MHB 1.8.1 AP Calculus find k for critical point
To find the critical point of the function g, the derivative g' must be set to zero. The derivative is given as g' = 2xe^(kx) + e^(kx)kx^2, and substituting x = 2/3 leads to the equation g' = (4/3)e^(2k/3) + (4k/9)e^(2k/3). Critical points occur where the derivative equals zero, which is satisfied when k = -3. This value of k confirms the critical point at x = 2/3. The discussion emphasizes the importance of setting the derivative to zero to identify critical values effectively.
karush
MHB
$\displaystyle g'=2xe^{kx}+e^{kx}kx^2$
we are given $ x=\dfrac{2}{3}$ then
$\displaystyle g'=\dfrac{4}{3}e^\left(\dfrac{2k}{3}\right)+e^\left({\dfrac{2k}{3}}\right)\dfrac{4k}{9}$
ok something is ? aren't dx supposed to set this to 0 to find the critical point
did a desmos look like k=-3 but ?
[DESMOS]advanced: {"version":7,"graph":{"showGrid":false,"squareAxes":false,"viewport":{"xmin":-0.6595622289691282,"ymin":-0.7302941176470592,"xmax":2.1639671827955773,"ymax":1.1520588235294116}},"expressions":{"list":[{"type":"expression","id":"graph1","color":"#2d70b3","latex":"y_1=x^2e^{kx}"},{"type":"expression","id":"2","color":"#388c46","latex":"k=-3","hidden":true},{"id":"6","type":"table","columns":[{"values":["\\frac{2}{3}"],"hidden":true,"id":"4","color":"#000000","latex":"x"},{"values":[""],"id":"5","color":"#c74440","latex":"y_1"},{"values":[""],"id":"7","color":"#2d70b3","latex":"k"}]}]}}[/DESMOS]
critical points are defined points on the function where the derivative equals zero, or where the derivative is undefined ...
$g=x^2e^{kx}$
$g' = xe^{kx}(kx+2)$
the derivative, $g'$, is defined for all values of $x$ in $g$'s domain, hence any critical value will be where $g'=0$
the first factor, $xe^{kx}$ equals zero only at $x=0$, no matter what $k$ is.
the second factor ...
$k\left(\frac{2}{3} \right) + 2 = 0 \implies k = -3$
that was indeed very helpful Mahalo
best place to be ... MHB
