MHB 1.3 find dx of (7+9x-6\sqrt{x})/x
  • Thread starter Thread starter karush
    Dx
To find the derivative of the function y = (7 + 9x - 6√x) / x, several methods are discussed, including expansion and the quotient rule. Expanding the function leads to y = 7/x + 9 - 6√x/x, which simplifies the differentiation process. Using the quotient rule is also suggested, resulting in the derivative y' = (3√x - 7) / x^2. An alternative approach involves rewriting the function as y = 7x^(-1) + 9 - 6x^(-1/2), leading to the same derivative in a different form. Ultimately, both methods confirm that the derivative is y' = (7 - 3√x) / x^2.
karush
MHB
Find $\dfrac{dy}{dx}$ for:$y=\dfrac{7+9x-6\sqrt{x}}{x}$
ok several ways to solve this but thot the best might be to expand it first so
$y=\dfrac{7}{x} +9 -6\dfrac{\sqrt{x}}{x}$
or is there a better way
It depends on what form you want for your answer. If you want to do it fast I'd recommend dividing through first. If you want it simplified (ie. as a fraction) it would be faster to use the quotient rule. But it's really a matter of taste.
-Dan
$\left(\dfrac{f}{g}\right)'=\dfrac{f'\cdot g-g'\cdot f}{g^2}$
quotient rule looks kinda busy since
$f'=-\frac{3}{\sqrt{x}}+9$
but expansion wasn't easy either
$\left(\dfrac{7}{x}\right)'=-\dfrac{7}{x^2}$
$\quad 9'=0$
$\quad\left(-6\cdot \dfrac{\sqrt{x}}{x}\right)'
=\dfrac{3}{x^{\dfrac{3}{2}}}$
$\implies -\dfrac{7}{x^2}+\dfrac{3}{x^{\dfrac{3}{2}}}$
hence $y'=\dfrac{3\sqrt{x}-7}{x^2}$
hopefully
hopefully
You've been doing much more involved problems over the years. You don't need the "hopefully." If you doubt your answer, check it by integration!
Yes. that's the derivative.
-Dan
This is, I think, simpler- write the function as $y= 7x^{-1}+ 9- 6x^{-1/2}$. Now use the fact that the derivative of $x^n$ is $nx^{n- 1}$
$\frac{dy}{dx}= -7x^{-2}- 3x^{-3/2}$ which can be written in the original form as $\frac{dy}{dx}= \frac{7-3\sqrt{x}}{x^2}$​
