- 558
http://www.arxiv.org/PS_cache/astro-ph/pdf/0510/0510750.pdf
They make the same point that I did in the thread new study shows Dark Matter isn't needed? Relativty explains it? "This diversion has taken attention away from the main question: as I have now raised several times:"Are the non-linear GR effects significant in galactic rotation, and if so, then what of galactic halo DM?""We analyze the presence of an additional singular thin disk in the recent General Relativistic model of galactic gravitational field proposed by Cooperstock and Tieu. The physical variables of the disk’s energy-momentum tensor are calculated. We show that the disk is made of exotic matter, either cosmic strings or struts with negative energy density.
And that reference 9 was to their earlier paper: Models of GalaxiesAlthough the proposed galactic model does not really resolve galactic rotation without the presence of exotic matter, we believe that the idea of treating the non-linear galactic dynamical problem in the context of General Relativity is quite interesting and should be further investigated, specially the rotating models where we have the non-Newtonian effect of dragging of inertial frames; a modest step in this direction is presented in [9].
- As I suggested. So the problem has been worked on for some time!Rotation is also incorporated to the models and the effects of the source rotation on the rotation profile are calculated as first order corrections by using an approximate form of the Kerr metric in isotropic coordinates.
(emphasis mine)As an example of application of the models, we have numerically calculated some geodesic orbits for one of the potentials and compared them with the Newtonian orbits with the same energy and angular momentum. Near the central regions where the gravitational fields are strong, the motion of particles is considerably altered by General Relativistic effects.
We also calculated the first order effects of galactic rotation on the tangential velocity of circular orbits on the galactic plane using an approximate form of the Kerr metric expressed in cylindrical isotropic coordinates. In general, rotation increases the progade tangential velocity and has an opposite effect on the retrogade tangential velocity.
It should be mentioned that the stability study of the models presented based on the extension of Rayleigh criteria of stability is very limited. A more realistic stability analysis should rely on the first order perturbed General Relativistic fluid equations taking into account two spatial coordinates, which may be not a trivial task (see, for instance, Ujevic & Letelier (2004) for the one dimensional case). This will be subject of further investigation.
Of course we need to clear these non-linear effects out, just because it is something interesting in itself. However, could you agree on that it probably won't solve the dark matter problem in any way?Garth said:The case is by no means closed!
Several points: First, there are several DM problems, that needed to resolve galactic rotation curves as discussed in this thread, that needed to gravitationally bind galactic clusters, especially rich cluster DM, and that detected through analysis of the WMAP data. It is also required to explain large-scale structure formation in the early universe given the near isotropy of the CMB at z ~ 1100.EL said:However, could you agree on that it probably won't solve the dark matter problem in any way?
Well, they said like this:Garth said:All these observations are theory dependent. C&L suggested that it all might be explained away by GR non-linear effects
So they really don't offer any hints of HOW general relativity would solve the other problems.astro-ph/0510750 Cooperstock & Tieu said:Moreover, it will be of interest to extend this general relativistic approach to the other relevant areas of astrophysics with the aim of determining whether there is any scope remaining for the presence of any exotic dark matter in the universe. Clearly the absence of such exotic dark matter would have considerable significance.
But here is where the beauty of particle DM comes in! It may solve a bunch of, at least at first site, unrelated problems!These different observations of DM may have different explanations, each has to be analysed separately and not just lumped together.
Of course not. I'm sure they are great physicists. And I'm also sure they will accept that they have made some errors.C&L may be onto something, they are not idiots
Garth said:If the need for galactic haloes can be substantially explained by non-linear GR effects, whereas cluster DM is real, then this hypothesis may be tested.
Individual galaxies should lens distant quasars less effectively than a cluster. IOW the lensing mass of a spiral galaxy should agree with its baryonic mass, whereas the lensing (and virial) mass of a cluster should be much larger than the sum total of its visible component parts. The latter part is true, but what of the former - what data do we have on the gravitational lensing by an individual spiral galaxy?
Garth
Show me the particle and I'll agree with you!EL said:But here is where the beauty of particle DM comes in! It may solve a bunch of, at least at first site, unrelated problems!
Garth said:Show me the particle and I'll agree with you!
Garth
It might be helpful to lump them together but take DM entirely out of the equation. Then ask "why does the GR gravititational model fail to accurately predict the behavior of visible matter at galactic, cluster, and cosmological scales?" Blind faith in the infallibility of GR gravitation necessitated the invention of DM - simply because GR could not be allowed to fail. Back when GR was developed, physicists "knew" things about the universe that later observations have shown to be absolutely wrong. Is this 90-year old theory of gravitation so sacred that we cannot allow observations to falsify it?Garth said:Several points: First, there are several DM problems, that needed to resolve galactic rotation curves as discussed in this thread, that needed to gravitationally bind galactic clusters, especially rich cluster DM, and that detected through analysis of the WMAP data. It is also required to explain large-scale structure formation in the early universe given the near isotropy of the CMB at z ~ 1100.
All these observations are theory dependent. C&L suggested that it all might be explained away by GR non-linear effects, that is not my position. These different observations of DM may have different explanations, each has to be analysed separately and not just lumped together.
The Cooperstock and Tieu model is a theoretical model developed by physicists Barry Cooperstock and Thomas Tieu in 1995. It proposes that the universe is made up of two different types of matter: ordinary matter and a type of matter called "shadow matter" which interacts with ordinary matter through gravity but not through any of the other fundamental forces.
The Cooperstock and Tieu model differs from other models of the universe in that it proposes the existence of shadow matter, which is not present in other models. This additional type of matter allows for a more consistent explanation of certain astronomical observations, such as the rotation curves of galaxies and the velocities of stars in galaxies.
Some evidence that supports the Cooperstock and Tieu model includes the observed rotation curves of galaxies, the distribution of dark matter in clusters of galaxies, and the large-scale structure of the universe. However, further research and observations are needed to fully confirm the validity of the model.
The Cooperstock and Tieu model can be tested through experiments involving gravitational lensing, which is the deflection of light by the presence of matter. The model predicts that the amount of deflection should be different for shadow matter compared to ordinary matter, so experiments using gravitational lensing can potentially confirm or disprove the existence of shadow matter.
The Cooperstock and Tieu model has significant implications for our understanding of the universe, as it challenges the traditional notion of dark matter as the only explanation for certain astronomical phenomena. If the model is confirmed, it could lead to a better understanding of the structure and evolution of the universe and potentially open up new avenues of research in cosmology and particle physics.
