MHB -1.1.1c Solve for the following initial value
  • Thread starter Thread starter karush
    Initial Value
karush
MHB
$1.1.2c\\ \displaystyle \frac{dy}{dt}=2y-10, \qquad y(0)=y_0$
rewrite
$\quad\displaystyle y'-2y=-10$
obtain u(x)
$\quad\displaystyle u(t)=\exp\int -2 \, dt=e^{-2t}$
integrate using the boundaries:
$\quad\displaystyle \int_{y_0}^{e^{-2t}y}\,du=-10\int_{0}^{t}e^{-2v}\,dv$
resulting in
$\quad\displaystyle e^{-2t}y-y_0=-5\left(e^{-2t}-1\right)$
multiply thru by $e^{2t}$
$\quad\displaystyle y-y_0e^{2t}=5\left(1-e^{2t}\right)$
then
$\quad\displaystyle y=5\left(1-e^{2t}\right)+y_0e^{2t}$
then
$\quad\displaystyle y=5-5e^{2t}+y_0e^{2t}$
then
$\quad\displaystyle y=5-(y_0+5)e^{-2t}$
book answer
$\quad\displaystyle y=5+(y_0-5)e^{-2t}$ok seems to be a sign error someplace
$\dfrac{dy}{dt} = 2(y-5)$
$\dfrac{dy}{y-5} = 2 \,dt$
$\ln|y-5| = 2t+ C$
$y(0) = y_0 \implies \ln|y_0-5| = C$
$\ln|y-5| = 2t+ \ln|y_0-5|$
$\ln \bigg| \dfrac{y-5}{y_0-5} \bigg| = 2t$
$\dfrac{y-5}{y_0-5} = e^{2t}$
$y-5 = (y_0-5)e^{2t}$
$y = 5 + (y_0-5)e^{2t}$
book answer should have a positive exponent ...
$\ln|y-5| = 2t+ C$
oh this one?
so you did this without the $u(x)$ method!
rewrite
obtain u(x)
resulting in
$\quad\displaystyle y-y_0e^{2t}=-5\left(1-e^{2t}\right)$
then
$\quad\displaystyle y=-5\left(1-e^{2t}\right)+y_0e^{2t}$
then
$\quad\displaystyle y=-5+5e^{2t}+y_0e^{2t}$
then
$\quad\displaystyle y=5-(y_0+5)e^{2t}$
book answer
$\quad\displaystyle y=5+(y_0-5)e^{-2t}$still sign ?
using an integrating factor ...
$\dfrac{dy}{dt} = 2y-10$
$\dfrac{dy}{dt} - 2y = -10$
$\mu(t) = e^{-2t}$
$e^{-2t}\left(\dfrac{dy}{dt} - 2y\right) = -10e^{-2t}$
$\dfrac{d}{dt}\left(e^{-2t} \cdot y\right) = -10e^{-2t}$
integrate both sides ...
$e^{-2t} \cdot y = 5e^{-2t} + C$
$y(0) = y_0 \implies y_0 = 5 + C \implies C = y_0 - 5$
$e^{-2t} \cdot y = 5e^{-2t} + y_0 - 5$
multiply every term by $e^{2t}$ ...
$y = 5 + (y_0 - 5)e^{2t}$
rewrite
obtain u(x)
resulting in
then
then
then
book answer
In my book [math]\dfrac{-10}{-2} = 5[/math].
Here's a higher brow method, used when we have a linear nth order equation. (It's kinda overkill in this situation.)
Method of Characteristics:
[math]y' - 2y = -10[/math]
Homogeneous equation:
[math]y' - 2y = 0[/math]
Thus [math]m - 2 = 0 \implies m = 2[/math]
So the homogeneous solution is [math]y = Ae^{2t}[/math]
For the particular solution we take y = B
[math]y' = 0[/math]
So
[math]y' - 2y = -10 \implies 0 - 2(B) = -10 \implies B = 5[/math]
Thus for the whole equation
[math]y = A e^{2t} + 5[/math]
(Then use [math]y(0) = y_0[/math] to find A.)
-Dan
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
