is simply that you cannot see {Visualy} that gravity is acting in an on-going-persistent-incessant fashion-manner as to keep that car attached to the ground, Unmoving, and you cannot "see" it doing that, "see" as in OBSERVE {Visually} the energy at work.
If you have a Problem with the idea of "invisible things" {'things' like energy} you cannot see radiation either, so use a gieger counter and be scientific.
That you personally express that as something that you find "scientifically uninteresting" is to me more your loss then anything else.
Now you are making me laugh, forgive me, but I find this rather condescending, in tone. {Langauge instructions?}
Firstly what leads you to believe that I am making only 'queries'? nevermind you seem to miss that all science is Philosophically based, from it's outset, as it is a System of 'beliefs-theories' that attempts to use certain standards, scientific Methodology, as proof of those beliefs-theories. Concensus to that 'belief' {Theory} is acknowledged when evidenced by the ability of Observational-testable-repetitively experimentation concords from readings of 'Physical' things, like atoms.
After that, as you admit you have "NO idea" of what I am saying, I'll re-iterate it, with some additions as to endevour to Make it clear to you
Means that what we currently see is "New" in the sense that it is the Beginning of the Universe from a Point of View of 'Time'.
All of what we currently know is from Local Space respective of Having Tested the Properties of Physical Space, Light speed might be Different Just outside of the Local Vicinity, we have not yet, and can not, yet, test that. That would Change Many things.
In the one page, you referred me to, respective of the Conversation you had with Turbot, you mentioned that (1+z) that z=1000 and-or z=1200 would not be observed, here, locally, as it has become obscured, right?
That is what I am referring to, that, and some other 'notions' that apply.
Now, you follow up with this
Please look, and read, what I had posted as a "quotation of Myself" Above, and your responce, as it is not a question, it is a Statement. That you cannot find the 'sense' in it, not my fault, also the Idea that you seem to think that you can respond in the stead of "Most scientists, well rather assumptive of you, isn't it? perhaps condescending again?
<Quite a partiallity of citation of what I had written, and with 'no name' ascribed, that is simply lazy.
Sorry but I have emboldened your words as I now need Clarification from you, as you State that, "If a cloud of constant mass and density expands to a larger radius, then yes," Please tell me how a Cloud can retain a CONSTANT DENSITY and CONSTANT MASS and expand, in VOLUME? cause I am at a COMPLETE loss as to how that works.
Then you tell me "If you mean the gravitational potential on the surface, then your formula is correct." It would, otherwise be amusing, but laughing at you now would be rude, BECAUSE the "Formula" that you Claim I am Using, please remember, I asked you a QUESTION, is not the Right answer, as increasing the radius of the Cloud will space out the Atoms and their gravitational Interactivety as per the measure of "Gravitational Action at a Distance" therefore the Activity dropping off at the SQUARE of the Distance, so the Proportionate Amount of Negation of the Superficial Gravitational Effect would be FOUR TIMES, or x 4 or Gm/4r
Thereafter, I had NOT queried you for this responce " If you mean the total potential energy of the cloud, then it's given by:"
Not the Total Potential energy of the cloud, but the measure of it's gravitational effect on any other given Mass, as measured from it's "surface" I HAD been Specific, as you seemed to be seeking.
SO, I 'googled' your equation, something like this u = (3/5)(GM^2/r)
and Found a website Merlyn.demon.Co-Uk wherein under this title "Binding Energy" we find your equation derived as thus:
© Dr J R Stockton said:
The binding energy, U, of a sphere (of mass M and radius R) is the energy required to move all of its particles to infinity in different directions; it is given by U = 3/5GM2/R.
To calculate U, one can dismantle the sphere shell by shell and integrate; from the above, the energy dU required to move a shell of thickness dr and mass dm to infinity from a surface at radius r and local gravity g is given by dU = g r dm. We have g = GM(r/R)3/r2 and dm = M×3r2dr/R3 (volume increases thrice as fast as radius, relatively). Thus
U = ò0R [ GM(r/R)3/r2 × r × 3Mr2dr/R3 ]
U = 3 G M 2 / R6 × ò0R [ r4dr ] = 3/5 GM2/R
So we read what the gentleman writes and we find that he seems to think that; "(volume increases thrice as fast as radius, relatively)" so I go to this website W3 .aaamath. com to verify that I have the Correct formula for the calculations of the Volume of Spheres, do the Math using 4/3πr3 such that, at an r value of 20 the answer works out to 33510.3216, and at an r value double that, 40 the answer is 33510.3216 which is an eightfold change in volume.
Can you see a problem there? {and My Apologies to Dr J R Stockton, just that}
Although I can clearly see that you can type well, as in this thread CMB it would appear that typing the Words "I Do Not {currently} Know the Answer to that Question" doesn't seem to flow, from your mind, to your fingers, and it would seem that even the attempt at evading the Correct responce by pointing at a Power metric, was founded in Flawed Information, so it would seem that your not a thorough on your "references" either.
As you may be able to tell, saying "I didn't know" is what you were supposed to write in that last post.
If you would like to measure, as a "Dynamic measure" the 'Force' acting upon the parked car, then simply get yourself a Michaelson Morely Interferometer, and Point the "Two light pathways" perpendicular to the Ground, you will get a Quite Dynamic reading of the Invisible force, of Gravity, as it is Acting.
Perhaps, after that, you will do me a small favor, and not respond, to anything, I write, any further.
Good thing I agreed "Not to" a priori.
LD
.....walks...off...head down...saddened...
  • #33
ever heard of private messaging?
  • #34
See my first response. This is basically equivalent to hypothesizing a correction to gravity (or perhaps another force). In order to achieve the balance you're describing, gravity and electromagnetism are inducing equal and opposite forces on the car. In the case of a star, the only force we know of that can act on it in any significant way is gravity... and we have a law for how that behaves.
Read what I said again:
Both energy and radiation are measurable, so no, I wouldn't find them scientifically uninteresting.
Unless you're a scientist, how would you know? Perhaps if you were, the statement would be plainly obvious.
If you were to walk onto a construction site, would you be upset if the workers lectured you on the use of their equipment? Would it be condescending that they assumed you weren't as familiar as they in their area of expertise?
Constant density in space, not time. That is, the cloud has one spatially constant density before expanding and another afterwards. This is only to simplify the computation of the potential/binding energy. Other spatial dependences of density will give a different constant out front, but will be of the same character (proportional to M2 and 1/R).
Let's review the basic gravitational formulae:
[tex]F=\frac{GMm}{r^2}[/tex]
[tex]\Phi=\frac{GM}{r}[/tex]
[tex]U=\frac{3}{5}\frac{GM^2}{R}[/tex]
The first is the magnitude of the force on a mass, m, a distance r from the cloud center. The second (which is what you had in your post), is the magnitude of the gravitational potential at a distance, r, from the cloud center. The last is the magnitude of the potential/binding energy of the cloud, where I substituted R to represent the total radius of the cloud. Please note that r=R only if you're evaluating the the force or potential at the surface of the cloud.
If you double the radius of the cloud, the first and second quantities stay the same unless you're moving the point at which you evaluate them. If you evaluate them both at the surface, the force will fall by a factor of a quarter, the potential by a factor of a half. The last equation is a property of the cloud itself, so it does not have a point of evaluation. Doubling the radius will then reduce that quantity by a factor of a half.
Hopefully this will clear up your misunderstanding.
  • #35
Yes, I have!
