In Science Express from UC-Santa Barbara
  • Thread starter pattylou
  • Tags
    Science
In summary: The most oft 'vaunted cry' was that they hadn't waited long enough in the Observance of the Pattern-s. With time we generally have more and more information, thus a better ability to understand the larger picture. That seems to be the case here.
pattylou
306
In "Science Express" from UC-Santa Barbara
Science Daily has the following intriguing title in their press releases today:
"Link Between Tropical Warming And Greenhouse Gases Stronger Than Ever, Say Scientists"
http://www.sciencedaily.com/releases/2005/10/051014073357.htm
The bit I got out of this press release, was that the shift in climate that occurred 950,000 years ago may have been triggered by CO2 levels rather than retreating ice sheets, and they are drilling ice cores to test this idea.
Hi Patty,
It occurs to me that we are discussing the same paper here:
http://www.ukweatherworld.co.uk/forum/forums/thread-view.asp?tid=24518&posts=11
It may be worthwhile to take note. As I said over there, now the hockeystick is dead, inevitably, the ice age with all it's mysteries comes back to rebuild the "CO2 = warming" case.
But now things are different. We are well on our way to really understand what happened and there is no "CO2 = warming" in there.
The Most oft 'Vaunted Cry' was that they hadn't waited long enough in the Observance of the Pattern-s.
So Now is Soon enough?
With time we generally have more and more information, thus a better ability to understand the larger picture. That seems to be the case here. ??
We do have detailed information about CO2 contents of the air bubbles in the (Ant)arctic ice sheets for some 100,000 years on Greenland as of the 1980ies (Camp Century) and going back 420,000 years for Antarctica (Vostok) since 1999. Currently ice core data are available which are going back to 740,000 years (EPICA Dome C).
More current work in progress is hi resultion research on the NGRIP core on Greenland (the one with http://www.glaciology.gfy.ku.dk/ngrip/billeder_eng.htm ) and trying to extent the EPICA Dome C to perhaps 1,000,000 years.
But things are much harder to interpret and nothing is like it seems. The age difference between the gas in the bubbles and the surrounding ice has made the researchers going crazy. As the surface of the polar ice remains open, fresh air can mix freely between the much older ice. Then distinct differences between ice CO2 and other CO2 calculating methods (leaf stomata) suggest that some physical and chemical or biological (extramorphiles) reactions may take place in the ice. But the biggest question is if we do understand the language of the isotopes. I think, no, I am sure that we do not.
http://home.wanadoo.nl/bijkerk/iso-ghnc.GIF is a comparision of the current heavy isotopes of a shallow core in Greenland that should represent temperature, compared to the GHCN global temperatures during a few decades in the last century. The high sub annual resolution of the ice core shows the seasonal variation of the heavy isotopes. But it also shows no trend at all. So, what does that say about the temperatures? Which one is wrong?
On the other hand, http://home.wanadoo.nl/bijkerk/Vostokamp.jpg of Antarctica shows an absurd high correlation (R2>98%) between Deuterium isotopes in the ice and annual layer height (or annual precipitation). Apparantly the correlation between precipitation and isotopes is much stronger than isotopes and temperature, leading to the conclusion that the ice cores do not show temperatures accurately (and there is much more evidence), which casts serious doubts about the relationship between CO2 and temperatures during the ice ages.
What are the isotopes? How can scientists correlate between atmospheric temperature and the isotope amounts?
An Isotope is one of two or more forms of a single element; the atoms of each isotope have the same number of protons but different numbers of neutrons in their nuclei. Thus isotopes have the same atomic number but differ in atomic mass.
For our ice core research important is the ratio of the heavy hydrogen isotope (called "deuterium" or "D" or "2H") containing a proton and a neutron, as well as heavy oxygen isotope 18O containing 8 protrons and 10 neutrons versus normal 16O with 8p and 8n.
Heavy isotopes behave like the fat heavy boys in class. They are not that agile and the quick smaller boys are always the first to do something active, with the fat boys lagging. Water evaporating is something active and the much more light guys evaporate out than the fat boys. This is called fractination. This process is temperature dependent, as the temperature rises, the molecules speed up and more heavier boys also get enough speed to escape the water. So the ratio between fat and skinny changes with temperature.
The opposite occurs during condensation. This is going to a less active state, which the fat boys love, so they go first, also temperature dependent.
http://www.huxley.ic.ac.uk/Local/EarthSciUG/ESFirstYr/EarthMaterials/mrpalmer/EarthMaterials/Iso/module8/m8.html is the same story in scientific language.
So it seems so obvious. Isotope ratios are temperature and with some cross - checking (Severinghaus Science 1998) this http://www.grida.no/climate/vital/graphics/large/2.jpg with CO2 in the upper and "temperature" in the lower is derived only from isotope ratios, disregarding a lot of other processes like precipitation changes, variable raining out situations. Working on a detailed paper to expose this "affirming-the-consequent" fallacy.
Sing it again bunni
In Five years time? much more certainty?
Should we still think that there isn't ANY problem, at all, with all of the energy consumption? and pollutant productions? cause that seems to be the effect of saying that "The warming isn't, or doesn't, matter" as that is not the Only issue associated with the Climate, or the Changes that are occurring Naturally, or Anthropogenic, we still need to be careful one way, ♪ or the oooother
Or, Not?
Just My Opinion.
LD
.. .. .. and From a FREAKK'IN rabbit! >> .. .. .. .. .. .. .. ...
Well, if you're asking for my opinion then I'd say sure, in five years time we'll have an even better idea of things than we do now. I'd say that now, we have a better idea of things than we did 30 years ago.
Or, Not?
Just My Opinion.
LD
I'm not following what you're saying: I certainly believe consumption is affecting the environment including climate. I don't know anyone that says it's all down to CO2 though, but consumption is such a broad word and can include creating pollution, creating CO2, deforesting, habitat loss, and so on and so on...
And I think we need to curb consumption in any way that is reasonable to do so, because this helps reduce pollutants, deforestation... And, as far as I understand even the CO2 skeptic's position on this, they would agree -
The only place some of us (seem to) disagree is on the degree to which CO2 specifically is contributing. I think it is worth seriously curtailing and others don't seem to.
I haven't figured out your position here yet... but I do hope mine is a little more clear. :smile:
Look! he takes a Position!
pattylou said:
Well, if you're asking for my opinion then I'd say sure, in five years time we'll have an even better idea of things than we do now. I'd say that now, we have a better idea of things than we did 30 years ago. :smile:
Agreed, on Both parts.
Agreed again, and on both parts again.
But how to motivate People?
The Fright of warming isn't good motivation, but it does seem to get them to think, and Act, so replace that with what? the apathy that was there before, when they had "No Fear" of the Weather Machine = Energy Production = pollution.
So what becomes the Motivator, for the changes needed, just for the pollution? How does this enable pointing to that as to continue with the impetus that concern over 'warming' HAS brung about?
LD
Position? Moi? Dormant! {Sleeping like a Rabbit, up on a Turtles back}.. .. .. .. What else .. .. .. .. .. .. is new .. .. .. ..
Basically it boils down to the simple obviously mutual objective and grand strategy, to accomplish an endurable sustainable world with a balance between nature and humans. No sane person would object to that.
The big problem is however, to agree what's going on and what there is to do.
The AGW sceptics would be the first to agree that many human actions are damaging the environment, threatening it's stability and survival but antropogenic global warming is simply not one of them, although he have a long way to go to convince everybody why not.
So, excess CO2, produced by fossile fuel burning is highly unlikely to have that much impact on climate that we should change policies to preserve it.
Pollution may be a reason to reconsider how and what to burn. CO2 is no polluter but several other matters are that are also released by burning.
The main reason why we should reconsider burning, terminating our dependability is the transition to a sustainable balanced economy, based on affordable, efficient and effective renewables. But which to choose is far from easy.
Using global warming to enforce moderation and transition is very wrong for two reasons. Firstly, the urge to accomplish political objectives creates a extreme biased climate science, diverging more and more off the straight and narrow path of the objective scientific method. This will effectively prevent steering back as well. As we are indeed way off track.
Secondly, wrong biased As soon as Antropogenic Global Warming is exposed when evitably the real mechanisms of the past and the present are revealed, the damage to science will be enormous. Forensics types of sciences should always be modest, it may look one way but the solution may be completely different.
Scientists make their conclusions based on evidence. Even if the vast majority of scientists were ultimately found to be "wrong" on human contributions to climate change, as long as their conclusions were based on properly controlled experiments, there is no damage done to science.
We revise theories all the time, and we understand that science is successive approximations. Newton, for example, did not cause "enormous damage" to physics with his ideas.
It's not as though scientists are making up GW data as they go. They are *collecting* data and asking if it supports a particular hypothesis. As long as procedures are properly followed, the science (as a process) is sound.
Absolutely and most certainly agree, however, if your research is driven by:
http://www.nationalcenter.org/dos7123.htm
"[We] have to offer up scary scenarios, make simplified dramatic statements and make little mention of any doubts we may have. Each of us has to decide what the right balance is between being effective and being honest." -Quoted by Dixy Lee Ray in Trashing the Planet (1990)
Then were for instance would the hockeystick fit in? accidently making the wrong choice by chance or perhaps expectation, a slight exagaration for a good cause or manipulating methods and using selective data to proof a predeterminent conclusion?
I don't know but I'm not optimistic, having followed all the details of the MM05 inquiry.
Thanks Andre. I find the link useful.
I googled on Dixy Lee Ray and couldn't find what she was referring to in that selected quote. She has been outspoken on nuclear energy - and was critical of Carter's nuclear energy program - so I wonder if her quote actually is geared towards scaremongering of nuclear energy rather than GW?
This could apply to any number of scenarios, my brief search on her doesn't indicate that she was talking about climate.
I agree that the attitude is wrong in any event, but it may not pertain to the climate discussion directly.
(And of course there will always be the odd scientist, in any field, that has an ax to grind. They are an embarassment.)
Unfortunately, Patty, the original statement was actually of environmentalist, biologist, climatologist Stephen Schneider about global warming:
http://www.john-daly.com/quotes.htm
A few more examples of doubtfull science: The resignation letter of Chris Landsea:
I am withdrawing because I have come to view the part of the IPCC to which my expertise is relevant as having become politicized. In addition, when I have raised my concerns to the IPCC leadership, their response was simply to dismiss my concerns...
..My work on hurricanes, and tropical cyclones more generally, has been widely cited by the IPCC. For the upcoming AR4, I was asked several weeks ago...
...Dr. Trenberth participated in a press conference organized by scientists at Harvard on the topic "Experts to warn global warming likely to continue spurring more outbreaks of intense hurricane activity" ...
...The result of this media interaction was widespread coverage that directly connected the very busy 2004 Atlantic hurricane season as being caused by anthropogenic greenhouse gas warming occurring today. Listening to and reading transcripts of this press conference and media interviews, it is apparent that Dr. Trenberth was being accurately quoted and summarized in such statements and was not being misrepresented in the media...
...I found it a bit perplexing that the participants in the Harvard press conference had come to the conclusion that global warming was impacting hurricane activity today. To my knowledge, none of the participants in that press conference had performed any research on hurricane variability, nor were they reporting on any new work in the field. All previous and current research in the area of hurricane variability has shown no reliable, long-term trend up in the frequency or intensity of tropical cyclones, either in the Atlantic or any other basin. ...
...It is beyond me why my colleagues would utilize the media to push an unsupported agenda that recent hurricane activity has been due to global warming...
...My concerns go beyond the actions of Dr. Trenberth and his colleagues to how he and other IPCC officials responded to my concerns. I did caution Dr. Trenberth before the media event and provided him a summary of the current understanding within the hurricane research community. I was disappointed when the IPCC leadership dismissed my concerns when I brought up the misrepresentation of climate science while invoking the authority of the IPCC...etc
And the http://www.sepp.org/NewSEPP/StateFear-Deming.htm :
With the publication of the article in Science, I gained significant credibility in the community of scientists working on climate change. They thought I was one of them, someone who would pervert science in the service of social and political causes. So one of them let his guard down. A major person working in the area of climate change and global warming sent me an astonishing email that said, ‘We have to get rid of the Medieval Warm Period".
Now if that was to be true, who could that have been?
I googled the phrase to get some clues --- and found no hints that said anything other than what you've quoted.In other words, I have no idea who said it.
It sounds very unscientific. And as I said earlier, such people in science are an embarassment.
And I am sure you would agree that the presence of such few people doesn't affect the truth or not, of climate and how and why it is changing. I'm sure you would also agree that there are publications on climate every day, and that the vast majority of these are by reputable scientists, who are properly following scientific procedures, and honestly trying only to get to the truth of the matter, and having reached consensus that fossil fuel consumption is accelerating warming. In fact I'll head over to science daily and see what's new today, on this topic.
It's important to know who the bad apples are, but it's also important to realize that most of the apples are following "sound science" and reaching a conclusion based on that.
Perhaps you should have googled about who was in the lead attempting to kill the Medieval Period. I tested all the names of the coauthors of the IPCC TAR (I do spend waaay to much time on this but that's the forensic method, patience patience patience). Anyway, this is the obvious winner. Not that I'm accusing anybody. Just curiousity.
I agree that testing global warming by increased greenhouse gasses is most certainly paramount. But where to start and what to believe? Which science is fair and which is constructed and which is biased by the it-must-be-true spirit?
So when you start with the pure physics, then there is little reason left to pursue greenhouse gasses all too vigorously.
If you start in paleo climate, there are a lot of disapointments too:
http://www.aip.org/history/climate/cycles.htm
The grand puzzle of the ice ages stood unsolved — except insofar as scientists now understood that nobody would ever jump up with a neat single solution.
BTW It's my objective (and perhaps progressing a little) to falsify that statement.
Remember the Landsea letter?
It is beyond me why my colleagues would utilize the media to push an unsupported agenda that recent hurricane activity has been due to global warming. Given Dr. Trenberth’s role as the IPCC’s Lead Author responsible for preparing the text on hurricanes, his public statements so far outside of current scientific understanding led me to concern.
So here is somebody not shy of offering scary stories perhaps balancing truth and political requirements.
He's active again:
Under this scenario, which assumes the amount of carbon dioxide in the air will roughly double over the next 100 years, the coldest days of the year in the Northeast will be as much as 18 degrees Fahrenheit warmer, and the temperatures currently experienced on the 18 hottest days of the year in the Washington area will prevail for two months.
The Southwest will become drier and hotter, the paper predicts, while the Gulf Coast will become warmer and experience less frequent, but more intense, rains.
Last month, three scientists from the National Center for Atmospheric Research in Boulder, Colo., published a paper suggesting that precipitation around the world is likely to become more intense as global warming continues. One of the authors of that study, Gerald A. Meehl, said the Purdue paper is consistent with his findings.
"This is what you'd expect to see," Meehl said. "As the climate continues to warm, you'd see more precipitation intensity [because] the warmer air can hold more moisture."
Kevin Trenberth, who heads the Colorado center's climate analysis section, said the two separate findings highlight "the need to examine not just the precipitation amount but also the intensity, frequency, duration and type" of rain or snow that may stem from climate change.
And of course one more tick off for the most popular ad honimem in the world:
That's not going to happen," said Michaels, who has accepted funding from coal, gas and mining interests opposed to mandatory curbs on greenhouse gas emissions. "These are very high assumptions that are not borne out by reality."
So it is clear that independent auditing and exposure of scaremongering needs to be unfunded. Moreover I wonder why the salaries of Trenbeth and Meehl et al are not mentioned.
Well a few more generatings ahead, when temperatures approach the little ice age again, people are going to marvel about the incredible effective manipulation of the public. You can just make anything true.
Your thrust seems to be that the climate change people are offering scare tactics and doomsday scenarios.
This hasn't been my experience.
About scaring tactics, there is an interesting thread here that I seem to have killed accidentily.
https://www.physicsforums.com/showthread.php?p=793563#post793563
I hope you enjoy the Problem Preservation Principle.
There is not a single doubt that the "scaremongers" are absolutely convinced of the correctness of global warming caused by anthropogenic emission of greenhouse gasses and of course their objectives are most noble, accomplishing a sustainable world. Most certainly. Discussing those things doesn't have the intention of scaremongering. It seems to be so simple, be good to nature, curb the gasses, and live happily ever after.
The problem however, is that the truth does not care about our common beliefs and feelings. No matter how good the cause, if you're wrong, you're wrong. That's the harsh reality.
Related to In Science Express from UC-Santa Barbara
1. What is Science Express from UC-Santa Barbara?
Science Express from UC-Santa Barbara is a program that offers interactive and engaging science education experiences for students of all ages. It aims to promote curiosity and excitement about science through hands-on activities, demonstrations, and experiments.
2. What types of science topics are covered in Science Express?
Science Express covers a wide range of science topics, including biology, chemistry, physics, earth sciences, and more. The program aims to provide a well-rounded science education experience and encourages students to explore multiple areas of science.
3. Who can participate in Science Express?
Science Express is open to students of all ages, from elementary school to high school and even college. The program also welcomes adults who are interested in learning more about science. Participants do not need any prior science knowledge or experience to join.
4. How can I get involved in Science Express?
There are several ways to get involved in Science Express. You can attend one of the program's events or workshops, become a volunteer or mentor, or even request a Science Express visit to your school or organization. You can also follow Science Express on social media for updates and information.
5. Is Science Express from UC-Santa Barbara a free program?
Yes, Science Express is a free program. It is funded by the UC-Santa Barbara's Department of Physics and is run by a team of dedicated volunteers. However, there may be fees associated with specific events or workshops, so be sure to check the program's website for more information.
14K
  • Astronomy and Astrophysics
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
