Total # of electrons transferred
  • Thread starter m0286
  • Tags
    Electrons
In summary, the given chemical equation is balanced by breaking it into half reactions and balancing the atoms, hydrogen, charge, and electrons separately. The final balanced equation is 6Br2 + 10ClO3- + 6H2O --> 12BrO3- + 10Cl- + 12H+.
m0286
63
Hello...
Im working on a chemistry assignment for first year chem (university). The question says:
What is the TOTAl number of electrons transferred when yje following equationis balanced (for acid media) with integer coefficients? Br2(l) + ClO3-(aq) + H2O(l) --> BrO3-(aq)+ Cl-(aq) + H+(aq)
Sorry i woulda used the special writing thing buit i forget how to. I know i should have got help sooner and its due at 6am. so any help asap is appreciated.
1. Write the half reactions.
ClO3- --> Cl-
Br2 --> BrO3-
2. Balance the atoms, leaving H and O for last.
ClO3- --> Cl- + 3H2O
Br2 + 6H2O --> 2BrO3-
3. Balance H with hydrogen ions:
6H+ + ClO3- --> Cl- + 3H2O
Br2 + 6H2O --> 2BrO3- + 12H+
4. Balance charge with electrons:
6e- + 6H+ + ClO3- --> Cl- + 3H2O
Br2 + 6H2O --> 2BrO3- + 12H+ + 10e-
5. Add up equations (need to multiply to balance electrons):
10[6e- + 6H+ + ClO3- --> Cl- + 3H2O] =
6[Br2 + 6H2O --> 2BrO3- + 12H+ + 10e-] =
60e- + 60H+ + 10ClO3- --> 10Cl- + 30H2O
6Br2 + 36H2O --> 12BrO3- + 72H+ + 60e-
Add up the electrons exchanged in the reaciton and there's your answer (the last step of adding the equation wasn't really necessary to solve your problem). Hope you understand what I did.
Cesium: your final equation should be divided by 2 :)
This equation can be balanced without redox approach.
Related to Total # of electrons transferred
1. What is the definition of "Total # of electrons transferred"?
The total number of electrons transferred refers to the overall number of electrons that have been exchanged between two or more elements or molecules during a chemical reaction. This is a measure of the amount of electricity generated or consumed in a reaction.
2. How is the total number of electrons transferred calculated?
The total number of electrons transferred is determined by balancing the oxidation and reduction half-reactions in a chemical equation. The number of electrons lost in the oxidation half-reaction must equal the number of electrons gained in the reduction half-reaction.
3. What is the significance of the total number of electrons transferred in a chemical reaction?
The total number of electrons transferred is a key factor in determining the energy of a chemical reaction. It can also provide information about the strength and stability of the resulting products and can be used to calculate the potential difference or voltage of an electrochemical cell.
4. Can the total number of electrons transferred be negative?
No, the total number of electrons transferred cannot be negative. Electrons can only be transferred from one element or molecule to another, resulting in a positive value for the total number of electrons transferred in a chemical reaction.
5. How does the total number of electrons transferred relate to the concept of oxidation and reduction?
The total number of electrons transferred is directly related to the process of oxidation and reduction. Oxidation involves the loss of electrons, while reduction involves the gain of electrons. The total number of electrons transferred is the difference between the number of electrons lost and gained in a chemical reaction.
15K
12K
85K
16K
10K
