How did Einstein derive the Lorentz transformations in his 1905 paper?
  • Thread starter cincirob
In summary, the conversation discusses the author's personal experience with differential equations and their interest in understanding Einstein's differential equation derivation of the Lorentz transformations. They mention the use of time as a function of coordinates and the notation used in the equations. Another member of the conversation provides a PDF link with a detailed explanation of the calculations and the use of the chain rule. The conversation also touches on Michelson's experiment and the potential for him to have discovered relativity earlier if he had deduced the length contraction. There is also a discussion about notational confusion and the use of the chain rule in the equations.
cincirob
24
Hello all,
My personal experience with differential equations is from a long time ago. I wold be interested in someone showing me the details of Einstein's differential equation derivation of the Lorentz transformations in "On the Electrodynamics of Moving Bodies" - 1905. i understand what he does after he gets the differential equation but not how he gets it. He starts with time T as a function of coordinates in the stationary frame based on his method of synchronizing clocks;
1/2[T(0,0,0,t) + T(0,0-,0,t+x'/(c-v)+x'/(c+v))] = T(x',0,0,t+x'/(c-v))
He states "Hence if x' be chosen infintesimally small,
1/2(1/(c-v)+1/(c+v))dT/dt = dT/dX' + 1/(c-v)dT/dt
or
dT/dx' + v/(c^2-v^2)dT/dt = 0 "
Where the coordinates are (x,y,z,t) and the small letter "d" in the equations is the lower case Greek delta indicating partial derivatives.
Anybody?
It's just a Taylor series expansion (on both x and t) retaining only first degree terms in the differentials.
Chew on http://home.comcast.net/~integral50/Math/Specialrel.PDF" for a bit. I sorted this out in the early days of PF. I spent about 3 weeks, taking long walks in the park thinking about how to fill in that little gap in his algebra. Be sure you understand the notation of the first equation. What I do is simple algebra with no motivation other then I know where I need to go.
Enjoy.
Einstein's calculus
Tide,
Thanks for the reply. I ran into and former associate who was pretty good with math and he took the same route and showed me the details.
I've had quite a bit of math training but it was long time ago.
(Don't ask. :-) )
It's a personal quirk, but I guess I'm not comfortable with the expanded-series-throw-away-the-higher-order-terms approach. Not that I don't believe it works, I guess I just prefer closed form solutions. That's why I didn't recognize what Albert did.
An interesting historical note on such things is the analysis Michelson did on his famous experiment. He too resorted to an expanded series to calculate the time difference expected in the experiment. When Fitzgerald and Lorentz looked at it years later, they used and exact equation and deduced the contraction formula from it by inspection.
One wonders if Michelson might not have deduced it himself.
If he had wondered about it, he might have fallen on relativity himself 20 years before Einsein. The seeds of what might have convinced him are in the appendix of his paper. He was concerned that the motion (through space) of the device might cause the perpendularly reflected beam of light to miss returning to the splitter. He works out where the beam of light returns using Huygens theory and finds that it doesn't quite get back to the same place but assume the error won't harm the experiment.
The interesting thing is that if he had deduced the length contraction and if he had applied it to the reflection problem, it predicts a return to the exact spot on the splitter mirror. It would have been difficult to explain that as coincidence and might have prompted him and others to start thinkingin the right direction.
CinciRob,
no comment on my PDF? Sounds to me like it is just what you are looking for.
I’ve only just noticed this thread, so this response is a month too late, but if anyone’s still interested here goes…
I’m sure Einstein didn’t really leave out three pages of calculations. I believe he was applying the http://en.wikipedia.org/wiki/Chain_rule#Chain_rule_for_several_variables".
First, I should point out there’s scope for notational confusion, as the symbols x’ and t are used with two subtly different meanings. To avoid this confusion, I will use X’, Y, Z and T to denote the four co-ordinate variables that [itex]\tau[/itex] is a function of. As Y and Z take constant zero values throughout, the chain rule in this case is:
[tex] \frac{\partial \tau}{\partial x ^{\prime}} = \frac{\partial \tau}{\partial X ^{\prime}} \frac{\partial X ^{\prime} }{\partial x ^{\prime}} + \frac{\partial \tau}{\partial T} \frac{\partial T}{\partial x ^{\prime}} [/tex]
Apply this to each of the three functions of [itex]\tau[/itex] within the equation.
In the first case X’ = 0 and T = t.
In the second case X’ = 0 and [tex] T = t + \frac {x ^{\prime}} {c + v} + \frac {x ^{\prime}} {c - v} [/tex].
In the third case X’ = x’ and [tex] T = t + \frac {x ^{\prime}} {c - v} [/tex].
Hi,
I was already about to post a new thread, but found this old one which addresses exactly the issue I wanted to address.
So I thought it would be better to just continue the present thread.
I had a look at the reference, and there is one thing which is not correct in my opinion: on the left hand side of the equation one has dt=dx'*(1/(c+v)+1/(c-v)) , but one the right hand side dt=dx'/(c-v), which is inconsistent , i.e. one should not be entitled to use the same expression dtau/dt on both sides of the equation.
Basically, the same applies what I said above: your Ts are a different from each other, so they shouldn't be referenced with the same variable T.
NeverMind said:
Hi,
You need to be more specific, which reference and where in that reference are you talking about?
Well, at the top of page 2 of your derivation http://home.comcast.net/~integral50/Math/Specialrel.PDF , you are making x' infinitesimal and then set dx'*(1/(c+v)+1/(c-v))=dt (this applies to the left hand side of the equation). Towards the bottom of the same page you are doing the same thing for the right hand side (not fully written out in the same detail) and set dx'/(c-v)=dt , i.e. you are assigning the same variable dt to different quantities.
dt is not a variable it is differential element. Both expressions I develop satisfy the definition of [itex] \frac {\partial \tau} {\partial t} [/itex]. It seems to me that requiring a single fixed [itex] \Delta t [/itex] in the definition of the partial is counter to the concept of a differential element.
It is not about the general concept of a differential element here but its particular value. The point here is that on the left hand side it has the value dt=dx'*(1/(c+v)+1/(c-v)) but on the right hand side the value dt=dx'/(c-v). So they are actually two different differential elements and can't therefore both be denoted dt.
That is the same thing you said before, it is still wrong. It IS about a differential and certainly NOT about a fixed quantity. That is the same t on both sides of the equation. Both satisfy the definition of [itex] \frac {d\tau} {dt} [/itex].
Since when are differential elements fixed quantities?
They are not fixed, but their ratio is fixed:
if you have dt1=dx'/(c-v) and dt2=dx'*(1/(c-v)+1/(c+v)), then
dt1/dt2= [1/(c-v)] / [1/(c-v)+1/(c+v)] ,
but you assume dt1/dt2=1 in your derivation.
Hello "NeverMind".
I assume you are Thomas Smid, the one who runs the crackpot site http://www.physicsmyths.org.uk/ , correct?
You resurrected a post over a year and a half old. And now you resurrect it AGAIN after another year.
People have debunked your incorrect statements many times on many forums. Please do not bring these with you to PhysicsForums.com
Thank you.
FAQ: How did Einstein derive the Lorentz transformations in his 1905 paper?
What is Einstein's famous equation, E=mc²?
E=mc² is known as Einstein's mass-energy equivalence equation, which states that energy (E) is equal to mass (m) multiplied by the speed of light squared (c²).
What is the significance of Einstein's theory of relativity?
Einstein's theory of relativity revolutionized our understanding of space and time. It introduced the concept of spacetime as a single entity and explained how gravity works as the curvature of spacetime.
How did Einstein come up with his mathematical equations?
Einstein's mathematical equations were a result of his thought experiments and his belief in the fundamental principles of physics, such as the constancy of the speed of light and the principle of relativity.
Why is it important to understand Einstein's math?
Understanding Einstein's math is crucial for understanding some of the most fundamental concepts in physics, such as energy, mass, and the relationship between space and time. It also allows us to comprehend the implications of his theories and their applications in modern science and technology.
Can anyone understand Einstein's math, or is it too complex?
Einstein's math can be challenging to understand, but with patience and effort, anyone can grasp the basics. It requires a solid understanding of mathematics, especially calculus and geometry, and a willingness to think critically and creatively.
